G'day guys,
Got a bit of an issue with my recent install of Garuda with xfce as my DE. Interestingly I had this problem on EndeavourOS with xfce as well. But as the title states, my second monitor refuses to display an image. Everything works fine on my Windows partition so I know that the monitor, cable and integrated graphics are fine on my computer. But it's just when I boot up Garuda, I'll get an image displaying on the second monitor, however when I get to the login screen it'll just be black, but I can see the cursor.
Taking screenshots shows both of the monitors displaying a normal screen (wallpaper, apps etc). I've tried going through xrandr arandr and just the normal display settings with no luck
Last bit of information is that my old endeavourOS partition used to work fine with no issues until I updated it and lost my second monitor, so I'm wondering if this is the same issue. Hard to say where the problem lies because both systems have been on arch, xfce and various kernels.
Thanks in advance for anyone that tries to help me out here. I'm really enjoying Garuda so far otherwise, I can finally play games on linux successfully for the first time
filo
May 8, 2022, 4:54am
2
Hi there, welcome.
Please always post the output of your
formatted with ~~~ before and after the text block, as per new topic template.
Kernel: 5.15.37-1-lts arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=7273e01e-fc1e-4715-95a6-22fbc752b8d2 rw rootflags=subvol=@
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.30.0 Distro: Garuda Linux base: Arch Linux
Type: Desktop System: Gigabyte product: Z690 UD DDR4 v: N/A
Mobo: Gigabyte model: Z690 UD DDR4 serial: <superuser required>
UEFI: American Megatrends LLC. v: F6 date: 01/27/2022
Device-1: sony_controller_battery_30:0e:d5:b3:38:08 model: N/A serial: N/A
charge: N/A status: charging
Info: model: 12th Gen Intel Core i5-12600K bits: 64 type: MST AMCP
arch: Alder Lake family: 6 model-id: 0x97 (151) stepping: 2 microcode: 0x1A
Topology: cpus: 1x cores: 10 mt: 6 tpc: 2 st: 4 threads: 16 smt: enabled
cache: L1: 864 KiB desc: d-4x32 KiB, 6x48 KiB; i-6x32 KiB, 4x64 KiB
L2: 9.5 MiB desc: 6x1.2 MiB, 1x2 MiB L3: 20 MiB desc: 1x20 MiB
Speed (MHz): avg: 2961 high: 4900 min/max: 800/4900:3600 scaling:
driver: intel_pstate governor: performance cores: 1: 1028 2: 4891 3: 4900
4: 4799 5: 834 6: 884 7: 4900 8: 4200 9: 906 10: 3075 11: 3008 12: 4500
13: 1400 14: 862 15: 3607 16: 3589 bogomips: 117964
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel AlderLake-S GT1 vendor: Gigabyte driver: i915 v: kernel
ports: active: HDMI-A-2 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:4680 class-ID: 0300
Device-2: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] driver: amdgpu
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: HDMI-A-3
empty: DP-2,DP-3,DP-4 bus-ID: 03:00.0 chip-ID: 1002:73bf class-ID: 0300
Display: x11 server: X.Org v: 21.1.3 compositor: xfwm v: 4.16.1 driver:
X: loaded: amdgpu,intel unloaded: modesetting,radeon alternate: fbdev,vesa
gpu: amdgpu,i915 display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 3840x1403 s-dpi: 96 s-size: 1016x371mm (40.00x14.61")
s-diag: 1082mm (42.58")
Monitor-1: HDMI-A-2 pos: primary,top-left model: Samsung S22D300
serial: <filter> built: 2015 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
size: 480x270mm (18.9x10.63") diag: 547mm (21.5") ratio: 16:9 modes:
Monitor-2: HDMI-A-3 mapped: HDMI2 pos: bottom-r model: Sceptre F24
built: 2019 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
size: 480x270mm (18.9x10.63") diag: 611mm (24") ratio: 16:10, 15:9 modes:
Device-1: Intel Alder Lake-S HD Audio vendor: Gigabyte
bus-ID: 00:1f.3 chip-ID: 8086:7ad0 class-ID: 0403
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
Sound Server-1: ALSA v: k5.15.37-1-lts running: yes
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 06:00.0
IF: enp6s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Qualcomm Atheros AR9287 Wireless Network Adapter driver: ath9k
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 07:00.0
chip-ID: 168c:002e class-ID: 0280
IF: wlp7s0 state: down mac: <filter>
Device-1: Broadcom BCM20702A0 Bluetooth 4.0 type: USB driver: btusb v: 0.8
bus-ID: 1-6.3:6 chip-ID: 0a5c:21ec class-ID: fe01 serial: <filter>
address: <filter>
Local Storage: total: 1.14 TiB used: 67.95 GiB (5.8%)
model: WD Blue SN570 1TB size: 931.51 GiB block-size: physical: 512 B
rev: 234100WD temp: 32.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT250MX500SSD1
size: 232.89 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 023 scheme: GPT
ID-1: / raw-size: 196.63 GiB size: 196.63 GiB (100.00%)
used: 67.92 GiB (34.5%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
ID-2: /boot/efi raw-size: 100 MiB size: 99.2 MiB (99.21%)
used: 26.1 MiB (26.3%) fs: vfat dev: /dev/sda3 maj-min: 8:3
ID-3: /home raw-size: 196.63 GiB size: 196.63 GiB (100.00%)
ID-4: /var/log raw-size: 196.63 GiB size: 196.63 GiB (100.00%)
ID-5: /var/tmp raw-size: 196.63 GiB size: 196.63 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.4 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 27.8 C mobo: 16.8 C gpu: amdgpu temp: 37.0 C
mem: 34.0 C
Processes: 380 Uptime: 1d 2h 59m wakeups: 3 Memory: 15.4 GiB
used: 3.55 GiB (23.0%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1379 lib: 369 Shell: Bash v: 5.1.16
running-in: xfce4-terminal inxi: 3.3.15
Garuda (2.6.2-1):
System install date: 2022-04-20
Last full system update: 2022-05-08
Trying to understand which exactly is the system behavior, these are not helping descriptions…
Which monitor? Both? Screen means all monitors, just for clarity.
