garuda-inxi:
Kernel: 6.0.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=3419cad2-d79e-432c-a090-687e8849465f rw rootflags=subvol=@
loglevel=3 amdgpu.ppfeaturemask=0xffffffff
Desktop: KDE Plasma v: 5.26.2 tk: Qt v: 5.15.7 info: latte-dock
wm: kwin_wayland dm: SDDM Distro: Garuda Linux base: Arch Linux
Type: Desktop Mobo: Gigabyte model: B550M DS3H v: x.x serial: N/A
UEFI: American Megatrends v: F12 date: 01/18/2021
Info: model: AMD Ryzen 5 5600X socket: AM4 bits: 64 type: MT MCP
arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22 process: TSMC n7
(7nm) family: 0x19 (25) model-id: 0x21 (33) stepping: 0
microcode: 0xA201009
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3700 min/max: 2200/4650 boost: enabled
base/boost: 3700/4650 scaling: driver: acpi-cpufreq governor: performance
volts: 1.1 V ext-clock: 100 MHz cores: 1: 3700 2: 3700 3: 3700 4: 3700
5: 3700 6: 3700 7: 3700 8: 3700 9: 3700 10: 3700 11: 3700 12: 3700
bogomips: 88636
Device-1: AMD Navi 23 [Radeon RX 6650 XT] vendor: Gigabyte driver: amdgpu
pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: HDMI-A-1
off: HDMI-A-2 empty: DP-1,DP-2 bus-ID: 0c:00.0 chip-ID: 1002:73ef
Display: server: X.Org v: 22.1.4 with: Xwayland v: 22.1.4
gpu: amdgpu display-ID: :1 screens: 1
Monitor-1: XWAYLAND1 res: 1920x1080 hz: 144 dpi: 92
size: 530x300mm (20.87x11.81") diag: 609mm (23.98") modes: N/A
OpenGL: renderer: AMD Radeon RX 6650 XT (navi23 LLVM 14.0.6 DRM 3.48
6.0.6-zen1-1-zen) v: 4.6 Mesa 22.2.1 direct render: Yes
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel
bus-ID: 1-2:4 pcie: chip-ID: 2972:0047 gen: 4 speed: 16 GT/s class-ID: fe01
lanes: 16 bus-ID: 0c:00.1 chip-ID: 1002:ab28 class-ID: 0403
bus-ID: 0e:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: FiiO BTR5 type: USB driver: snd-usb-audio
Device-4: Medeli heyday Microphone 01 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-5:5 chip-ID: 0a67:0002
Sound API: ALSA v: k6.0.6-zen1-1-zen running: yes
lanes: 1 port: f000 bus-ID: 09:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: NetGear A6210 type: USB driver: mt76x2u bus-ID: 2-3:2
chip-ID: 0846:9053 class-ID: 0000 serial: <filter>
IF: wlp2s0f0u3 state: up mac: <filter>
Local Storage: total: 4.63 TiB used: 134.3 GiB (2.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: TeamGroup model: TM8FP6001T
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: VC0S036B
temp: 54.9 C scheme: GPT
SMART: yes health: PASSED on: 6d 18h cycles: 162 read-units: 16,524,150
[8.46 TB] written-units: 14,090,254 [7.21 TB]
model: WD1003FZEX-00MK2A0 family: Black size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: HDD
rpm: 7200 serial: <filter> rev: 1A01 temp: 41 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 2y 247d 1h cycles: 2374
model: WD20EZAZ-00GGJB0 family: Blue (SMR) size: 1.82 TiB block-size:
rpm: 5400 serial: <filter> rev: 0A80 temp: 35 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 133d 20h cycles: 264
model: WD10EADS-65M2B1 family: Caviar Green size: 931.51 GiB block-size:
physical: 512 B logical: 512 B sata: 2.6 speed: 3.0 Gb/s type: N/A
serial: <filter> rev: 0A01 temp: 45 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 2y 156d 10h cycles: 5201
ID-5: /dev/sdd maj-min: 8:48 type: USB vendor: SanDisk model: USB 3.2Gen1
size: 57.3 GiB block-size: physical: 512 B logical: 512 B type: N/A
ID-1: / raw-size: 741.14 GiB size: 741.14 GiB (100.00%) used: 134.26 GiB
(18.1%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p6 maj-min: 259:6
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 38.9 MiB
(13.0%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 741.14 GiB size: 741.14 GiB (100.00%) used: 134.26
GiB (18.1%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p6
maj-min: 259:6
ID-4: /var/log raw-size: 741.14 GiB size: 741.14 GiB (100.00%) used: 134.26
maj-min: 259:6
ID-5: /var/tmp raw-size: 741.14 GiB size: 741.14 GiB (100.00%) used: 134.26
maj-min: 259:6
ID-1: swap-1 type: zram size: 15.56 GiB used: 1024 KiB (0.0%)
ID-2: swap-2 type: partition size: 17.13 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 45.1 C mobo: 36.0 C gpu: amdgpu temp: 58.0 C
mem: 60.0 C
Processes: 333 Uptime: 22m wakeups: 0 Memory: 15.56 GiB used: 3.47 GiB
(22.3%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 1841
libs: 514 tools: octopi,paru Shell: garuda-inxi (sudo) default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.22
Garuda (2.6.9-1):
System install date: 2022-11-01
Last full system update: 2022-11-01 ↻
Windows dual boot: Yes
i installed garuda on my machine just today. It was working fine for a little bit, but then i left the computer for a few minutes and came back to see that one of my monitors wasn't working. I tried logging out and logging in to an X11 session, no dice. I checked on my windows partition to confirm that my monitor hadn't died or something, but it worked fine. So probably not a hardware issue. I tried unplugging both of my monitors and plugging them back in, trying different display ports on the gpu, nothing. When i go to my display settings it keeps refreshing and saying on output has been removed and added, but it never detects the second monitor.
According to xrandr theres only one monitor connected:
Screen 0: minimum 16 x 16, current 1920 x 1080, maximum 32767 x 32767
XWAYLAND1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 530mm x 300mm
1920x1080 143.88*+
1440x1080 143.90
1400x1050 143.89
1280x1024 143.92
1280x960 143.86
1152x864 143.92
1024x768 143.87
800x600 143.83
640x480 143.85
320x240 142.05
1680x1050 143.88
1440x900 143.86
1280x800 143.84
720x480 143.85
640x400 143.37
320x200 141.40
1600x900 143.93
1368x768 143.77
1280x720 143.85
1024x576 143.91
864x486 143.63
720x400 143.88
640x350 143.57
having looked through the forums it seems that multiple other users have had a very similar issue occur recently, but no solutions yet.
edit: i forgot to mention, but the second monitor turns on and works on the login manager, but as soon as i log in with either X11 or Wayland it shuts back off
