I Installed Garuda Drangonized Blackarch KDE yesterday and it's not picking my Manjaro install and adding it to the Grub menu for Garuda, nor when I'm in Manjaro does Manjaro add Garuda to Manjaro's Grub menu. I have done "sudo update-grub in both OS's and neither will add the second OS to their Grub menu. What am I missing?
╭─locutus@Borg in ~
╰─λ inxi -Faz
System: Kernel: 5.15.7-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=eca0fa90-c671-48bf-8727-e2f8928f8012
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM Distro: Garuda Linux
Machine: Type: Desktop System: ASUS product: N/A v: N/A serial: <superuser required>
Mobo: ASUSTeK model: ROG STRIX B550-F GAMING v: Rev X.0x serial: <superuser required>
UEFI: American Megatrends v: 2423 date: 08/10/2021
Battery: Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M325 serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: Discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Keyboard K360 serial: <filter>
CPU: Info: 6-Core model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2 family: 17 (23)
model-id: 71 (113) stepping: 0 microcode: 8701021 cache: L1: 384 KiB L2: 3 MiB L3: 32 MiB
flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 86244
Speed: 3468 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz): 1: 3468 2: 3896
3: 2104 4: 2127 5: 2054 6: 3031 7: 2125 8: 2120 9: 3503 10: 3776 11: 2090 12: 2316
mitigation: Full AMD retpoline, IBPB: conditional, STIBP: conditional, RSB filling
Graphics: Device-1: NVIDIA TU116 [GeForce GTX 1650 SUPER] vendor: eVga.com. driver: nvidia v: 495.44
alternate: nouveau,nvidia_drm bus-ID: 08:00.0 chip-ID: 10de:2187 class-ID: 0300
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver: loaded: nvidia
unloaded: modesetting alternate: fbdev,nouveau,nv,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1080 s-dpi: 97 s-size: 670x283mm (26.4x11.1") s-diag: 727mm (28.6")
Monitor-1: HDMI-0 res: 2560x1080 hz: 60 dpi: 97 size: 673x284mm (26.5x11.2")
diag: 730mm (28.8")
Audio: Device-1: NVIDIA TU116 High Definition Audio vendor: eVga.com. driver: snd_hda_intel v: kernel
bus-ID: 08:00.1 chip-ID: 10de:1aeb class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 0a:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound Server-1: ALSA v: k5.15.7-zen1-1-zen running: yes
Network: Device-1: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel port: N/A bus-ID: 07:00.0
Drives: Local Storage: total: 20.82 TiB used: 5.78 TiB (27.8%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Seagate model: XPG GAMMIX S11 Pro size: 476.94 GiB
rev: 32B3T8EB temp: 31.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Patriot model: Viper M.2 VPN100 size: 238.47 GiB
rev: ECFM22.6 temp: 30.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 type: USB vendor: Seagate model: Expansion HDD size: 7.28 TiB
block-size: physical: 4096 B logical: 512 B type: N/A serial: <filter> rev: 1801 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 type: USB vendor: Seagate model: ST8000AS0002-1NA17Z
size: 7.28 TiB block-size: physical: 4096 B logical: 512 B type: HDD rpm: 5980 serial: <filter>
ID-5: /dev/sdc maj-min: 8:32 type: USB vendor: Seagate model: ST330006 51NS size: 2.73 TiB
block-size: physical: 4096 B logical: 512 B type: N/A serial: <filter> rev: 7101 scheme: GPT
ID-6: /dev/sdd maj-min: 8:48 type: USB vendor: Seagate model: ST3000DM 001-1E6166
size: 2.73 TiB block-size: physical: 4096 B logical: 512 B type: N/A serial: <filter> rev: 7101
ID-7: /dev/sde maj-min: 8:64 type: USB vendor: PNY model: USB 3.0 FD size: 115.38 GiB
block-size: physical: 512 B logical: 512 B type: N/A serial: <filter> rev: PMAP scheme: MBR
Partition: ID-1: / raw-size: 238.17 GiB size: 238.17 GiB (100.00%) used: 33.76 GiB (14.2%) fs: btrfs
dev: /dev/nvme1n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 576 KiB (0.2%) fs: vfat
dev: /dev/nvme1n1p1 maj-min: 259:1
ID-3: /home raw-size: 238.17 GiB size: 238.17 GiB (100.00%) used: 33.76 GiB (14.2%) fs: btrfs
ID-4: /var/log raw-size: 238.17 GiB size: 238.17 GiB (100.00%) used: 33.76 GiB (14.2%)
ID-5: /var/tmp raw-size: 238.17 GiB size: 238.17 GiB (100.00%) used: 33.76 GiB (14.2%)
ID-1: swap-1 type: zram size: 31.32 GiB used: 4 MiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: Message: No sensor data found. Is lm-sensors configured?
Info: Processes: 452 Uptime: 6h 20m wakeups: 58 Memory: 31.32 GiB used: 11.42 GiB (36.5%)
Init: systemd v: 249 tool: systemctl Compilers: gcc: 11.1.0 Packages: 2217 pacman: 2190
lib: 445 flatpak: 20 snap: 7 Shell: fish v: 3.3.1 default: Bash v: 5.1.12 running-in: konsole
inxi: 3.3.09
# GRUB boot loader configuration
GRUB_DEFAULT=0
GRUB_TIMEOUT=30
GRUB_DISTRIBUTOR="Garuda"
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0 systemd.unified_cgroup_hierarchy=1 loglevel=3"
GRUB_CMDLINE_LINUX=""
# Preload both GPT and MBR modules so that they are not missed
GRUB_PRELOAD_MODULES="part_gpt part_msdos"
# Uncomment to enable booting from LUKS encrypted devices
#GRUB_ENABLE_CRYPTODISK=y
# Set to 'countdown' or 'hidden' to change timeout behavior,
# press ESC key to display menu.
GRUB_TIMEOUT_STYLE=menu
# Uncomment to use basic console
GRUB_TERMINAL_INPUT=console
# Uncomment to disable graphical terminal
#GRUB_TERMINAL_OUTPUT=console
# The resolution used on graphical terminal
# note that you can use only modes which your graphic card supports via VBE
# you can see them in real GRUB with the command `vbeinfo'
GRUB_GFXMODE=auto
# Uncomment to allow the kernel use the same resolution used by grub
GRUB_GFXPAYLOAD_LINUX=keep
# Uncomment if you want GRUB to pass to the Linux kernel the old parameter
# format "root=/dev/xxx" instead of "root=/dev/disk/by-uuid/xxx"
#GRUB_DISABLE_LINUX_UUID=true
# Uncomment to disable generation of recovery mode menu entries
GRUB_DISABLE_RECOVERY=true
# Uncomment and set to the desired menu colors. Used by normal and wallpaper
# modes only. Entries specified as foreground/background.
#GRUB_COLOR_NORMAL="light-blue/black"
#GRUB_COLOR_HIGHLIGHT="light-cyan/blue"
# Uncomment one of them for the gfx desired, a image background or a gfxtheme
#GRUB_BACKGROUND="/path/to/wallpaper"
GRUB_THEME="/usr/share/grub/themes/garuda-dr460nized/theme.txt"
# Uncomment to get a beep at GRUB start
#GRUB_INIT_TUNE="480 440 1"
# Uncomment to make GRUB remember the last selection. This requires
# setting 'GRUB_DEFAULT=saved' above.
#GRUB_SAVEDEFAULT=true
# Uncomment to disable submenus in boot menu
#GRUB_DISABLE_SUBMENU=y
GRUB_DISABLE_OS_PROBER=false
