Please laugh at me and I have no idea how but it appears to no longer be a repository I can download from. I don't really want to reinstall the os so I am requesting aid.
Pamac does not list the aur, and octopi only lists previously installed packages from it.
Kernel: 6.4.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=8f73c2ee-4399-4af0-be0f-e16f37bffd55 rw rootflags=subvol=@
radeon.si_support=0 amdgpu.si_support=1 radeon.cik_support=0
amdgpu.cik_support=1 quiet quiet rd.udev.log_priority=3
vt.global_cursor_default=0
resume=UUID=f90b7653-d3f7-47fd-9dc1-b22866e431b1 loglevel=3 ibt=off
Desktop: i3 v: 4.22 info: i3bar vt: 7 dm: LightDM v: 1.32.0
Type: Desktop System: Gigabyte product: B450M DS3H WIFI v: -CF
Mobo: Gigabyte model: B450M DS3H WIFI-CF v: x.x
serial: <superuser required> BIOS: American Megatrends LLC. v: F64
date: 11/07/2022
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3598 high: 3600 min/max: 2200/4208 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3590 2: 3600
3: 3600 4: 3600 5: 3600 6: 3600 7: 3600 8: 3600 9: 3592 10: 3594 11: 3600
12: 3600 bogomips: 86237
Device-1: AMD Hawaii PRO [Radeon R9 290/390] vendor: Micro-Star MSI
driver: amdgpu v: kernel alternate: radeon arch: GCN-2 code: Sea Islands
process: GF/TSMC 16-28nm built: 2013-17 pcie: gen: 3 speed: 8 GT/s
lanes: 4 link-max: lanes: 16 ports: active: DP-1,DVI-D-1
empty: DVI-D-2,HDMI-A-1 bus-ID: 0a:00.0 chip-ID: 1002:67b1 class-ID: 0300
temp: 61.0 C
compositor: Picom v: git-b700a driver: X: loaded: amdgpu
unloaded: modesetting alternate: fbdev,vesa dri: radeonsi gpu: amdgpu
Screen-1: 0 s-res: 3600x1080 s-dpi: 96 s-size: 952x285mm (37.48x11.22")
s-diag: 994mm (39.12")
Monitor-1: DVI-D-1 mapped: DVI-D-0 pos: left model: Apple Cinema
serial: <filter> built: 2007 res: 1680x1050 hz: 60 dpi: 99 gamma: 1.2
size: 433x270mm (17.05x10.63") diag: 510mm (20.1") ratio: 16:10 modes:
max: 1680x1050 min: 640x480
Monitor-2: DP-1 mapped: DisplayPort-0 pos: primary,right
model: ASUS VG24VQ1B serial: <filter> built: 2021 res: 1920x1080 dpi: 93
gamma: 1.2 size: 527x296mm (20.75x11.65") diag: 604mm (23.8") ratio: 16:9
API: OpenGL v: 4.6 Mesa 23.1.6-arch1.4 renderer: AMD Radeon R9 390 Series
(hawaii LLVM 16.0.6 DRM 3.52 6.4.12-zen1-1-zen) direct-render: Yes
Device-1: AMD Hawaii HDMI Audio [Radeon R9 290/290X / 390/390X]
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 4 link-max: lanes: 16 bus-ID: 0a:00.1
chip-ID: 1002:aac8 class-ID: 0403
Device-3: Razer USA Kraken Kitty Edition
lanes: 1 mode: 1.1 bus-ID: 1-1.3:6 chip-ID: 1532:0521 class-ID: 0300
API: ALSA v: k6.4.12-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.79 status: active with: 1: pipewire-pulse
lanes: 1 port: e000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
vendor: AzureWave driver: rtw_8821ce v: N/A modules: rtw88_8821ce pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 07:00.0
IF: wlp7s0 state: down mac: <filter>
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:5 chip-ID: 13d3:3533
lmp-v: 8 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 1.83 TiB used: 258.26 GiB (13.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT500P3SSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR30A temp: 37.9 C
scheme: MBR
ID-2: /dev/sda maj-min: 8:0 vendor: SanDisk model: SDSSDH3 1T00
tech: SSD serial: <filter> fw-rev: 20RL scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: TeamGroup model: T253512GB
tech: SSD serial: <filter> fw-rev: 61.5 scheme: MBR
ID-1: / raw-size: 448.67 GiB size: 448.67 GiB (100.00%)
used: 258.26 GiB (57.6%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
ID-2: /home raw-size: 448.67 GiB size: 448.67 GiB (100.00%)
ID-3: /var/log raw-size: 448.67 GiB size: 448.67 GiB (100.00%)
ID-4: /var/tmp raw-size: 448.67 GiB size: 448.67 GiB (100.00%)
ID-2: swap-2 type: partition size: 17.09 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 45.0 C mobo: 40.0 C gpu: amdgpu temp: 61.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 860
Processes: 334 Uptime: 20m wakeups: 0 Memory: total: 16 GiB
available: 15.54 GiB used: 3.72 GiB (24.0%) Init: systemd v: 254
Packages: 2328 pm: pacman pkgs: 2318 libs: 535 tools: octopi,pamac,paru
pm: flatpak pkgs: 10 Shell: Bash v: 5.1.16 running-in: kitty inxi: 3.3.29
System install date: 2023-08-08
Last full system update: 2023-09-05
Is partially upgraded: Yes
