Hello , as title says , i got troubles using my second screen , please can you help having it setup ?
╰─λ garuda-inxi
Kernel: 6.15.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=4a1fc13b-9cd2-4f1c-96aa-b983a3f800d1 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.4.0 tk: Qt v: N/A info: frameworks v: 6.15.0
Mobo: ASUSTeK model: TUF GAMING B760M-PLUS II v: Rev 1.xx
UEFI: American Megatrends v: 1820 date: 05/15/2025
Info: model: 12th Gen Intel Core i7-12700KF bits: 64 type: MST AMCP
microcode: 0x3A
Topology: cpus: 1x dies: 1 clusters: 9 cores: 12 threads: 20 mt: 8 tpc: 2
st: 4 smt: enabled cache: L1: 1024 KiB desc: d-4x32 KiB, 8x48 KiB; i-8x32
KiB, 4x64 KiB L2: 12 MiB desc: 8x1.2 MiB, 1x2 MiB L3: 25 MiB
desc: 1x25 MiB
Speed (MHz): avg: 800 min/max: 800/4900:5000:3800 scaling:
5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800
15: 800 16: 800 17: 800 18: 800 19: 800 20: 800 bogomips: 144383
Device-1: NVIDIA GB203 [GeForce RTX 5070 Ti] vendor: CardExpert
driver: nvidia v: 575.64 alternate: nouveau,nvidia_drm non-free: N/A
status: unknown device ID pcie: gen: 5 speed: 32 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:2c05 class-ID: 0300
alternate: fbdev,nouveau,nv,vesa gpu: nvidia display-ID: 0
Monitor-1: Unknown-1 res: mode: 2560x1440 hz: 60 scale: 100% (1) dpi: 96
size: 677x381mm (26.65x15") diag: 777mm (30.58") modes: 2560x1440
API: EGL v: 1.5 platforms: device: 0 drv: swrast surfaceless: drv: swrast
wayland: drv: swrast x11: drv: swrast inactive: gbm
API: OpenGL v: 4.5 vendor: mesa v: 25.1.4-arch1.1 glx-v: 1.4
direct-render: yes renderer: llvmpipe (LLVM 20.1.6 256 bits)
device-ID: ffffffff:ffffffff memory: 30.4 GiB unified: yes
display-ID: :1.0
Device-1: Intel Raptor Lake High Definition Audio vendor: ASUSTeK
Device-2: NVIDIA driver: snd_hda_intel v: kernel pcie: gen: 5
speed: 32 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:22e9 class-ID: 0403
Device-3: Corsair HS80 RGB USB Gaming Headset
lanes: 1 mode: 1.1 bus-ID: 1-1.4.3:8 chip-ID: 1b1c:0a88 class-ID: 0300
API: ALSA v: k6.15.2-zen1-1-zen status: kernel-api with: aoss
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 4000 bus-ID: 05:00.0
IF: eno1 state: up speed: 2500 Mbps duplex: full mac: <filter>
v: 0.6 port: N/A bus-ID: 00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 2.79 TiB used: 23.97 GiB (0.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 46.9 C
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: A-Data model: LEGEND 800
lanes: 4 tech: SSD serial: <filter> fw-rev: SN20800 temp: 42.9 C
ID-3: /dev/sda maj-min: 8:0 model: SG Flash size: 58.59 GiB block-size:
physical: 4096 B logical: 512 B type: USB rev: 3.2 spd: 5 Gb/s lanes: 1
mode: 3.2 gen-1x1 tech: SSD serial: <filter> fw-rev: 1.00 scheme: MBR
used: 23.97 GiB (2.6%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:6
used: 620 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:5
ID-1: swap-1 type: zram size: 31.12 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 52.5 C mobo: N/A
Memory: total: 32 GiB available: 31.13 GiB used: 5.39 GiB (17.3%)
Processes: 389 Power: uptime: 15m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.37 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1753 libs: 525 tools: octopi,paru Compilers:
clang: 20.1.6 gcc: 15.1.1 Shell: garuda-inxi default: fish v: 4.0.2
System install date: 2025-06-20
Last full system update: 2025-06-21
Main screen (this one is working here) : HDMI
Second screen : DisplayPort
