Kernel: 5.18.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=c880b797-5f3c-4d1d-bda8-80ce11228d59 rw [email protected]
resume=UUID=425e77c1-16a6-4525-99aa-76416df146ff loglevel=3
amdgpu.ppfeaturemask=0xffffffff
Type: Desktop System: Gigabyte product: AB350-Gaming 3 v: N/A
Mobo: Gigabyte model: AB350-Gaming 3-CF serial: <superuser required>
UEFI: American Megatrends LLC. v: F52e date: 12/14/2021
Device-1: sony_controller_battery_06:ed:69:89:63:25 model: N/A serial: N/A
charge: N/A status: full
Info: model: AMD Ryzen 5 1600 bits: 64 type: MT MCP arch: Zen
built: 2017-19 process: GF 14nm family: 0x17 (23) model-id: 1 stepping: 1
microcode: 0x8001138
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 3186 high: 3417 min/max: 1550/3600 boost: disabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3122 2: 3156
3: 3417 4: 3068 5: 3203 6: 3216 7: 3086 8: 3350 9: 3079 10: 3173 11: 3317
12: 3047 bogomips: 86238
vendor: XFX Pine driver: amdgpu v: kernel arch: GCN 4 process: GF 14nm
built: 2016-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports:
active: DP-1,DVI-D-1,HDMI-A-1 empty: DP-2,DP-3 bus-ID: 07:00.0
Device-2: ARC Camera type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-1:2 chip-ID: 05a3:9331 class-ID: 0102 serial: <filter>
Screen-1: 0 s-res: 5760x1080 s-dpi: 96 s-size: 1524x285mm (60.00x11.22")
s-diag: 1550mm (61.04")
Monitor-1: DVI-D-1 mapped: DVI-D-0 pos: primary,left model: Acer S231HL
serial: <filter> built: 2013 res: 1920x1080 hz: 60 dpi: 96 gamma: 1.2
size: 510x287mm (20.08x11.3") diag: 585mm (23") ratio: 16:9 modes:
Monitor-2: DP-1 mapped: DisplayPort-0 pos: primary,center
model: ViewSonic VX2458-mhd serial: <filter> built: 2019 res: 1920x1080
dpi: 94 gamma: 1.2 size: 521x293mm (20.51x11.54") diag: 598mm (23.5")
Monitor-3: HDMI-A-1 mapped: HDMI-A-0 pos: right model: AOC 2370
serial: <filter> built: 2014 res: 1920x1080 hz: 60 dpi: 96 gamma: 1.2
size: 509x286mm (20.04x11.26") diag: 584mm (23") ratio: 16:9 modes:
OpenGL: renderer: AMD Radeon RX 590 Series (polaris10 LLVM 13.0.1 DRM
3.46 5.18.3-zen1-1-zen)
v: 4.6 Mesa 22.1.1 direct render: Yes
vendor: XFX Pine driver: snd_hda_intel v: kernel bus-ID: 1-1:2
chip-ID: 05a3:9331 pcie: class-ID: 0102 gen: 3 serial: <filter>
speed: 8 GT/s lanes: 16 bus-ID: 07:00.1 chip-ID: 1002:aaf0 class-ID: 0403
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 09:00.3
Device-3: ARC Camera type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.18.3-zen1-1-zen running: yes
lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Ralink MT7601U Wireless Adapter type: USB driver: mt7601u
bus-ID: 1-7:72 chip-ID: 148f:7601 class-ID: 0000 serial: <filter>
IF: wlp2s0f0u7 state: up mac: <filter>
driver: btusb v: 0.8 bus-ID: 1-8:7 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 2.96 TiB used: 14.71 GiB (0.5%)
model: WDS250G2X0C-00L350 size: 232.89 GiB block-size: physical: 512 B
rev: 101110WD temp: 52.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000LM007-1R8174
type: HDD rpm: 5400 serial: <filter> rev: SBK2 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT500MX500SSD1
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 023
ID-4: /dev/sdc maj-min: 8:32 vendor: Crucial model: CT500MX500SSD1
ID-1: / raw-size: 200.38 GiB size: 200.38 GiB (100.00%)
used: 14.18 GiB (7.1%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
used: 608 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p3 maj-min: 259:3
ID-3: /home raw-size: 465.76 GiB size: 931.52 GiB (200.00%)
used: 534.7 MiB (0.1%) fs: btrfs dev: /dev/sdb maj-min: 8:16
ID-4: /var/log raw-size: 200.38 GiB size: 200.38 GiB (100.00%)
ID-5: /var/tmp raw-size: 200.38 GiB size: 200.38 GiB (100.00%)
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: zram size: 31.27 GiB used: 256 KiB (0.0%)
ID-2: swap-2 type: partition size: 32 GiB used: 0 KiB (0.0%) priority: -2
System Temperatures: cpu: 16.8 C mobo: N/A gpu: amdgpu temp: 47.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 648
Processes: 396 Uptime: 1h 4m wakeups: 1 Memory: 31.27 GiB
used: 3.83 GiB (12.3%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1769
lib: 510 Shell: fish v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.17
e[1;34mGaruda (2.6.3-2):e[0m
e[1;34m System install date:e[0m 2022-07-14
e[1;34m Last full system update:e[0m 2022-07-14
e[1;34m Is partially upgraded: e[0m Yes
e[1;34m Relevant software: e[0m NetworkManager
e[1;34m Windows dual boot: e[0m No/Undetected
e[1;34m Snapshots: e[0m Snapper
e[1;34m Failed units: e[0m
This is my terminal output trying to set up the printer with hp-setup -i
It mysteriously fails.
hp-setup -i
HP Linux Imaging and Printing System (ver. 3.22.6)
Printer/Fax Setup Utility ver. 9.0
Copyright (c) 2001-18 HP Development Company, LP
This software comes with ABSOLUTELY NO WARRANTY.
This is free software, and you are welcome to distribute it
under certain conditions. See COPYING file for more details.
(Note: Defaults for each question are maked with a '*'. Press <enter> to accept the default.)
| SELECT CONNECTION (I/O) TYPE |
Num Connection Description
Type
0* usb Universal Serial Bus (USB)
1 net Network/Ethernet/Wireless (direct connection or JetDirect)
2 par Parallel Port (LPT:)
Enter number 0...2 for connection type (q=quit, enter=usb*) ?
Using connection type: usb
Setting up device: hp:/usb/HP_LaserJet_Professional_P_1102w?serial=000000000W481VWXPR1a
| PRINT QUEUE SETUP |
Please enter a name for this print queue (m=use model name:'HP_LaserJet_Professional_P_1102w'*, q=quit) ?m
Using queue name: HP_LaserJet_Professional_P_1102w
Locating PPD file... Please wait.
error: No PPD found for model laserjet_professional_p_1102w using old algorithm.
error: Unable to find an appropriate PPD file.
Would you like to specify the path to the correct PPD file to use (y=yes, n=no*, q=quit) ? y
Please enter the full filesystem path to the PPD file to use (q=quit) :"/usr/share/ppd/HP/hp-laserjet_professional_p_1102w.ppd.gz"
error: File not found or not an appropriate (PPD) file.
Please enter the full filesystem path to the PPD file to use (q=quit) :/usr/share/ppd/HP/hp-laserjet_professional_p_1102w.ppd.gz
File "/usr/bin/hp-setup", line 560, in <module>
desc = nickname_pat.search(nickname).group(1)
TypeError: cannot use a string pattern on a bytes-like object