XFCE display settings not able to configure monitors sounds odd, since your system report looks normal (the system can see both monitors).
Explain in detail what happens when you open xfce display settings, or arandr.
More objective info required.
ls -l /etc/X11/xorg.conf.d/*.conf
xrandr
DRI_PRIME=1 xrandr
DRI_PRIME=1 inxi -Gaz
cat /var/log/Xorg.0.log ## post this to a pastebin web service
Apologies for the inaccurate descriptions, I'm just a wee little newbie
By login screen going black, I mean the Samsung monitor (secondary monitor plugged into the motherboard and not the GPU)
-rw-r--r-- 1 root root 232 Apr 20 11:43 /etc/X11/xorg.conf.d/00-keyboard.conf
-rw-r--r-- 1 root root 240 Mar 29 14:06 /etc/X11/xorg.conf.d/30-touchpad.conf
DRI_PRIME=1 xrandr
Screen 0: minimum 320 x 200, current 3840 x 1403, maximum 16384 x 16384
DisplayPort-1 disconnected (normal left inverted right x axis y axis)
DisplayPort-2 disconnected (normal left inverted right x axis y axis)
DisplayPort-3 disconnected (normal left inverted right x axis y axis)
HDMI-A-2 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 480mm x 270mm
1920x1080 60.00*+ 74.97 50.00 59.94
1280x1024 75.02
1440x900 74.98
1280x800 59.81
1280x720 60.00 50.00 59.94
1024x768 75.00 75.03 60.00
800x600 75.00 60.32
720x576 50.00
720x480 60.00 59.94
640x480 60.00 59.94
720x400 70.08
DP1 disconnected (normal left inverted right x axis y axis)
HDMI1 disconnected (normal left inverted right x axis y axis)
HDMI2 connected 1920x1080+1920+323 (normal left inverted right x axis y axis) 480mm x 270mm
1920x1080 60.00*+ 50.00 59.94
1680x1050 59.88
1600x900 60.00
1280x1024 75.02 60.02
1440x900 59.90
1280x800 59.91
1152x864 75.00
1024x768 75.03 70.07 60.00
832x624 74.55
800x600 72.19 75.00 60.32 56.25
720x576 50.00
720x480 60.00 59.94
640x480 75.00 72.81 66.67 60.00 59.94
720x400 70.08
VIRTUAL1 disconnected (normal left inverted right x axis y axis)
1920x1080 (0x59) 148.500MHz +HSync +VSync
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.50KHz
v: height 1080 start 1084 end 1089 total 1125 clock 60.00Hz
1920x1080 (0x5b) 148.500MHz +HSync +VSync
h: width 1920 start 2448 end 2492 total 2640 skew 0 clock 56.25KHz
v: height 1080 start 1084 end 1089 total 1125 clock 50.00Hz
1920x1080 (0x5c) 148.352MHz +HSync +VSync
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.43KHz
v: height 1080 start 1084 end 1089 total 1125 clock 59.94Hz
1280x1024 (0x5d) 135.000MHz +HSync +VSync
h: width 1280 start 1296 end 1440 total 1688 skew 0 clock 79.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 75.02Hz
1280x720 (0x60) 74.250MHz +HSync +VSync
h: width 1280 start 1390 end 1430 total 1650 skew 0 clock 45.00KHz
v: height 720 start 725 end 730 total 750 clock 60.00Hz
1280x720 (0x61) 74.250MHz +HSync +VSync
h: width 1280 start 1720 end 1760 total 1980 skew 0 clock 37.50KHz
v: height 720 start 725 end 730 total 750 clock 50.00Hz
1280x720 (0x62) 74.176MHz +HSync +VSync
h: width 1280 start 1390 end 1430 total 1650 skew 0 clock 44.96KHz
v: height 720 start 725 end 730 total 750 clock 59.94Hz
1024x768 (0x64) 78.750MHz +HSync +VSync
h: width 1024 start 1040 end 1136 total 1312 skew 0 clock 60.02KHz
v: height 768 start 769 end 772 total 800 clock 75.03Hz
1024x768 (0x65) 65.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.36KHz
v: height 768 start 771 end 777 total 806 clock 60.00Hz
800x600 (0x66) 49.500MHz +HSync +VSync
h: width 800 start 816 end 896 total 1056 skew 0 clock 46.88KHz
v: height 600 start 601 end 604 total 625 clock 75.00Hz
800x600 (0x67) 40.000MHz +HSync +VSync
h: width 800 start 840 end 968 total 1056 skew 0 clock 37.88KHz
v: height 600 start 601 end 605 total 628 clock 60.32Hz
720x576 (0x68) 27.000MHz -HSync -VSync
h: width 720 start 732 end 796 total 864 skew 0 clock 31.25KHz
v: height 576 start 581 end 586 total 625 clock 50.00Hz
720x480 (0x69) 27.027MHz -HSync -VSync
h: width 720 start 736 end 798 total 858 skew 0 clock 31.50KHz
v: height 480 start 489 end 495 total 525 clock 60.00Hz
720x480 (0x6a) 27.000MHz -HSync -VSync
h: width 720 start 736 end 798 total 858 skew 0 clock 31.47KHz
v: height 480 start 489 end 495 total 525 clock 59.94Hz
640x480 (0x6b) 25.200MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.50KHz
v: height 480 start 490 end 492 total 525 clock 60.00Hz
640x480 (0x6c) 25.175MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.47KHz
v: height 480 start 490 end 492 total 525 clock 59.94Hz
720x400 (0x6d) 28.320MHz -HSync +VSync
h: width 720 start 738 end 846 total 900 skew 0 clock 31.47KHz
v: height 400 start 412 end 414 total 449 clock 70.08Hz
Pastebin was down at the time of posting
Not sure what you mean by explaining what happens with display settings/arandr. Everything looks good in the settings. All enabled, correct locations, correct frequency
@filo @petsam
Sorry guys, I don’t mean to be a pest but this is the only issue stopping me from fully committing to Linux. I’ve tried so many options so I’m depending on you guys and the community to discover the solution to this.
filo
May 15, 2022, 7:01am
7
Sorry, unfortunately I don't think I'll be able to help much here.
Something you could do would be to go through the Arch wiki, eg.
https://wiki.archlinux.org/title/Multihead
and relevant related articles, eg. the ATI one.
There seems to be something missing in the /etc/X11/xorg.conf.d/*.conf in my opinion.
Maybe you can test the suggestions from the wiki.
tbg
May 15, 2022, 8:13am
8
I, and others on the team do not use more than one monitor, so how exactly are we supposed to test and find a solution to your issue. The only one likely to be using your exact hardware is yourself. We are simply here to offer suggestions, it is incumbent on the user to troubleshoot and find their own solution.
This is not a Garuda specific issue if it presents on other distros, yet there seems to be the expectation here that it is our responsibility to solve this issue for you. That is your responsibility, not ours, (we are only here to assist).
I wish you luck finding a solution to your issue.
Have you tried a different kernel?
First fully update the system:
garuda-update
Install the kernel you want to try--install the corresponding headers, too:
sudo pacman -S linux-zen linux-zen-headers
Reboot, then on the grub screen (before the login screen) select "advanced options" and select your new kernel.
Another easy thing to try would be to download some of the other Garuda spins and boot into the live environment to see if the problem persists. I'm not saying switch DEs, I'm just saying that could be a good source for troubleshooting clues.
Have you tried unplugging the monitor (from power) for a few minutes? Have you tried unplugging the monitor (from the computer) and plugging it back in on a live system?
petsam
May 15, 2022, 4:31pm
10
Maybe English is not your native language (neither is mine), but a translation tool can help you.
Just do as you are requested, not something else and we will eventually understand (although we don’t all have unlimited free time, so I myself prefer to spend it on technical support, not language translation ).
xrandr
You missed this one. We need this to compare with the similar one for prime.
if the output of this, is what you have posted, then your system is seriously broken. Reinstall if that’s the case.
I don’t think you do as requested:
If you could realize what is good or bad (being a newbie, as you state), then you wouldn’t need help. Obviously, something wrong happens in front of your eyes and you can’t realize it. That’s why I did not ask what is wrong , but what do you see (not your interpretation ).
We are going slow, so don’t get anxious if you get a slow response…
system
Closed
May 29, 2022, 4:32pm
11
