Firstly, sorry, it's another one of these threads... ![]()
This post has been long in the making, and I’m about ready to throw in the towel by disabling SDDM. I’ve been fighting this ever since I first installed Garuda, and so far, nothing I’ve tried has worked – I also ran into some other issues along the way, but those are for another day (and thread).
Essentially, this is yet another ‘SDDM does not start/is stuck on black screen after GRUB/freezes on a starting process’ issue. I have the Plymouth boot screen theme set to ‘details’ with all quiet params removed since I am basically always pressing esc to check the textual output, and what I’ve discovered is that sometimes the freeze will happen while trying to load the Samba service, in which case I can see all the textual output – other times it’ll tell me that SDDM has started, and then freeze on a black screen.
What both instances have in common is that the laptop will completely freeze – can’t change to another tty, can’t do any sysreq combos such as alt+prtsc+b to reboot, and can’t login by typing my password as though the login screen is just invisible. A hard reset is always required.
All the stuff I’ve tried to resolve this issue that has failed to fix it:
Everything suggested in this thread: Computer doesn’t boot, boots to a black screen, or stops at a message
Using different kernels (tried zen, lts and hardened, all to no avail – currently using lts due to some other issues related to suspend)
systemctl set-default graphical.targetso that the system isn’t usingmulti-user.targetinstead -
Adding a 30 second delay (which has somewhat lessened the occurrence of this issue) to the start of SDDM by executing the following:
sudo systemctl edit sddm-plymouth
# inside the override config file
[Service]
ExecStartPre=/bin/sleep 30
Installing
xf86-video-intel, as I noticed in myXorg.0.logbefore that it could not find any Intel modules. I’m actually not sure whether this could’ve made the issue worse, as the display manager now has two (possibly competing) graphical modules? -
Adding the proprietary NVIDIA modules to
mkinitpcio.confso it containsMODULES=(crc32c-intel intel_agp i915 nouveau nvidia nvidia_modeset nvidia_uvm nvidia_drm), and then refreshing the initramfs withsudo mkinitpcio -P -
Modifying
usr/share/sddm/scripts/Xsetupto use NVIDIA with
xrandr –setprovideroutputsource modesetting NVIDIA-G0
xrandr –auto
- Changing SDDM to use Wayland instead of X11 – didn’t solve the problem and only brought on its own set of problems, such as a black screen with cursor after suspend (at least I could switch to a virtual console…)
There may have been some changes which I forgot about since I wasn’t thoroughly documenting my steps >_>;; but these were the main ones.
Here are some links to logs which might be relevant (some logs are a few days old as that’s when I happened to be adamantly troubleshooting the issue – if you would like newer logs, please let me know):
journalctl –unit=sddm-plymouth.service: Garuda's PrivateBin -
Xorg.0.log (most recent): Garuda's PrivateBin
Xorg.1.log (ran
startxon a different tty to generate this log): Garuda's PrivateBin -
sudo journalctl -b -1: Garuda's PrivateBin
I’m at a loss for what to try next – any help would be appreciated! ^^;
If there's any further elaboration and/or logs required, lemme know and I'll get them to you when I can.
