Kernel: 5.16.2-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=3bf66fc0-89ba-4f98-b6f6-81b2ff1ff168 rw rootflags=subvol=@
resume=UUID=fd7e8027-710d-411d-82b6-505a4c2b5304 loglevel=3
nvidia-drm.modeset=1
Type: Laptop System: Micro-Star product: GL62M 7REX v: REV:1.0
Mobo: Micro-Star model: MS-16J9 v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends v: E16J9IMS.31A date: 07/11/2017
ID-1: BAT1 charge: 36.0 Wh (94.5%) condition: 38.1/42.4 Wh (89.9%)
volts: 12.1 min: 10.8 model: MSI BIF0_9 type: Li-ion serial: N/A
status: N/A
Device-1: apple_mfi_fastcharge model: N/A serial: N/A charge: N/A
status: N/A
Info: model: Intel Core i5-7300HQ bits: 64 type: MCP arch: Kaby Lake
family: 6 model-id: 0x9E (158) stepping: 9 microcode: 0xEA
desc: 1x6 MiB
Speed (MHz): avg: 3188 high: 3214 min/max: 800/3500 scaling:
driver: intel_pstate governor: performance cores: 1: 3170 2: 3214 3: 3162
4: 3206 bogomips: 19999
Type: l1tf
IBRS_FW, STIBP: disabled, RSB filling
Device-1: Intel HD Graphics 630 vendor: Micro-Star MSI driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:591b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile]
vendor: Micro-Star MSI driver: nvidia v: 495.46
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1c8c
class-ID: 0302
loaded: modesetting,nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1013x285mm (39.9x11.2")
s-diag: 1052mm (41.4")
Monitor-1: eDP-1-1 res: 1920x1080 dpi: 142 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
Monitor-2: HDMI-1-2 res: 1920x1080 hz: 60 dpi: 92
size: 528x297mm (20.8x11.7") diag: 606mm (23.9")
OpenGL: renderer: NVIDIA GeForce GTX 1050 Ti/PCIe/SSE2
v: 4.6.0 NVIDIA 495.46 direct render: Yes
Device-1: Intel CM238 HD Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a171 class-ID: 0403
Sound Server-1: ALSA v: k5.16.2-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.43 running: yes
v: kernel bus-ID: 02:00.0 chip-ID: 8086:24fb class-ID: 0280
Device-2: Qualcomm Atheros QCA8171 Gigabit Ethernet
vendor: Micro-Star MSI driver: alx v: kernel port: d000 bus-ID: 03:00.0
chip-ID: 1969:10a1 class-ID: 0200
IF-ID-1: enp0s20f0u6c4i2 state: down mac: <filter>
Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-10:7 chip-ID: 8087:0aa7 class-ID: e001
Local Storage: total: 685.61 GiB used: 320.96 GiB (46.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: RBU-SNS8152S3256GG5
type: SSD serial: <filter> rev: 01.R scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT480M500SSD1
size: 447.13 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: SSD serial: <filter> rev: MU03 scheme: MBR
ID-1: / raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
used: 181.29 GiB (79.0%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
ID-4: /var/log raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
ID-5: /var/tmp raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 7.68 GiB used: 2.8 MiB (0.0%) priority: 100
System Temperatures: cpu: 59.0 C pch: 55.0 C mobo: 27.8 C gpu: nvidia
temp: 52 C
Processes: 261 Uptime: 2m wakeups: 2 Memory: 7.68 GiB
used: 3.66 GiB (47.6%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: 1921 note: see --pkg apt: 0
pacman: 1913 lib: 503 flatpak: 8 Shell: fish v: 3.3.1 running-in: konsole
inxi: 3.3.12
Garuda:
System install date: 2021-11-26
Last full system update: 2022-01-25
Using TLP: No
The automount mounts my drive to:
/run/media/[username]/[drive]
but several programs like wine have a problem with this, for example if i wanted to make a wineprefix it would throw a million errors, not related to it being on an on a separate drive but because its mounted in the weird path. Im trying to mounft in to:
/mnt/[drive]
automatically with fstab or manually but i cannot change the ownership to my user from root..
I know that NTFS does not have permission management and thats why its getting mounted as root, and cannot be changed to my user with chmod.
I need help with this, its tiring, thank you.
