Set a number higher than 99 when batch renaming from dolphin
I don't know if some recent update caused this, but when I press F2 after selecting multiple files, I cannot set the value of # to be higher then 99, in the batch rename tool (or whatever its called).
Example: I rename my wallpapers to numbers (1.jpeg, 2.jpeg etc).The folder has over 100 images. I recently added a few more and had to rename them, starting from 156.jpeg. After selecting the new images, I couldn't set the value of # to 156. It wouldn't go higher than 99.
I opened up a post on forum.KDE.org and the person replied showed that their rename tool does not have this bug. More over they said that the theme might be of the issue. Changing the theme and application style did not fix it.
My Post on forum.KDE.org:
Set a number higher than 99 when batch renaming • KDE Community Forums
System info:
Kernel: 6.1.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=1d17e6de-9557-4600-a71d-2fc817db7784 rw [email protected]
quiet
cryptdevice=UUID=ccf6a087-7f6c-4357-9cb5-8bf35bb72a1d:luks-ccf6a087-7f6c-4357-9cb5-8bf35bb72a1d
root=/dev/mapper/luks-ccf6a087-7f6c-4357-9cb5-8bf35bb72a1d quiet splash
resume=/dev/mapper/luks-253338ee-7144-43f5-bc83-a762863e12f3 loglevel=3
mitigations=off ibt=off
Desktop: KDE Plasma v: 5.27.1 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: ASUSTeK product: ROG Strix G713QM_G713QM v: 1.0
Mobo: ASUSTeK model: G713QM v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: G713QM.321 date: 09/07/2022
ID-1: BAT0 charge: 51.8 Wh (60.0%) condition: 86.4/90.0 Wh (96.0%)
volts: 15.6 min: 15.9 model: AS3GWAF3KC GA50358 type: Li-ion
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 2S
microcode: 0xA50000B
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1199 high: 1200 min/max: 1200/4462 boost: enabled
scaling: driver: acpi-cpufreq governor: powersave cores: 1: 1200 2: 1200
3: 1200 4: 1200 5: 1200 6: 1198 7: 1200 8: 1198 9: 1200 10: 1200 11: 1200
12: 1200 13: 1200 14: 1200 15: 1200 16: 1200 bogomips: 102213
link-max: gen: 4 speed: 16 GT/s ports: active: HDMI-A-1 off: eDP-1
empty: none bus-ID: 05:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 33.0 C
compositor: kwin_x11 driver: X: loaded: modesetting dri: radeonsi
Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 507x317mm (19.96x12.48")
s-diag: 598mm (23.54")
Monitor-1: HDMI-A-1 mapped: HDMI-1 model: Acer B246WL serial: <filter>
built: 2020 res: 1920x1200 hz: 60 dpi: 94 gamma: 1.2
size: 518x324mm (20.39x12.76") diag: 611mm (24.1") ratio: 16:10 modes:
max: 1920x1200 min: 720x400
Monitor-2: eDP-1 note: disabled pos: primary model: AU Optronics 0x8294
built: 2020 res: 1920x1200 dpi: 128 gamma: 1.2 size: 382x215mm (15.04x8.46")
diag: 438mm (17.3") ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 Mesa 22.3.6 renderer: AMD Radeon Graphics (renoir LLVM
15.0.7 DRM 3.49 6.1.12-zen1-1-zen) direct-render: Yes
Device-1: AMD Renoir Radeon High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 3-2.4:6 pcie: chip-ID: 0c76:1620
class-ID: 0300 gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 05:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: ASUSTeK
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.5
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3
Device-4: JMTek LLC. USB PnP Audio Device type: USB
Sound API: ALSA v: k6.1.12-zen1-1-zen running: yes
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-4:5
chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 4.98 TiB used: 2.16 TiB (43.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFM512GD3JX013N
lanes: 4 type: SSD serial: <filter> rev: 41000C20 temp: 29.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Western Digital
model: WDS480G2G0A-00JH30 size: 447.13 GiB block-size: physical: 512 B
logical: 512 B type: SSD serial: <filter> scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: Western Digital
