My system information, besides that I'm running gnome, doesn't seem relevant to this issue that should be really obvious to me but isn't, but I have put it below to satisfy the rules lol
Ok, I use Prospect Mail as an appimage to access my Outlook email. If I search for it in the Super key menu, I can only find it in Files. Which is fine, because then I can just select and run the appimage from there, but I don't like that I have to do that extra step.
So I was trying to learn how to add an application to the dock (which my research indicates is Plank) and I simply can't find anything about it. Am I just a bad searcher? Can you point me to the right location?
When I searched the forum, I found only completely unrelated issues (probably because this has a simple one sentence answer I just haven't found yet.
I tried creating a script to run it from the Super search, but selecting it only makes it open in gvim.
Sorry if this is a dumb question lol
$ inxi -Faz
System: Kernel: 5.13.10-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=a2f9b7ce-1d14-45ec-960d-80f6deb84e9b
rw rootflags=subvol=@ quiet
cryptdevice=UUID=ed9fb91f-024a-4397-9ad0-e4eabee27366:luks-ed9fb91f-024a-4397-9ad0-e4eabee27366
root=/dev/mapper/luks-ed9fb91f-024a-4397-9ad0-e4eabee27366 splash rd.udev.log_priority=3
vt.global_cursor_default=0 systemd.unified_cgroup_hierarchy=1 loglevel=3 pcie_aspm=off
ath10k_core.skip_otp=y
Desktop: GNOME 40.4 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1 Distro: Garuda Linux
Machine: Type: Laptop System: Acer product: Nitro AN515-42 v: V1.18 serial: <filter>
Mobo: RR model: Freed_RRS v: V1.18 serial: <filter> UEFI: Insyde v: 1.18 date: 06/18/2020
Battery: ID-1: BAT1 charge: 8.8 Wh (29.6%) condition: 29.7/48.9 Wh (60.7%) volts: 14.0 min: 15.2
model: LG 0x41,0x43,0x31,0x34,0x42,0x38,0x007A type: Li-ion serial: <filter>
status: Discharging
Device-1: apple_mfi_fastcharge model: N/A serial: N/A charge: N/A status: N/A
CPU: Info: Quad Core model: AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx bits: 64 type: MT MCP
arch: Zen family: 17 (23) model-id: 11 (17) stepping: 0 microcode: 810100B cache: L2: 2 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 31938
Speed: 1532 MHz max: 1600 MHz boost: enabled Core speeds (MHz): 1: 1532 2: 1416 3: 1400 4: 1368
5: 1545 6: 1460 7: 1378 8: 1434
Graphics: Device-1: AMD Baffin [Radeon RX 460/560D / Pro 450/455/460/555/555X/560/560X]
vendor: Acer Incorporated ALI driver: amdgpu v: kernel bus-ID: 01:00.0 chip-ID: 1002:67ef
class-ID: 0380
Device-2: AMD Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series]
vendor: Acer Incorporated ALI driver: amdgpu v: kernel bus-ID: 04:00.0 chip-ID: 1002:15dd
Device-3: Chicony HD WebCam type: USB driver: uvcvideo bus-ID: 3-1:2 chip-ID: 04f2:b5f7
class-ID: 0e02
Display: x11 server: X.Org 1.20.13 compositor: gnome-shell driver: loaded: amdgpu,ati
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 142 size: 344x194mm (13.5x7.6") diag: 395mm (15.5")
OpenGL: renderer: AMD Radeon Vega 8 Graphics (RAVEN DRM 3.41.0 5.13.10-zen1-1-zen LLVM 12.0.1)
v: 4.6 Mesa 21.1.6 direct render: Yes
Audio: Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel bus-ID: 04:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
Sound Server-1: ALSA v: k5.13.10-zen1-1-zen running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Acer Incorporated ALI
driver: r8169 v: kernel port: 2000 bus-ID: 02:00.1 chip-ID: 10ec:8168 class-ID: 0200
IF: enp2s0f1 state: down mac: <filter>
Device-2: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter vendor: Lite-On
driver: ath10k_pci v: kernel port: 2000 bus-ID: 03:00.0 chip-ID: 168c:003e class-ID: 0280
IF-ID-1: enp4s0f3u1c4i2 state: up speed: N/A duplex: N/A mac: <filter>
Bluetooth: Device-1: Lite-On type: USB driver: btusb v: 0.8 bus-ID: 1-4:2 chip-ID: 04ca:3016
Report: bt-adapter ID: hci0 rfk-id: 12 state: up address: <filter>
Drives: Local Storage: total: 931.51 GiB used: 874.74 GiB (93.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000MX500SSD1 size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 033 scheme: GPT
Partition: ID-1: / raw-size: 931.25 GiB size: 931.25 GiB (100.00%) used: 874.74 GiB (93.9%) fs: btrfs
dev: /dev/dm-0 maj-min: 254:0 mapped: luks-ed9fb91f-024a-4397-9ad0-e4eabee27366
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.45%) used: 708 KiB (0.3%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 931.25 GiB size: 931.25 GiB (100.00%) used: 874.74 GiB (93.9%) fs: btrfs
ID-4: /var/log raw-size: 931.25 GiB size: 931.25 GiB (100.00%) used: 874.74 GiB (93.9%)
fs: btrfs dev: /dev/dm-0 maj-min: 254:0 mapped: luks-ed9fb91f-024a-4397-9ad0-e4eabee27366
ID-5: /var/tmp raw-size: 931.25 GiB size: 931.25 GiB (100.00%) used: 874.74 GiB (93.9%)
ID-1: swap-1 type: zram size: 30.27 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 53.0 C mobo: N/A
GPU: device: amdgpu temp: 47.0 C watts: 11.07 device: amdgpu temp: 53.0 C
Info: Processes: 366 Uptime: 2d 10h 38m wakeups: 20 Memory: 30.27 GiB used: 8.95 GiB (29.5%)
Init: systemd v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages:
pacman: 1758 lib: 541 Shell: fish v: 3.3.1 default: Bash v: 5.1.8 running-in: gnome-terminal
inxi: 3.3.06
