Second Monitor not working through USB-C hub
Hello everyone! Very new noobie here, hoping to make the full transition to Garuda Linux!
I just swapped from Windows to Garuda Cinnamon for the first time and I'm having issues using my second monitor. I'm using a 2021 Asus Zephyrus G14 with an AMD Ryzen 9 5900HS and RTX 3060. I'll paste my logs below for more system info.
Onto my issue, if I plug the HDMI cable to the built in HDMI port, the monitor turns on ok. But if I use the usb-c hub which has passthrough directly to the dGPU, then it will detect the monitor, but it will refuse to swap. I prefer to use the Hub since games will use the dGPU and the built in HDMI port uses the iGPU.
Anyone knows how to fix this? Any help is very appreciated :slight_smile:
  Kernel: 6.4.7-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=8b5dad39-7bad-4f79-8a48-361ffb45159c rw rootflags=subvol=@
    resume=UUID=a6f142fa-98ba-4663-8088-23273caf01e8 loglevel=3 ibt=off
  Desktop: Cinnamon v: 5.8.4 tk: GTK v: 3.24.38 wm: muffin vt: 7 dm: LightDM
    v: 1.32.0 Distro: Garuda Linux base: Arch Linux
  Type: Laptop System: ASUSTeK product: ROG Zephyrus G14 GA401QM_GA401QM
  Mobo: ASUSTeK model: GA401QM v: 1.0 serial: <superuser required>
    UEFI: American Megatrends LLC. v: GA401QM.412 date: 08/30/2022
  ID-1: BAT0 charge: 29.5 Wh (51.8%) condition: 56.9/76.0 Wh (74.9%)
    power: 63.0 W volts: 15.8 min: 15.8 model: ASUSTeK ASUS Battery type: Li-ion
    serial: N/A status: charging
  Info: model: AMD Ryzen 9 5900HS with Radeon Graphics bits: 64 type: MT MCP
    microcode: 0xA50000C
    L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 1328 high: 3300 min/max: 1200/4679 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1197 2: 1197
    3: 1197 4: 1200 5: 1198 6: 1197 7: 1195 8: 1197 9: 1198 10: 1196 11: 1195
    12: 1200 13: 3300 14: 1200 15: 1200 16: 1194 bogomips: 105394
  Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: ASUSTeK
    driver: nvidia v: 535.86.05 alternate: nouveau,nvidia_drm non-free: 535.xx+
    status: current (as of 2023-07) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 3 speed: 8 GT/s lanes: 8
    link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0
    chip-ID: 10de:2520 class-ID: 0300
    link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1 empty: HDMI-A-1
    bus-ID: 04:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 53.0 C
  Display: x11 server: X.Org v: 21.1.8 driver: X: loaded: amdgpu,nvidia
    s-diag: 583mm (22.95")
  Monitor-1: DP-1-0 size-res: N/A modes: N/A
  Monitor-2: eDP pos: primary res: 1920x1080 hz: 144 dpi: 158
    size: 309x174mm (12.17x6.85") diag: 355mm (13.96") modes: N/A
  API: OpenGL v: 4.6 Mesa 23.1.4 renderer: AMD Radeon Graphics (renoir LLVM
    15.0.7 DRM 3.52 6.4.7-zen1-2-zen) direct-render: Yes
  Device-2: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
    speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637 class-ID: 0403
    lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.5
    link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3
  API: ALSA v: k6.4.7-zen1-2-zen status: kernel-api with: aoss
  Server-1: PipeWire v: 0.3.76 status: active with: 1: pipewire-pulse
  Device-1: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
    lanes: 1 bus-ID: 02:00.0 chip-ID: 14c3:7961 class-ID: 0280
  Device-2: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
    rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 4-1.1:3
  IF: enp4s0f4u1u1 state: up speed: 100 Mbps duplex: full mac: <filter>
    rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:3 chip-ID: 13d3:3563
  Local Storage: total: 476.94 GiB used: 56.08 GiB (11.8%)
    fw-rev: FXM7201Q temp: 35.9 C scheme: GPT
  ID-1: / raw-size: 460.11 GiB size: 460.11 GiB (100.00%)
    used: 56.08 GiB (12.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-3: /home raw-size: 460.11 GiB size: 460.11 GiB (100.00%)
  ID-4: /var/log raw-size: 460.11 GiB size: 460.11 GiB (100.00%)
  ID-5: /var/tmp raw-size: 460.11 GiB size: 460.11 GiB (100.00%)
  ID-1: swap-1 type: zram size: 15.03 GiB used: 9.8 MiB (0.1%) priority: 100
  ID-2: swap-2 type: partition size: 16.53 GiB used: 0 KiB (0.0%)
  System Temperatures: cpu: 61.5 C mobo: N/A gpu: amdgpu temp: 53.0 C
  Fan Speeds (RPM): cpu: 0
  Processes: 466 Uptime: 2h 52m wakeups: 2 Memory: total: 16 GiB note: est.
