Hello.
I have installed Wayland-session on my laptop. If laptop is not connect to a secondary monitor (HDMI) It works fine. Right resolution laptop screen. When I connect laptop to the secondary monitor, laptop monitor turns off and secondary monitor turns on. But it works at a wrong resolution (the screen is greater than monitor). Also mouse doesn't work fine. (No rigth focus)
When I use X11 session it works fine.
I use a KDE-wayland-session.
Any suggest?
I have used this command:
pacman -S plasma-wayland-session
inxi -System: Kernel: 5.15.6-zen2-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=e1b87af6-67e0-4350-97cb-8bdfe430d209 rw
rootflags=subvol=@ quiet
cryptdevice=UUID=735c2a29-e901-4fc7-893a-52a88bf43878:luks-735c2a29-e901-4fc7-893a-52a88bf43878
root=/dev/mapper/luks-735c2a29-e901-4fc7-893a-52a88bf43878 splash rd.udev.log_priority=3 vt.global_cursor_default=0
systemd.unified_cgroup_hierarchy=1 resume=/dev/mapper/luks-23c04b79-4698-461f-ade3-f485919f86ca loglevel=3
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM Distro: Garuda Linux
Machine: Type: Laptop System: FUJITSU product: LIFEBOOK A544 v: N/A serial: <superuser required> Chassis: type: 10
Mobo: FUJITSU model: FJNBB35 serial: <superuser required> UEFI: FUJITSU // Phoenix v: Version 1.13 date: 11/18/2013
Battery: ID-1: BAT0 charge: 0.9 Wh (90.0%) condition: 1.0/4.5 Wh (22.7%) volts: 12.5 min: 10.8 model: PTL CP651527-01
type: Li-ion serial: <filter> status: Charging cycles: 274
CPU: Info: Quad Core model: Intel Core i7-4702MQ bits: 64 type: MT MCP arch: Haswell family: 6 model-id: 3C (60)
stepping: 3 microcode: 28 cache: L1: 256 KiB L2: 1024 KiB L3: 6 MiB
flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 35116
Speed: 2195 MHz min/max: 800/2200 MHz Core speeds (MHz): 1: 2188 2: 2195 3: 2195 4: 2195 5: 2195 6: 2195 7: 2189
8: 2195
Graphics: Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: Fujitsu Limited. driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:0416 class-ID: 0300
Device-2: Importek FJ Camera type: USB driver: uvcvideo bus-ID: 1-7:5 chip-ID: 10f1:1a58 class-ID: 0e02
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver: loaded: intel unloaded: modesetting
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 507x285mm (20.0x11.2") s-diag: 582mm (22.9")
Monitor-1: HDMI1 res: 1920x1080 hz: 60 dpi: 102 size: 480x270mm (18.9x10.6") diag: 551mm (21.7")
Audio: Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio vendor: Fujitsu Limited. driver: snd_hda_intel
v: kernel bus-ID: 00:03.0 chip-ID: 8086:0c0c class-ID: 0403
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Fujitsu Limited. driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0 chip-ID: 8086:8c20 class-ID: 0403
Sound Server-1: ALSA v: k5.15.6-zen2-1-zen running: yes
Network: Device-1: Intel Wireless 7260 driver: iwlwifi v: kernel bus-ID: 03:00.0 chip-ID: 8086:08b1 class-ID: 0280
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Fujitsu Limited. driver: r8169 v: kernel
port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF-ID-2: virbr1 state: down mac: <filter>
Bluetooth: Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8 bus-ID: 1-8:7 chip-ID: 8087:07dc
Report: bt-adapter ID: hci0 rfk-id: 0 state: down bt-service: enabled,running rfk-block: hardware: no software: no
address: <filter>
Drives: Local Storage: total: 931.51 GiB used: 57.02 GiB (6.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 1TB size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 1B6Q scheme: GPT
Partition: ID-1: / raw-size: 922.45 GiB size: 922.45 GiB (100.00%) used: 57.02 GiB (6.2%) fs: btrfs dev: /dev/dm-0
maj-min: 254:0 mapped: luks-735c2a29-e901-4fc7-893a-52a88bf43878
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.45%) used: 682 KiB (0.3%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 922.45 GiB size: 922.45 GiB (100.00%) used: 57.02 GiB (6.2%) fs: btrfs dev: /dev/dm-0
ID-4: /var/log raw-size: 922.45 GiB size: 922.45 GiB (100.00%) used: 57.02 GiB (6.2%) fs: btrfs dev: /dev/dm-0
ID-5: /var/tmp raw-size: 922.45 GiB size: 922.45 GiB (100.00%) used: 57.02 GiB (6.2%) fs: btrfs dev: /dev/dm-0
ID-1: swap-1 type: zram size: 7.67 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
ID-2: swap-2 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/dm-1 maj-min: 254:1
mapped: luks-23c04b79-4698-461f-ade3-f485919f86ca
Sensors: System Temperatures: cpu: 58.0 C pch: 56.5 C mobo: 27.8 C
Info: Processes: 294 Uptime: 30m wakeups: 139 Memory: 7.67 GiB used: 2.8 GiB (36.6%) Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1643 lib: 379 Shell: fish v: 3.3.1 running-in: konsole
inxi: 3.3.09
