Serious performance issues in spite of decent specs
Kernel: 6.10.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=188b6d2a-8511-40b0-8f75-e421c65f4e21 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.1.4 tk: Qt v: N/A info: frameworks v: 6.5.0
Type: Desktop Mobo: ASUSTeK model: PRIME X470-PRO v: Rev X.0x
UEFI: American Megatrends v: 5204 date: 07/29/2019
Info: model: AMD Ryzen 7 2700X bits: 64 type: MT MCP arch: Zen+ gen: 2
model-id: 8 stepping: 2 microcode: 0x800820D
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 3499 high: 4042 min/max: 2200/3700 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3700 2: 3700
3: 3700 4: 2582 5: 3019 6: 4042 7: 3700 8: 3700 9: 2402 10: 3700 11: 2646
12: 3700 13: 3700 14: 3700 15: 3960 16: 4042 bogomips: 118162
Device-1: NVIDIA TU104 [GeForce RTX 2070 SUPER] vendor: Gigabyte
driver: nvidia v: 560.35.03 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-06; EOL~2026-12-xx) arch: Turing code: TUxxx
lanes: 16 ports: active: none off: DP-1,HDMI-A-1 empty: DP-2,DP-3
bus-ID: 09:00.0 chip-ID: 10de:1e84 class-ID: 0300
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
Screen-1: 0 s-res: 3840x1080 s-dpi: 93 s-size: 1049x292mm (41.30x11.50")
s-diag: 1089mm (42.87")
Monitor-1: DP-1 note: disabled pos: primary,left model: BenQ GL2580
serial: <filter> built: 2018 res: 1920x1080 hz: 60 dpi: 90 gamma: 1.2
size: 544x303mm (21.42x11.93") diag: 623mm (24.5") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
Monitor-2: HDMI-A-1 mapped: HDMI-0 note: disabled pos: right
model: ELEFW2417M serial: <filter> built: 2017 res: 1920x1080 hz: 60 dpi: 94
gamma: 1.2 size: 521x294mm (20.51x11.57") diag: 598mm (23.6") ratio: 16:9
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 560.35.03
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 2070
SUPER/PCIe/SSE2 memory: 7.81 GiB
API: Vulkan v: 1.3.279 layers: 5 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 2070 SUPER driver: nvidia v: 560.35.03 device-ID: 10de:1e84
surfaces: xcb,xlib
Device-1: NVIDIA TU104 HD Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 09:00.1
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0b:00.3
Device-3: Logitech Yeti Nano driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 7-1.1:4
chip-ID: 046d:0ab1 class-ID: 0300 serial: <filter>
API: ALSA v: k6.10.6-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.3 status: active with: 1: pipewire-pulse
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 07:00.0
Local Storage: total: 1.84 TiB used: 104.81 GiB (5.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 EVO 1TB
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 126 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 0B2QKXJ7 temp: 35.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: SanDisk model: SDSSDH3 1T02
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 1000 scheme: GPT
used: 104.81 GiB (11.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
System Temperatures: cpu: 60.0 C mobo: 30.0 C gpu: nvidia temp: 41 C
Fan Speeds (rpm): cpu: 2922 case-1: 0 case-2: 0 case-3: 0 gpu: nvidia
fan: 0%
Power: 12v: 12.03 5v: N/A 3.3v: N/A vbat: N/A
Memory: total: 16 GiB available: 15.53 GiB used: 4.46 GiB (28.7%)
Processes: 390 Power: uptime: 6m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.16 GiB services: org_kde_powerdevil,
Packages: 1676 pm: pacman pkgs: 1668 libs: 520 tools: octopi,pamac,paru
pm: flatpak pkgs: 8 Compilers: gcc: 14.2.1 Shell: garuda-inxi default: Bash
v: 5.2.32 running-in: konsole inxi: 3.3.35
System install date:     2024-08-30
Last full system update: 2024-09-03
Relevant software:       snapper(custom) NetworkManager dracut nvidia-dkms
Hi there. I’d like to preface by saying I’ve been really enjoying using Garuda and trying to learn Linux through it, but this issue has been preventing me from considering staying on it unless I can fix it (it could be quite simple). I’ve tested two games, Minecraft with Optifine and Sildur’s Shaders, as well as CS2. In both of these games I’ve had serious performance issues. For reference, as you can see above, I’m running a RTX 2070 Super and a Ryzen 7 2700x. In both of these games on Windows 11 I can get upwards of 70-100 fps (@1080p High to Ultra settings), whereas on Garuda, I’m getting drops into the 30s and 40s. Since this is a problem across both games, I assumed it was something with my drivers (rather than the games configs), so I tried reinstalling the proprietary nvidia drivers through the terminal but to no avail performance wise. I restarted multiple times and still have been encountering these issues. (I also switched from Wayland to KDE and have been on it since). If anyone could suggest some alternative solutions to reinstalling the drivers or what have you, then I’d be glad to attempt them. Maybe it’s something really simple I’m overlooking, but I’m not sure in all honesty what to do. I would really appreciate the community’s support. Thanks.
Have you tried with an x11 session instead of wayland in the login screen?
Something is pretty odd here… if you were truly up to date you would be running linux-zen 6.10.7.zen1-1 that was updated August 30th. :thinking:
I would try updating again with garuda-update to see if you can get the latest kernel. The last couple point releases before 6.10.7 had some serious issues.
They seem to be in one?
You’re right @Kayo. I went too quickly to an easy common cause of issues.
Sorry!
Thank you for your response. I have done a full update and restarted my system. For reference, here’s the inxi now:
Kernel: 6.10.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
Speed (MHz): avg: 3658 high: 4012 min/max: 2200/3700 boost: enabled
3: 3700 4: 3700 5: 3700 6: 3700 7: 2724 8: 4012 9: 3700 10: 3700 11: 3700
12: 3700 13: 3700 14: 3700 15: 3700 16: 3700 bogomips: 118166
surfaces: xcb,xlib
API: ALSA v: k6.10.7-zen1-1-zen status: kernel-api with: aoss
Local Storage: total: 1.84 TiB used: 109.93 GiB (5.8%)
lanes: 4 tech: SSD serial: <filter> fw-rev: 0B2QKXJ7 temp: 38.9 C
used: 109.93 GiB (11.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
System Temperatures: cpu: 63.2 C mobo: 33.0 C gpu: nvidia temp: 48 C
Fan Speeds (rpm): cpu: 0 case-1: 0 case-2: 0 case-3: 0 gpu: nvidia fan: 0%
Power: 12v: 11.97 5v: N/A 3.3v: N/A vbat: N/A
Memory: total: 16 GiB available: 15.53 GiB used: 5.53 GiB (35.6%)
Processes: 427 Power: uptime: 3m states: freeze,mem,disk suspend: deep
Last full system update: 2024-09-04
After doing some basic testing, unfortunately, the problem still persists, despite my update to the newest kernel (6.10.7). Any other suggestions?
might want to try downgrading the driver 1 or 2 versions as ive heard some stories about both 555 an 560.
Always best to remember nvidia drivers are a rollercoaster some are good some are bad. An its random so you can just never know.
How would I go about doing that?
isn’t it just downgrade nvidia--dkms nvidia-utils lib32-nvidia-utils though I may be wrong.