  available: 15.03 GiB used: 7.66 GiB (51.0%) Init: systemd v: 254
  pm: pacman pkgs: 1582 libs: 499 tools: pamac,paru Shell: fish v: 3.6.1
  default: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.28
  System install date:     2023-08-03
  Last full system update: 2023-08-03 ↻
Found a similar post and followed the diagnostic steps
I ran xrandr and this is the output:
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 16384 x 16384
eDP connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 309mm x 174mm
   1920x1080    143.98*+  59.99
   1680x1050    143.98
   1280x1024    143.98
   1440x900     143.98
   1280x800     143.98
   1280x720     143.98
   1024x768     143.98
   800x600      143.98
   640x480      143.98
HDMI-A-0 disconnected (normal left inverted right x axis y axis)
DP-1-0 connected (normal left inverted right x axis y axis)
   1920x1080     60.00 +  59.99    59.94    50.00
   1680x1050     59.95
   1600x1200     60.00
   1440x900      59.89
   1366x768      59.79
   1280x1024     75.02    60.02
   1280x960      60.00
   1280x720      60.00    59.94    50.00
   1152x864      75.00
   1024x768      75.03    70.07    60.00
   800x600       75.00    72.19    60.32    56.25
   720x576       50.00
   720x480       59.94
   640x480       75.00    72.81    59.94    59.93
DP-1-1 disconnected (normal left inverted right x axis y axis)
Then I ran
inxi -SMGxxxaz
mhwd -li
bash -c 'for Xconf in $(ls /etc/X11/xorg.conf.d/*.conf | grep -v keyboard); do echo -e "\n" $Xconf ; cat $Xconf ; done'
ls -1 /etc/X11 | grep conf
And it printed the following:
  Kernel: 6.4.7-zen1-3-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    bus-ID: 04:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 40.0 C
    15.0.7 DRM 3.52 6.4.7-zen1-3-zen) direct-render: Yes
> Installed PCI configs:
                  NAME               VERSION          FREEDRIVER           TYPE
           video-linux            2021.08.29                true            PCI
video-nvidia-prime-render-offload            2023.01.15               false            PCI
Warning: No installed USB configs!
 /etc/X11/xorg.conf.d/30-touchpad.conf
Section "InputClass"
    Identifier "touchpad"
    Driver "libinput"
    MatchIsTouchpad "on"
    Option "Tapping" "on"
    Option "TappingButtonMap" "lrm"
    Option "NaturalScrolling" "on"
    Option "ScrollMethod" "twofinger"
EndSection
 xorg.conf.d
Creating a filename.conf in etc/X11//xorg.conf.d solved this issue :slight_smile: hope this fixes someone elses problem too!
Section "ServerLayout"
    Identifier "layout"
    Screen 0 "nvidia"
    Inactive "AMD"
EndSection
Section "Device"
    Identifier  "nvidia"
    Driver      "nvidia"
    BusID       "PCI:01:0:0"
EndSection
Section "Screen"
    Identifier "nvidia"
    Device "nvidia"
    Option "DPI" "96 x 96"
EndSection
Section "Device"
    Identifier  "AMD"
    Driver      "amdgpu"
    BusID       "PCI:05:0:0"
    Option "DRI" "3"
    Option "TearFree" "true"
