Simple question. What is the proper way to set the gamma (display) on Garuda Linux?
The KDE and Nvidia settings do not stick. Seems to be a common thing on a lot of distros IME.
Kernel: 6.1.11-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=0f309958-7881-489f-869b-afc74fd9b0e0 rw [email protected]
resume=UUID=f551f9c4-353d-45f8-b453-fd3936591bd1 loglevel=3 ibt=off
Type: Desktop Mobo: ASUSTeK model: PRIME B450M-A v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 3604
date: 02/25/2022
Info: model: AMD Ryzen 7 2700X bits: 64 type: MT MCP arch: Zen+ gen: 2
model-id: 8 stepping: 2 microcode: 0x800820D
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 3610 high: 3700 min/max: 2200/3700 boost: disabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3700 2: 3700
3: 3700 4: 3700 5: 3700 6: 3700 7: 3700 8: 3700 9: 3700 10: 3700 11: 3149
12: 2832 13: 3686 14: 3700 15: 3700 16: 3700 bogomips: 118403
Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: Micro-Star MSI
driver: nvidia v: 525.89.02 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2023-02) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 09:00.0 chip-ID: 10de:1c03 class-ID: 0300
Device-2: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 3-1:2 chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
Screen-1: 0 s-res: 3840x1200 s-dpi: 93 s-size: 1049x321mm (41.30x12.64")
s-diag: 1097mm (43.19")
Monitor-1: DVI-D-0 pos: primary,right res: 1920x1200 hz: 60 dpi: 94
size: 518x324mm (20.39x12.76") diag: 611mm (24.05") modes: N/A
Monitor-2: HDMI-0 pos: left res: 1920x1200 hz: 60 dpi: 94
API: OpenGL v: 4.6.0 NVIDIA 525.89.02 renderer: NVIDIA GeForce GTX 1060
6GB/PCIe/SSE2 direct-render: Yes
Device-1: NVIDIA GP106 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel bus-ID: 3-1:2 v: kernel pcie: chip-ID: 046d:0825
gen: 3 class-ID: 0102 speed: 8 GT/s serial: <filter> lanes: 16
bus-ID: 09:00.1 chip-ID: 10de:10f1 class-ID: 0403
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0b:00.3
Device-3: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
Device-4: C-Media CM6631A Audio Processor type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-3:4 chip-ID: 0d8c:0004
Sound API: ALSA v: k6.1.11-zen1-1-zen running: yes
Device-1: Qualcomm Atheros AR9285 Wireless Network Adapter driver: ath9k
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 07:00.0
chip-ID: 168c:002b class-ID: 0280
IF: wlp7s0 state: up mac: <filter>
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 08:00.0 chip-ID: 10ec:8168
Local Storage: total: 2.62 TiB used: 75.23 GiB (2.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Silicon Power
model: SPCC M.2 PCIe SSD size: 476.94 GiB block-size: physical: 512 B
rev: H211011a temp: 42.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: M4-CT128M4SSD2
type: SSD serial: <filter> rev: 000F scheme: GPT
model: WD20EARX-00PASB0 size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: N/A serial: <filter> rev: AB51
scheme: MBR
ID-4: /dev/sdc maj-min: 8:32 vendor: Kingston model: SUV400S37240G
size: 223.57 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 96R9 scheme: GPT
ID-1: / raw-size: 234.38 GiB size: 234.38 GiB (100.00%)
used: 75.23 GiB (32.1%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
ID-2: /boot/efi raw-size: 497 MiB size: 496 MiB (99.80%)
used: 612 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p5 maj-min: 259:5
ID-3: /home raw-size: 234.38 GiB size: 234.38 GiB (100.00%)
ID-4: /var/log raw-size: 234.38 GiB size: 234.38 GiB (100.00%)
ID-5: /var/tmp raw-size: 234.38 GiB size: 234.38 GiB (100.00%)
ID-2: swap-2 type: partition size: 15.62 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 40.6 C mobo: N/A gpu: nvidia temp: 51 C
Processes: 374 Uptime: 1h 0m wakeups: 0 Memory: 15.53 GiB
used: 5.67 GiB (36.5%) Init: systemd v: 252 default: graphical
pkgs: 1727 libs: 381 tools: octopi,pamac,paru,yay pm: rpm pkgs: 0
Shell: fish v: 3.6.0 default: Bash v: 5.1.16 running-in: alacritty
inxi: 3.3.25
Garuda (2.6.14-1):
System install date: 2023-01-18
Last full system update: 2023-02-15
Is partially upgraded: Yes