In the end if nothing works, I’m happy to follow the advice of a Redditor who essentially said, “From my experience with NVIDIA, you are better off forgoing graphical login managers. Log into a console and use startx instead”. :’)
Lastly, garuda-inxi:
Kernel: 5.15.79-1-lts arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-lts root=UUID=c9f99daa-f49a-4d9f-a961-e0361c675eed
rw rootflags=subvol=@ splash rd.udev.log_priority=3 vt.global_cursor_default=0
resume=UUID=8d72c892-6d9c-4514-b2d6-398dc499ca0c loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.26.3 tk: Qt v: 5.15.7 info: latte-dock wm: kwin_x11 vt: 2 dm: SDDM
Type: Laptop System: Dell product: XPS 15 9560 v: N/A serial: <superuser required> Chassis:
type: 10 serial: <superuser required>
Mobo: Dell model: 05FFDN v: A00 serial: <superuser required> UEFI: Dell v: 1.24.0
date: 08/10/2021
ID-1: BAT0 charge: 26.7 Wh (32.3%) condition: 82.7/97.0 Wh (85.3%) volts: 11.2 min: 11.4
model: LGC-LGC8.33 DELL 5XJ28 type: Li-ion serial: <filter> status: discharging
Info: model: Intel Core i7-7700HQ bits: 64 type: MT MCP arch: Kaby Lake gen: core 7 level: v3
note: check built: 2018 process: Intel 14nm family: 6 model-id: 0x9E (158) stepping: 9
microcode: 0xF0
Topology: cpus: 1x cores: 4 tpc: 2 threads: 8 smt: enabled cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 900 min/max: 800/3800 scaling: driver: intel_pstate governor: powersave
cores: 1: 900 2: 900 3: 900 4: 900 5: 900 6: 900 7: 900 8: 900 bogomips: 44798
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel HD Graphics 630 vendor: Dell driver: i915 v: kernel arch: Gen-9.5
process: Intel 14nm built: 2016-20 ports: active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:591b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Dell driver: nvidia v: 520.56.06
alternate: nouveau,nvidia_drm non-free: 520.xx+ status: current (as of 2022-10) arch: Pascal
code: GP10x process: TSMC 16nm built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1c8d class-ID: 0302
Device-3: Sunplus Innovation Integrated_Webcam_HD type: USB driver: uvcvideo bus-ID: 1-12:7
chip-ID: 1bcf:2b95 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.5 compositor: kwin_x11 driver: X:
loaded: intel dri: i965 gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 168 s-size: 580x326mm (22.83x12.83") s-diag: 665mm (26.19")
Monitor-1: eDP-1 mapped: eDP1 model: Sharp 0x1476 built: 2016 res: 3840x2160 hz: 60 dpi: 279
gamma: 1.2 size: 350x190mm (13.78x7.48") diag: 397mm (15.6") ratio: 16:9 modes: 3840x2160
API: OpenGL v: 4.6 Mesa 22.2.3 renderer: Mesa Intel HD Graphics 630 (KBL GT2)
direct render: Yes
Device-1: Intel CM238 HD Audio vendor: Dell driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
chip-ID: 8086:a171 class-ID: 0403
Sound API: ALSA v: k5.15.79-1-lts running: yes
Sound Server-2: PipeWire v: 0.3.60 running: yes
Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter vendor: Rivet Networks
Killer Wireless-n/a/ac 1535 driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 02:00.0 chip-ID: 168c:003e class-ID: 0280 temp: 41.0 C
Device-1: Qualcomm Atheros QCA61x4 Bluetooth 4.0 type: USB driver: btusb v: 0.8 bus-ID: 1-4:4
chip-ID: 0cf3:e300 class-ID: e001
Report: bt-adapter note: tool can't run ID: hci0 rfk-id: 1 state: down bt-service: disabled
rfk-block: hardware: no software: no address: N/A
Local Storage: total: 476.94 GiB used: 587.04 GiB (123.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba model: KXG50ZNV512G NVMe 512GB
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: AADA4106 temp: 31.9 C scheme: GPT
ID-1: / raw-size: 459.61 GiB size: 459.61 GiB (100.00%) used: 148.98 GiB (32.4%) fs: btrfs
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 10.2 MiB (3.4%) fs: vfat
ID-3: /home raw-size: 459.61 GiB size: 459.61 GiB (100.00%) used: 148.98 GiB (32.4%) fs: btrfs
ID-4: /var/log raw-size: 459.61 GiB size: 459.61 GiB (100.00%) used: 148.98 GiB (32.4%)
ID-5: /var/tmp raw-size: 459.61 GiB size: 459.61 GiB (100.00%) used: 148.98 GiB (32.4%)
ID-1: swap-1 type: zram size: 15.48 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
ID-2: swap-2 type: partition size: 17.03 GiB used: 0 KiB (0.0%) priority: -2
System Temperatures: cpu: 46.0 C pch: 43.5 C mobo: N/A
Fan Speeds (RPM): cpu: 0 fan-2: 0
Processes: 281 Uptime: 1h 30m wakeups: 3 Memory: 15.48 GiB used: 5.18 GiB (33.5%) Init: systemd
v: 252 default: graphical tool: systemctl Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1780
libs: 500 tools: octopi,pamac,paru pm: appimage pkgs: 0 Client: shell wrapper v: 5.1.16-release
inxi: 3.3.23
Garuda (2.6.9-1):
System install date: 2022-10-19
Last full system update: 2022-11-26
