It seems I’m not the first to ask this question but none of the solutions have worked for me. I have a laptop with a second monitor. The colors are extremely dull and everything looks blurry.
Note: I’ve been locked out of replying to this discussion or editing my post below, so I’m using this post to edit. I’m not sure what
does but i put it down below.
The laptop I’m using is a Swift SFX14-42G.
Ryzen 7 5825U
GeForce RTX 3050Ti (though I’m not using it by default)
both the laptop and monitor are 1920x1080
After doing some research it seems the problem is only caused by booting up with the monitor connected. This is not the case for me. Even if I connect it after booting up the problem persists .
Please post the terminal/konsole input and output as text (no pictures) from the following command:
Refusing to post the output of the required “garuda-inxi” on a help request will likely result in you not receiving any help from the Garuda team. A failure to provide your system specs may also result in your thread being closed without notice, (as without this information providing assistance is often next to impossible).
Before opening a new help request, please search the Arch and Garuda Wiki’s, and read any relevant sections related to your issue. Also, thoroughly search any error messages in the forum’s search engine and on the web. For in depth information on how to search for answers to Linux issues effectively, read the tips on the Garuda Wiki:
Ryzen 7 5825U
