Hello, I just installed Garuda with XFCE today and I am having this issue where, after suspending my machine, only one monitor turns back on after resuming. The monitor that does not turn on is my 2k display that runs over HDMI while the other one is 1080p over display port. I am also using NVIDIA which could have something to do with that. I did not have this problem on Manjaro (I even tried switching from xfce4-screensaver to light-locker as well as disabling the lock screen all together), so it might be a Garuda thing.
System info:
Kernel: 5.9.1-zen2-1-zen x86_64 bits: 64 compiler: N/A
Desktop: Xfce 4.14.2 tk: Gtk 3.24.20 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Garuda Linux
Type: Desktop System: Micro-Star product: MS-7B51 v: 1.0 serial: <filter>
Mobo: Micro-Star model: MPG Z390 GAMING PLUS (MS-7B51) v: 1.0
serial: <filter> UEFI: American Megatrends v: 1.10 date: 08/22/2018
Device-1: hidpp_battery_0 model: Logitech K520 serial: <filter>
charge: 70% (should be ignored) rechargeable: yes status: Discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse M510
status: Discharging
Info: 6-Core model: Intel Core i7-8700K bits: 64 type: MT MCP
arch: Kaby Lake rev: A L2 cache: 12.0 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
bogomips: 88796
Speed: 4508 MHz min/max: 800/4700 MHz Core speeds (MHz): 1: 4503 2: 4503
3: 4500 4: 4500 5: 4507 6: 4505 7: 4502 8: 4504 9: 4494 10: 4446 11: 3604
12: 4504
Device-1: NVIDIA TU106 [GeForce RTX 2070 Rev. A] vendor: Micro-Star MSI
driver: nvidia v: 455.28 bus ID: 01:00.0 chip ID: 10de:1f07
Display: x11 server: X.Org 1.20.9 driver: nvidia resolution: 1: 2560x1440
2: 1920x1080~75Hz s-dpi: 96
OpenGL: renderer: GeForce RTX 2070/PCIe/SSE2 v: 4.6.0 NVIDIA 455.28
direct render: Yes
driver: snd_hda_intel v: kernel bus ID: 00:1f.3 chip ID: 8086:a348
Device-2: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:10f9
Device-3: JMTek LLC. JOUNIVO JV605PRO type: USB
driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-2:3 chip ID: 0c76:605d
Sound Server: ALSA v: k5.9.1-zen2-1-zen
Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e
v: kernel port: efa0 bus ID: 00:1f.6 chip ID: 8086:15bc
Device-2: Ralink RT5572 Wireless Adapter type: USB driver: rt2800usb
bus ID: 1-9:8 chip ID: 148f:5572 serial: <filter>
IF: wlp0s20f0u9 state: up mac: <filter>
Local Storage: total: 1.42 TiB used: 413.34 GiB (28.4%)
ID-1: /dev/sda vendor: SanDisk model: SDSSDH31000G size: 931.51 GiB
speed: 6.0 Gb/s serial: <filter> rev: 70RL scheme: GPT
ID-2: /dev/sdb vendor: SanDisk model: SDSSDH3500G size: 465.76 GiB
ID-3: /dev/sdd type: USB vendor: Generic model: Flash Disk size: 58.59 GiB
serial: <filter> rev: 8.07 scheme: MBR
ID-1: / size: 34.18 GiB used: 10.20 GiB (29.9%) fs: btrfs dev: /dev/sda2
ID-2: /home size: 874.43 GiB used: 403.14 GiB (46.1%) fs: ext4
dev: /dev/sda3
ID-3: /var/log size: 34.18 GiB used: 10.20 GiB (29.9%) fs: btrfs
dev: /dev/sda2
ID-4: /var/tmp size: 34.18 GiB used: 10.20 GiB (29.9%) fs: btrfs
dev: /dev/sda2
ID-1: swap-1 type: partition size: 7.82 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda4
ID-2: swap-2 type: zram size: 332.2 MiB used: 212 KiB (0.1%)
priority: 32767 dev: /dev/zram0
ID-3: swap-3 type: zram size: 332.2 MiB used: 12 KiB (0.0%)
priority: 32767 dev: /dev/zram1
ID-4: swap-4 type: zram size: 332.2 MiB used: 136 KiB (0.0%)
priority: 32767 dev: /dev/zram2
ID-5: swap-5 type: zram size: 332.2 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram3
ID-6: swap-6 type: zram size: 332.2 MiB used: 12 KiB (0.0%)
priority: 32767 dev: /dev/zram4
ID-7: swap-7 type: zram size: 332.2 MiB used: 152 KiB (0.0%)
priority: 32767 dev: /dev/zram5
ID-8: swap-8 type: zram size: 332.2 MiB used: 100 KiB (0.0%)
priority: 32767 dev: /dev/zram6
ID-9: swap-9 type: zram size: 332.2 MiB used: 204 KiB (0.1%)
priority: 32767 dev: /dev/zram7
ID-10: swap-10 type: zram size: 332.2 MiB used: 276 KiB (0.1%)
priority: 32767 dev: /dev/zram8
ID-11: swap-11 type: zram size: 332.2 MiB used: 8 KiB (0.0%)
priority: 32767 dev: /dev/zram9
ID-12: swap-12 type: zram size: 332.2 MiB used: 112 KiB (0.0%)
priority: 32767 dev: /dev/zram10
ID-13: swap-13 type: zram size: 332.2 MiB used: 372 KiB (0.1%)
priority: 32767 dev: /dev/zram11
System Temperatures: cpu: 44.0 C mobo: N/A gpu: nvidia temp: 61 C
Processes: 481 Uptime: 9h 20m Memory: 15.57 GiB used: 2.41 GiB (15.5%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1231
Shell: Zsh v: 5.8 running in: xfce4-terminal inxi: 3.1.06
