Hi, I don't really know when or why this happened (probably because I want my system to be in englisch but the times and stuff like they are in german). The error is above the inxi. Its not to serious but at least minecraft doesn't start and maybe other apps face the same problem.
Thanks in advance muddy.
LANGUAGE = "en_US:de",
LC_ALL = (unset),
LC_ADDRESS = "de_DE.UTF-8",
LC_NAME = "de_DE.UTF-8",
LC_MONETARY = "de_DE.UTF-8",
LC_PAPER = "de_DE.UTF-8",
LC_IDENTIFICATION = "de_DE.UTF-8",
LC_TELEPHONE = "de_DE.UTF-8",
LC_MEASUREMENT = "de_DE.UTF-8",
LC_TIME = "de_DE.UTF-8",
LC_NUMERIC = "de_DE.UTF-8",
LANG = "de_AT.UTF-8"
perl: warning: Falling back to the standard locale ("C").
Kernel: 5.15.13-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=f181ffc3-cea3-4242-9c63-210fcfa3609e rw rootflags=subvol=@
Type: Laptop System: ASUSTeK product: TUF Gaming FX505DV_FX505DV v: 1.0
Mobo: ASUSTeK model: FX505DV v: 1.0 serial: <superuser required>
UEFI-[Legacy]: American Megatrends v: FX505DV.312 date: 01/28/2021
ID-1: BAT0 charge: 8.0 Wh (20.9%) condition: 38.2/48.1 Wh (79.5%)
volts: 12.4 min: 11.7 model: FX50442 type: Li-ion serial: N/A
status: Charging
Info: model: AMD Ryzen 5 3550H with Radeon Vega Mobile Gfx bits: 64
type: MT MCP arch: Zen/Zen+ note: check family: 0x17 (23)
model-id: 0x18 (24) stepping: 1 microcode: 0x8108102
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 2267 high: 2772 min/max: 1400/2100 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 1496 2: 1283
3: 2770 4: 2769 5: 2772 6: 2766 7: 1585 8: 2695 bogomips: 33538
STIBP: disabled, RSB filling
Device-1: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: ASUSTeK
driver: nvidia v: 495.46 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1f11 class-ID: 0300
Device-2: AMD Picasso vendor: ASUSTeK driver: amdgpu v: kernel
bus-ID: 05:00.0 chip-ID: 1002:15d8 class-ID: 0300
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 5-1:2 chip-ID: 13d3:56a2 class-ID: 0e02 serial: <filter>
loaded: modesetting,nvidia display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1-1 res: 1920x1080 hz: 60 dpi: 142
OpenGL: renderer: NVIDIA GeForce RTX 2060/PCIe/SSE2
v: 4.6.0 NVIDIA 495.46 direct render: Yes
Device-1: NVIDIA TU106 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f9
v: kernel bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.15.13-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.43 running: yes
vendor: ASUSTeK driver: r8169 v: kernel port: e000 bus-ID: 02:00.0
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: AzureWave driver: rtw_8822ce v: N/A modules: rtw88_8822ce
port: d000 bus-ID: 04:00.0 chip-ID: 10ec:c822 class-ID: 0280
IF-ID-1: ipv6leakintrf0 state: unknown speed: N/A duplex: N/A
mac: <filter>
IF-ID-2: proton0 state: unknown speed: 10 Mbps duplex: full mac: N/A
Device-1: IMC Networks Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 3-4:3 chip-ID: 13d3:3548 class-ID: e001 serial: <filter>
address: <filter>
Local Storage: total: 476.94 GiB used: 243.61 GiB (51.1%)
model: 2200V MTFDHBA512TCK size: 476.94 GiB block-size: physical: 512 B
rev: P1MA0V4 temp: 43.9 C scheme: MBR
ID-1: / raw-size: 476.93 GiB size: 476.93 GiB (100.00%)
used: 243.61 GiB (51.1%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
ID-2: /home raw-size: 476.93 GiB size: 476.93 GiB (100.00%)
ID-3: /var/log raw-size: 476.93 GiB size: 476.93 GiB (100.00%)
ID-4: /var/tmp raw-size: 476.93 GiB size: 476.93 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.26 GiB used: 2 MiB (0.0%) priority: 100
System Temperatures: cpu: 48.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2800
GPU: device: nvidia screen: :0.0 temp: 44 C device: amdgpu temp: 48.0 C
Processes: 307 Uptime: 5m wakeups: 1 Memory: 7.26 GiB
used: 2.98 GiB (41.0%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1572 lib: 458 Shell: Bash
v: 5.1.12 running-in: konsole inxi: 3.3.11