model: WDS480G2G0A-00JH30 size: 447.14 GiB block-size: physical: 512 B
ID-4: /dev/sdc maj-min: 8:32 type: USB vendor: Western Digital
model: WD40NDZW-11A8JS1 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B type: HDD rpm: 5400 serial: <filter> rev: 4008 scheme: GPT
ID-1: / raw-size: 430.27 GiB size: 430.27 GiB (100.00%)
used: 137.04 GiB (31.9%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-ccf6a087-7f6c-4357-9cb5-8bf35bb72a1d
used: 752 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 430.27 GiB size: 430.27 GiB (100.00%)
ID-4: /var/log raw-size: 430.27 GiB size: 430.27 GiB (100.00%)
ID-5: /var/tmp raw-size: 430.27 GiB size: 430.27 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.05 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 16.56 GiB used: 0 KiB (0.0%)
mapped: luks-253338ee-7144-43f5-bc83-a762863e12f3
System Temperatures: cpu: 34.5 C mobo: N/A gpu: amdgpu temp: 34.0 C
Fan Speeds (RPM): cpu: 0
Processes: 415 Uptime: 3h 46m wakeups: 11 Memory: 15.05 GiB
used: 4.76 GiB (31.6%) Init: systemd v: 253 default: graphical
pkgs: 2204 libs: 568 tools: octopi,pamac,paru Shell: fish v: 3.6.0
default: Bash v: 5.1.16 running-in: yakuake inxi: 3.3.25
Garuda (2.6.15-1):
System install date:     2022-10-03
Last full system update: 2023-02-28 ↻
Windows dual boot:       Yes
What Theme did you try instead of Dr460nized?
Did that guy explain why he points at the theme for this issue? It's easy for someone to point at something without explaining why...
EDIT: Ok I saw your post, I'm late. loll Still can't see the picture you posted so that doesn't help me for now, I'll wait tonight before I check again. I don't understand what he says "is off" in the gui, maybe after seeing your screenshot I will.
There was nothing close to such feature (renaming files) worked on about the Dr460nized theme.
I'll try to reproduce this, I cannot see your image (blocked from my work machine), if I don't understand the exact steps you perform to get this issue I'll get back and ask.
Ok now I see your picture. So easy to reproduce then...
I am getting the same behavior.
Note something important here.
At number 98 you see the "+" is still available:
At number 99, the "+" becomes greyed out:
Something is blocking to get more than 99.
This is not controlled by Dr460nized Theme.
You could open a "bug" or wishlist at bugs.kde.org. Or perform deeper search on internet to see if you can find anything about this feature.
If you are absolutely certain this was available before 5.27, then that change may be hidden somewhere in the 5.27 Change Log.
I did open it. I guess it got resolved today.
https://bugs.kde.org/show_bug.cgi?id=466636
Man that's awesome!
That's what we like, when everyone contributes like you did. It's not that difficult. :smiley:
Do you realize you just made KDE better? :smiley:
I like that guy's comment:
"Not setting a maximum makes it default to 99, which is not what we want.
Instead, set it to a billion, which should be enough for everyone"
Yeah it's a candidate for the Share Funny Things thread.
And you even anticipated another KDE user who entered the same bug as yours.
But your bug report was much better than the duplicate!
Good old school from our forum? :rofl::crazy_face:
The application to file the bug report was all pre-made. IDK why the other guy decided to write a paragraph instead.
People don't necessarily read the procedure to follow for opening a help request. We see that... elsewhere too!
Does it require two users to report a bug in order for it to be given a thought/priority?
Absolutely not. It depends on multiple factors.
instead of using dolphin to rename your files, you could try krename. It does the same things, but with much more control. I think it can go over 100.
I did had to use that in the mean time.
So did dolphin, but it stopped going over 99. It was a bug that I reported.
