Sd Card Slot not working
Hey guys, so I'll be straight up and admit that I don't think this issue is related to Garuda although it does happen on Gauda. The reason for this is that it behaves the same on Windows too. Essentially, I have an Asus Vivobook s510ua. It has a port for an sd card which I put a micro sd card into. Micro sd card goes into the sd card adapter which goes into the slot in the laptop. However, when slotting it in, even with different sd cards and different sd card adapters, it isn't detected at all on my laptop. So I was hoping someone might have an idea if the port is dead or a way to troubleshoot this possibly? Thanks
  Kernel: 5.18.0-3-bore arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-bore
    root=UUID=95b636ca-42a5-47b4-9b7a-038581af6cdf rw rootflags=subvol=@
    resume=UUID=41193397-191d-45b5-8c2b-405cf71e73b2 loglevel=3
    wm: kwin_wayland vt: 2 dm: SDDM Distro: Garuda Linux base: Arch Linux
  Type: Laptop System: ASUSTeK product: X510UA v: 1.0
  Mobo: ASUSTeK model: X510UA v: 1.0 serial: <superuser required>
    UEFI: American Megatrends v: X510UA.312 date: 04/29/2020
  ID-1: BAT0 charge: 21.1 Wh (71.0%) condition: 29.7/42.1 Wh (70.6%)
    volts: 11.5 min: 11.5 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
    status: discharging cycles: 481
  Info: model: Intel Core i7-7500U bits: 64 type: MT MCP
    arch: Amber/Kaby Lake note: check family: 6 model-id: 0x8E (142)
    stepping: 9 microcode: 0xF0
    L3: 4 MiB desc: 1x4 MiB
  Speed (MHz): avg: 509 high: 514 min/max: 400/3500 scaling:
    driver: intel_pstate governor: powersave cores: 1: 503 2: 507 3: 514 4: 513
    bogomips: 23220
  Type: l1tf
  Device-1: Intel HD Graphics 620 vendor: ASUSTeK driver: i915 v: kernel
    ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:5916
  Device-2: IMC Networks VGA UVC WebCam type: USB driver: uvcvideo
    bus-ID: 1-6:2 chip-ID: 13d3:5a07 class-ID: 0e02 serial: <filter>
  Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.2
    alternate: fbdev,intel,vesa gpu: i915 display-ID: 0
  OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 22.1.0
    direct render: Yes
  Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK
  Sound Server-1: ALSA v: k5.18.0-3-bore running: yes
  Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:24fd class-ID: 0280
    bus-ID: 1-8:3 chip-ID: 8087:0a2b class-ID: e001
    address: <filter>
  Local Storage: total: 931.52 GiB used: 184.28 GiB (19.8%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 500GB
  ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO M.2 500GB
  ID-1: / raw-size: 448.4 GiB size: 448.4 GiB (100.00%)
    used: 86.09 GiB (19.2%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
    used: 32.1 MiB (10.7%) fs: vfat dev: /dev/sda1 maj-min: 8:1
  ID-3: /home raw-size: 448.4 GiB size: 448.4 GiB (100.00%)
  ID-4: /var/log raw-size: 448.4 GiB size: 448.4 GiB (100.00%)
  ID-5: /var/tmp raw-size: 448.4 GiB size: 448.4 GiB (100.00%)
  ID-1: swap-1 type: zram size: 15.52 GiB used: 2 MiB (0.0%) priority: 100
  ID-2: swap-2 type: partition size: 17.06 GiB used: 0 KiB (0.0%)
  System Temperatures: cpu: 57.0 C pch: 37.5 C mobo: N/A
  Fan Speeds (RPM): cpu: 2500
  Processes: 253 Uptime: 13m wakeups: 1 Memory: 15.52 GiB
  used: 3.27 GiB (21.1%) Init: systemd v: 251 tool: systemctl Compilers:
  gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1564 lib: 374 Shell: fish
  v: 3.4.1 running-in: yakuake inxi: 3.3.16
Garuda (2.6.3-2):
  System install date:     2022-05-27
  Last full system update: 2022-05-31
  Failed units:            systemd-sysctl.service
M$ and Garuda, hardware fault, or clean the slot :wink:
Did you search in Internet?
Remember, we are not the personal search engine for Garuda users here.
Yeah I know I'm not that much of a noob haha. I did Google around as much as I could and looked through my bios but nothing there. I understand it's likely a hardware problem with the port due to testing multiple adapters and SD cards. Thought I'd just ask on the off chance someone knows some magical spell or something to fix it
I'm not really sure your model has the same card reader, anyway, just an idea:
https://wiki.archlinux.org/title/ASUS_A55VJ#Card_reader
You can use lsusb or lspci to show the device - depending on how it's connected internally. Find it in the list, then search for the device's ID.
Nevermind I fixed it haha. I'd already tried cleaning it with no luck. However, I found some weird little bristle brush and a long piece of bendy plastic and I just shoved it in there and jiggled it around and shook the laptop and prayed and it worked :sweat_smile:
Sorry for wasting your guy's time. I really thought it was something in the BIOS potentially as I'd really tried cleaning vigorously already. Maybe I just got some random luck this time. This has been bothering me for literal months like I'm so pissed it was this easy to fix
No worries, it's a learning experience! Don't forget to mark your solution so the thread closes and is found by any others searching for a similar issue.
Yeah done thanks haha. People here know by now that I tend to work out my problem after posting an issue here. It's weird though like nothing I tried before worked and then suddenly I made a post here and it starts working. Damn technology. Anyway cheers :sweat_smile:
It typically is. Fastboot or its ilk can be set to skip hardware checks at boot, and so sometimes Windows will willy-nilly decide your hardware is not what it is and change that in the BIOS. It happened to me with the BT adaptor on this 2019 9th Gen desktop rig.
So you were correct in first thinking about the BIOS, in my humble opinion, but now that we know about your atrocious housekeeping, we’ll bear that in mind in future.
:stuck_out_tongue_winking_eye:
