Hello folks,
I have a Asus rog flo x16 2-in-1 laptop. I installed Garuda on it and now trying to get the touchscreen functionality working.
First I installed iio-sensor-proxy and now it changes orientation when I turn laptop.
However, when I turn the laptop 360 and turn it into a tablet, the keyboard is not disabled.
I installed detect-tablet-mode as mentioned in arch wiki (Tablet PC - ArchWiki), but I didn’t find any configuration option.
Can someone help how to configure detect-tablet-mode?
What I want is in tablet mode, the keyboard and trackpad should be disabled.
Kernel: 6.5.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=8c21cc27-c660-4c39-9c5e-1dc59b00ad5c rw rootflags=subvol=@
resume=UUID=6b675d04-b6c5-4b3f-838d-4b4f19888841 loglevel=3 ibt=off
Type: Convertible System: ASUSTeK product: ROG Flow X16 GV601RM_GV601RM
Mobo: ASUSTeK model: GV601RM v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: GV601RM.310 date: 07/06/2022
ID-1: BAT0 charge: 51.4 Wh (59.3%) condition: 86.7/90.0 Wh (96.3%)
power: 37.2 W volts: 16.0 min: 16.0 model: ASUSTeK ASUS Battery type: Li-ion
serial: N/A status: charging
Device-1: hid-0018:04F3:2FC2.0003-battery model: ELAN9008:00 04F3:2FC2
serial: N/A charge: N/A status: N/A
Info: model: AMD Ryzen 7 6800HS with Radeon Graphics bits: 64 type: MT MCP
family: 0x19 (25) model-id: 0x44 (68) stepping: 1 microcode: 0xA404102
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 672 high: 1580 min/max: 400/4785 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 1397 2: 400 3: 400
4: 1490 5: 400 6: 400 7: 1499 8: 400 9: 1580 10: 400 11: 400 12: 400
13: 400 14: 400 15: 400 16: 400 bogomips: 102204
Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: ASUSTeK
driver: nvidia v: 535.104.05 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-08) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:2520 class-ID: 0300
Device-2: AMD Rembrandt [Radeon 680M] vendor: ASUSTeK driver: amdgpu
pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: DP-1,
DP-2, DP-3, DP-4, DP-5, HDMI-A-1 bus-ID: 09:00.0 chip-ID: 1002:1681
class-ID: 0300 temp: 44.0 C
Device-3: Quanta USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1:2 chip-ID: 0408:30c3
Screen-1: 0 s-res: 2560x1600 s-dpi: 96 s-size: 676x422mm (26.61x16.61")
s-diag: 797mm (31.37")
Monitor-1: eDP-1 mapped: eDP model: AU Optronics 0xc199 built: 2021
res: 2560x1600 hz: 165 dpi: 189 gamma: 1.2 size: 344x215mm (13.54x8.46")
diag: 406mm (16") ratio: 16:10 modes: max: 2560x1600 min: 640x480
API: OpenGL v: 4.6 Mesa 23.1.7-arch1.1 renderer: AMD Radeon Graphics
(rembrandt LLVM 16.0.6 DRM 3.54 6.5.2-zen1-1-zen) direct-render: Yes
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:228e class-ID: 0403
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 09:00.1
snd_sof_amd_renoir, snd_sof_amd_rembrandt pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 09:00.5 chip-ID: 1022:15e2 class-ID: 0480
bus-ID: 09:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.5.2-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.79 status: active with: 1: pipewire-pulse
lanes: 1 bus-ID: 06:00.0 chip-ID: 14c3:0616 class-ID: 0280
IF: wlp6s0 state: up mac: <filter>
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:3 chip-ID: 0489:e0e2
lmp-v: 11 status: discoverable: no pairing: no class-ID: 7c0000
Local Storage: total: 953.87 GiB used: 355.73 GiB (37.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 3400 MTFDKBA1T0TFH
lanes: 4 tech: SSD serial: <filter> fw-rev: P7MA001 temp: 31.9 C
ID-1: / raw-size: 200 GiB size: 200 GiB (100.00%) used: 11.36 GiB (5.7%)
fs: btrfs dev: /dev/nvme0n1p9 maj-min: 259:9
ID-2: /boot/efi raw-size: 512.7 MiB size: 511.7 MiB (99.80%)
used: 576 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p7 maj-min: 259:7
ID-3: /home raw-size: 514.03 GiB size: 514.03 GiB (100.00%)
used: 344.37 GiB (67.0%) fs: btrfs dev: /dev/nvme0n1p10 maj-min: 259:10
ID-4: /var/log raw-size: 200 GiB size: 200 GiB (100.00%)
used: 11.36 GiB (5.7%) fs: btrfs dev: /dev/nvme0n1p9 maj-min: 259:9
ID-5: /var/tmp raw-size: 200 GiB size: 200 GiB (100.00%)
ID-1: swap-1 type: partition size: 16 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p8 maj-min: 259:8
ID-2: swap-2 type: zram size: 14.89 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 51.1 C mobo: N/A gpu: amdgpu temp: 44.0 C
Fan Speeds (rpm): cpu: 2400
Processes: 387 Uptime: 23m wakeups: 4 Memory: total: 16 GiB note: est.
available: 14.89 GiB used: 5.29 GiB (35.5%) Init: systemd v: 254
pm: pacman pkgs: 1388 libs: 375 tools: octopi,pamac,paru Shell: fish
v: 3.6.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.29
System install date: 2023-08-06
Last full system update: 2023-09-10 ↻
Failed units: detect-tablet-mode.service
