Hi all,
This problem is something that has been happening for about 5 to 6 months. A couple of months ago I did a fresh installation of Garuda and it is still the same.
I am on a laptop and I have a second monitor with 3440x1440 resolution, so it is problematic to use nvidia-off-loading, since there are lags and jumps between windows movements or switching between them. So I have installed optimus-manager
to switch completely to nvidia.
Everything goes perfect, except when I have to pause, the screen goes into lock and then the second monitor just won't turn on. There are times when the laptop screen also goes completely black. To try to fix this without forcing the shutdown I have tried:
- switching to tty2 (control + alt + F2) and back to tty1, but sometimes this doesn't work either.
- Disconnecting the hdmi cable, so that it reloads the lock screen. Sometimes combining with going to tty2.
In any of the situations, in case you manage to enter again to the active session, the secondary display is still disconnected, you have to go to the nvidia utility, to the 'X Server Display Configuration' section, and change in "Resolution" from Auto to the correct resolution, in 2 attempts. This makes the monitor active again, although in "Unify Outputs" mode, so you need to go to System Preferences --> Display, to again change the way you want to use the monitor. This makes using the system really annoying, and I'm not sure how to fix it.
Attached is the result of garuda-inxi
╭─[email protected] in ~ via 📐 v4.2.2 as 🧙 took 3s
╰─λ garuda-inxi -t
Kernel: 6.1.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=e8d1681e-e709-4f84-9299-11d7b9a7f289 rw [email protected]
loglevel=3 ibt=off
Type: Laptop System: Dell product: G5 5587 v: N/A
Mobo: Dell model: 03PVDF v: A00 serial: <superuser required> UEFI: Dell
v: 1.21.0 date: 04/15/2022
ID-1: BAT0 charge: 3.9 Wh (19.2%) condition: 20.3/56.0 Wh (36.3%)
volts: 15.8 min: 15.2 model: BYD DELL 7FHHV87 type: Li-ion serial: <filter>
status: charging
Info: model: Intel Core i7-8750H bits: 64 type: MT MCP arch: Coffee Lake
L3: 9 MiB desc: 1x9 MiB
Speed (MHz): avg: 3758 high: 3902 min/max: 800/4100 scaling:
driver: intel_pstate governor: powersave cores: 1: 3900 2: 3900 3: 3900
4: 3900 5: 3900 6: 2200 7: 3900 8: 3900 9: 3900 10: 3900 11: 3900 12: 3902
bogomips: 52799
ports: active: eDP-1 empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-2, HDMI-A-3
bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] vendor: Dell
driver: nvidia v: 525.60.11 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2022-12) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: none off: HDMI-A-4 empty: none bus-ID: 01:00.0
chip-ID: 10de:1c8c class-ID: 0302
gpu: i915,nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 5360x1440 s-dpi: 110 s-size: 1239x333mm (48.78x13.11")
s-diag: 1283mm (50.51")
Monitor-1: HDMI-A-4 mapped: HDMI-0 note: disabled pos: primary,left
model: TE-7250N built: 2021 res: 3440x1440 hz: 60 dpi: 110 gamma: 1.2
size: 797x334mm (31.38x13.15") diag: 864mm (34") modes: max: 3440x1440
min: 640x480
Monitor-2: eDP-1 mapped: eDP-1-1 pos: right model: LG Display 0x05d0
built: 2018 res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2
modes: 1920x1080
API: OpenGL v: 4.6.0 NVIDIA 525.60.11 renderer: NVIDIA GeForce GTX 1050
Ti/PCIe/SSE2 direct render: Yes
v: kernel bus-ID: 3-1.4:5 chip-ID: 0bda:4937
alternate: snd_soc_skl,snd_sof_pci_intel_cnl class-ID: 0300
bus-ID: 00:1f.3 chip-ID: 8086:a348 serial: <filter> class-ID: 0403
Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel
chip-ID: 10de:0fb9 class-ID: 0403
Device-3: Realtek USB2.0 Microphone type: USB
Sound API: ALSA v: k6.1.2-zen1-1-zen running: yes
IF: wlp0s20f3 state: down mac: <filter>
Device-2: Qualcomm Atheros Killer E2400 Gigabit Ethernet vendor: Dell
driver: alx v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000
bus-ID: 3c:00.0 chip-ID: 1969:e0a1 class-ID: 0200
IF: enp60s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
driver: btusb v: 0.8 bus-ID: 1-14:3 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 1.82 TiB used: 813.29 GiB (43.7%)
rev: 2B2QEXM7 temp: 55.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
type: HDD rpm: 5400 serial: <filter> rev: SDM3 scheme: GPT
ID-1: / raw-size: 120 GiB size: 120 GiB (100.00%) used: 71.33 GiB (59.4%)
ID-2: /boot/efi raw-size: 612 MiB size: 610.8 MiB (99.80%)
used: 52.9 MiB (8.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 661.51 GiB size: 650.06 GiB (98.27%)
used: 460.68 GiB (70.9%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
ID-4: /opt raw-size: 40.04 GiB size: 40.04 GiB (100.00%)
used: 7.82 GiB (19.5%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-5: /var/log raw-size: 120 GiB size: 120 GiB (100.00%)
used: 71.33 GiB (59.4%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
ID-6: /var/tmp raw-size: 120 GiB size: 120 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.04 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 30 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p6 maj-min: 259:6
System Temperatures: cpu: 87.0 C pch: 72.0 C mobo: N/A gpu: nvidia
temp: 61 C
Processes: 355 Uptime: 14m wakeups: 5 Memory: 31.04 GiB
used: 8.88 GiB (28.6%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 alt: 11 clang: 14.0.6 Packages: 2703
pm: dpkg pkgs: 0 pm: pacman pkgs: 2693 libs: 539 tools: octopi,pamac,paru
pm: flatpak pkgs: 10 Shell: fish v: 3.5.1 running-in: konsole inxi: 3.3.24
Garuda (2.6.13-1):
System install date: 2022-10-22
Last full system update: 2023-01-04
