I am on Garuda Dragonized. The SDDM is the Sweet login screen attached below is the garuda-inxi. I have attempted to update language settings in the nano /etc/default/locale and these values are not showing up when i open the file. I have no idea as the rest of the system is in english just not the login screen.
LANGUAGE = "",
LC_ALL = (unset),
LC_ADDRESS = "fi_FI.UTF-8",
LC_NAME = "fi_FI.UTF-8",
LC_MONETARY = "en_FI.UTF-8",
LC_PAPER = "fi_FI.UTF-8",
LC_IDENTIFICATION = "fi_FI.UTF-8",
LC_TELEPHONE = "fi_FI.UTF-8",
LC_MEASUREMENT = "en_FI.UTF-8",
LC_TIME = "en_FI.UTF-8",
LC_NUMERIC = "en_FI.UTF-8",
LANG = "en_US.UTF-8"
perl: warning: Falling back to a fallback locale ("en_US.UTF-8").
Kernel: 6.3.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=0165517f-39a3-4f64-b1f0-99a6388bb854 rw [email protected]
loglevel=3 ibt=off
Type: Laptop System: Razer product: Blade 17 (2022) - RZ09-0423 v: 8.04
Mobo: Razer model: DI780 v: 4 serial: <superuser required> UEFI: Razer
v: 1.07 date: 02/16/2022
ID-1: BAT0 charge: 83.4 Wh (97.8%) condition: 85.3/82.1 Wh (104.0%)
volts: 17.3 min: 15.4 model: Razer Blade type: Unknown serial: <filter>
status: full
Info: model: 12th Gen Intel Core i9-12900H bits: 64 type: MST AMCP
microcode: 0x42A
Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 1985 high: 2900 min/max: 400/4900:5000:3800 scaling:
driver: intel_pstate governor: powersave cores: 1: 734 2: 2900 3: 864
4: 2900 5: 800 6: 2900 7: 920 8: 675 9: 1027 10: 2900 11: 1183 12: 2900
13: 813 14: 2900 15: 785 16: 2900 17: 2900 18: 2900 19: 2900 20: 2900
bogomips: 116736
Device-1: Intel Alder Lake-P Integrated Graphics vendor: Razer USA
driver: i915 v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:46a6
Device-2: NVIDIA GA103M [GeForce RTX 3080 Ti Mobile] vendor: Razer USA
status: current (as of 2023-05) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:2420 class-ID: 0300
Device-3: IMC Networks Integrated RGB Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-8:5 chip-ID: 13d3:5279
s-diag: 1165mm (45.88")
Monitor-1: eDP-1 model: AU Optronics 0x749d built: 2021 res: 3840x2160
hz: 144 dpi: 256 gamma: 1.2 size: 381x214mm (15x8.43") diag: 437mm (17.2")
ratio: 16:9 modes: 3840x2160
API: OpenGL v: 4.6 Mesa 23.0.3 renderer: Mesa Intel Graphics (ADL GT2)
direct-render: Yes
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Razer USA
chip-ID: 8086:51c8 class-ID: 0401
Device-2: NVIDIA vendor: Razer USA driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:2288 class-ID: 0403
API: ALSA v: k6.3.2-zen1-1-zen status: kernel-api with: aoss
Device-1: Intel Alder Lake-P PCH CNVi WiFi vendor: Rivet Networks
driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:51f0 class-ID: 0280
Device-2: Realtek RTL8125 2.5GbE vendor: Razer USA driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 04:00.0
Device-1: Intel driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 3-10:6 chip-ID: 8087:0033 class-ID: e001
Local Storage: total: 4.57 TiB used: 18.44 GiB (0.4%)
model: MZVL21T0HCLR-00B00 size: 953.87 GiB block-size: physical: 512 B
fw-rev: GXA7601Q temp: 39.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:7 vendor: Western Digital
model: WDS400T3X0C-00SJG0 size: 3.64 TiB block-size: physical: 512 B
fw-rev: 114000WD temp: 45.9 C scheme: GPT
ID-1: / raw-size: 31.25 GiB size: 31.25 GiB (100.00%)
used: 18.39 GiB (58.9%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
used: 48.6 MiB (50.6%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 31.25 GiB size: 31.25 GiB (100.00%)
ID-4: /var/log raw-size: 31.25 GiB size: 31.25 GiB (100.00%)
ID-5: /var/tmp raw-size: 31.25 GiB size: 31.25 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.04 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 51.0 C mobo: N/A
Processes: 448 Uptime: 7m wakeups: 4485 Memory: available: 31.04 GiB
used: 7.9 GiB (25.5%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 Packages: pm: pacman pkgs: 1871
libs: 522 tools: octopi,paru Shell: fish v: 3.6.1 running-in: konsole
inxi: 3.3.27
System install date: 2023-05-14
Last full system update: 2023-05-15 ↻
