Semi-constant screen flickering
I assume it’s some sort of driver issue, I still have Windows on my m.2 SSD, I booted into that, played Doom through GZDoom, browsed the internet a little and had no screen flickering issues. I updated the system, reboot, tried both X11 and Wayland, screen flickering with either.
Not too long ago I was getting a weird screen flickering issues while playing video games using X11, now I’m getting it all the time with either display method.
Kernel: 6.10.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=7b56fc96-0e19-473d-badd-73a065550c34 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.1.3 tk: Qt v: N/A info: frameworks v: 6.4.0
Type: Desktop Mobo: Micro-Star model: MPG B550 GAMING EDGE WIFI (MS-7C91)
v: 1.0 serial: <superuser required> uuid: <superuser required> UEFI: American
Megatrends LLC. v: 1.80 date: 12/15/2021
Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3674 high: 3700 min/max: 2200/4650 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3700 2: 3700
3: 3600 4: 3700 5: 3700 6: 3700 7: 3599 8: 3700 9: 3700 10: 3700 11: 3700
12: 3596 bogomips: 88798
vendor: Tul / PowerColor Red Devil driver: amdgpu v: kernel arch: RDNA-2
speed: 16 GT/s lanes: 16 ports: active: DP-2 empty: DP-1, DP-3, HDMI-A-1,
Writeback-1 bus-ID: 2d:00.0 chip-ID: 1002:73df class-ID: 0300
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.1
s-diag: 777mm (30.58")
Monitor-1: DP-2 mapped: DisplayPort-1 model: ASUS VG32VQR serial: <filter>
built: 2021 res: 2560x1440 hz: 165 dpi: 93 gamma: 1.2
size: 697x393mm (27.44x15.47") diag: 800mm (31.5") ratio: 16:9 modes:
max: 2560x1440 min: 720x400
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.4-arch1.2
navi22 LLVM 18.1.8 DRM 3.57 6.10.1-zen1-1-zen) device-ID: 1002:73df
memory: 11.72 GiB unified: no
API: Vulkan v: 1.3.279 layers: 13 device: 0 type: discrete-gpu name: AMD
Radeon RX 6700 XT (RADV NAVI22) driver: mesa radv v: 24.1.4-arch1.2
device-ID: 1002:73df surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 18.1.8 256 bits) driver: mesa llvmpipe v: 24.1.4-arch1.2 (LLVM
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 2d:00.1 chip-ID: 1002:ab28
bus-ID: 2f:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.10.1-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.1 status: active with: 1: pipewire-pulse
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 29:00.0
Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 2a:00.0
IF: enp42s0 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:6 chip-ID: 8087:0032
Local Storage: total: 14.81 TiB used: 4.14 TiB (28.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN530
SDBPNPZ-256G-1006 size: 238.47 GiB block-size: physical: 512 B
fw-rev: HPS2 temp: 37.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST14000NM001G-2KJ103
size: 12.73 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: SN02 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 870 EVO 2TB
ID-4: /dev/sdc maj-min: 8:32 vendor: SanDisk model: Ultra size: 28.64 GiB
block-size: physical: 512 B logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s
lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter> fw-rev: 1.00
scheme: MBR
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 797.56 GiB (42.8%)
fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 584 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
used: 797.56 GiB (42.8%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
System Temperatures: cpu: 58.0 C mobo: N/A gpu: amdgpu temp: 47.0 C
mem: 46.0 C
Memory: total: 16 GiB available: 15.54 GiB used: 2.54 GiB (16.3%)
Processes: 360 Power: uptime: 1m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.21 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2050 libs: 588 tools: octopi,paru,yay
Compilers: clang: 18.1.8 gcc: 14.1.1 Shell: garuda-inxi default: fish
v: 3.7.1 running-in: konsole inxi: 3.3.35
System install date:     2023-12-16
Last full system update: 2024-07-28
Update, when I have the refresh rate to 165 hz (native) there is flickering, when I change it to 144 hz, no flickering. Anyone have idea on what’s causing this?
Just a guess but a lot of monitors in windows overdrive to 165mhz with drivers but are 144mhz native
just use 144 hz :slight_smile:
Recent kernel issue with amdgpu. It should be fixed in a later update:
https://bugzilla.kernel.org/show_bug.cgi?id=219091
Edit:
The fix should be in kernel 6.10.3 when that becomes available:
https://bbs.archlinux.org/viewtopic.php?id=298198
Related thread:
as far as I know, the monitor is truly 165 hz, I’ve been using it on the highest hz on garuda in the past.
Yep, that’s what I have to do (for now) it seems.
Thank you everyone for help!!!
I’ve been experiencing the same issue. One thing I’ve found that seems to fix it is to go into CoreControl and bump the minimum GPU frequency up 100mhz or so.
For me, the flickering becomes a smaller and smaller portion of the screen for every 10 mhz bump. Even at a 200mhz increase the GPU temps don’t go up and the fans don’t turn on. After that I can reset CoreCtrl to the default value and the flicker stays gone (until the PC goes to sleep or restarts anyway).
Uncheck this option:
Screen Tearing: Allow in fullscreen windows
This solved everything on my end, even at 165hz.
