Garuda Hyprland running (on a Home Windows 11 PC) from a 64 GB HP Pendrive :heart_eyes:
R/W speed is slow so updates/installs are slow AF but that was expected!
BTW, my main laptop with broken display has KDE…
Better specs than mine, Ima slowly steal it!
  Kernel: 6.8.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=363d4ac6-8a4c-416f-bbdb-b8f59c838907 rw rootflags=subvol=@
  Desktop: Hyprland v: 0.37.1-34-g4c796683 with: waybar tools:
    avail: swayidle,swaylock vt: 1 dm: SDDM Distro: Garuda base: Arch Linux
  Type: Laptop System: LENOVO product: 81UT v: Lenovo IdeaPad S145-15API
    serial: <superuser required> Chassis: type: 10 v: Lenovo IdeaPad S145-15API
  Mobo: LENOVO model: LNVNB161216 v: SDK0Q55724WIN
    part-nu: LENOVO_MT_81UT_BU_idea_FM_IdeaPad S145-15API
    uuid: <superuser required> UEFI: LENOVO v: BUCN33WW date: 05/12/2022
  ID-1: BAT0 charge: 12.1 Wh (39.5%) condition: 30.6/35.3 Wh (86.6%)
    power: 15.5 W volts: 8.0 min: 7.6 model: CPT-COS L16C2PB1 type: Li-poly
    serial: <filter> status: charging cycles: 891
  Info: model: AMD Ryzen 3 3200U with Radeon Vega Mobile Gfx bits: 64
    stepping: 1 microcode: 0x8108102
    L1: 192 KiB desc: d-2x32 KiB; i-2x64 KiB L2: 1024 KiB desc: 2x512 KiB
    L3: 4 MiB desc: 1x4 MiB
  Speed (MHz): avg: 1363 high: 1400 min/max: 1400/2600 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1400 2: 1252
    3: 1400 4: 1400 bogomips: 20760
    vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5 code: Vega
    ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 02:00.0 chip-ID: 1002:15d8
    class-ID: 0300 temp: 53.0 C
  Device-2: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 04f2:b624
    compositor: Hyprland v: 0.37.1-34-g4c796683 driver: X: loaded: amdgpu
    unloaded: modesetting alternate: fbdev,vesa dri: radeonsi gpu: amdgpu
    display-ID: 1
  Monitor-1: eDP-1 model: BOE Display 0x0812 built: 2018 res: 1920x1080
    hz: 60 dpi: 142 gamma: 1.2 scale: 1 size: 344x194mm (13.54x7.64")
  API: Vulkan v: 1.3.279 layers: 3 device: 0 type: integrated-gpu name: AMD
    Radeon Vega 3 Graphics (RADV RAVEN) driver: mesa radv v: 24.0.3-arch1.1
    device-ID: 1002:15d8 surfaces: xcb,xlib,wayland device: 1 type: cpu
    v: 24.0.3-arch1.1 (LLVM 17.0.6) device-ID: 10005:0000
  Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Lenovo
    bus-ID: 02:00.1 chip-ID: 1002:15de class-ID: 0403
  Device-2: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 02:00.6
  API: ALSA v: k6.8.1-zen1-1-zen status: kernel-api tools: N/A
  Server-2: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse
  Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
    vendor: Lenovo driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 bus-ID: 01:00.0 chip-ID: 168c:0042 class-ID: 0280
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-2:3 chip-ID: 0cf3:e500
  Local Storage: total: 989.28 GiB used: 10.14 GiB (1.0%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10SPZX-24Z10
    tech: HDD rpm: 5400 serial: <filter> fw-rev: 1A05 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: HP model: USB Flash Drive
    size: 57.77 GiB block-size: physical: 512 B logical: 512 B type: USB
    rev: 2.0 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: SSD serial: <filter>
    fw-rev: PMAP scheme: GPT
  ID-1: / raw-size: 57.46 GiB size: 57.46 GiB (100.00%)
    used: 10.14 GiB (17.6%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
    used: 584 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
  ID-3: /home raw-size: 57.46 GiB size: 57.46 GiB (100.00%)
  ID-4: /var/log raw-size: 57.46 GiB size: 57.46 GiB (100.00%)
  ID-5: /var/tmp raw-size: 57.46 GiB size: 57.46 GiB (100.00%)
  ID-1: swap-1 type: zram size: 5.66 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 51.2 C mobo: N/A gpu: amdgpu temp: 51.0 C
  Memory: total: 6 GiB available: 5.66 GiB used: 1.78 GiB (31.5%)
  Processes: 195 Power: uptime: 17m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 2.26 GiB Init: systemd v: 255
  Packages: pm: pacman pkgs: 1245 libs: 404 tools: paru Compilers:
    gcc: 13.2.1 Shell: garuda-inxi default: fish v: 3.7.0 running-in: foot
    inxi: 3.3.33
Garuda (2.6.23-1):
  System install date:     2024-03-21
  Last full system update: 2024-03-21
Yeah, I am that one emacs user. :moyai:
Ayo one of us
Once you go Emacs you can never go back :melting_face:
I love Emacs! It’s my WM and has been for years! One of us! One of us!!
गरु‍ड़ लिनक्स के लिए स्वनिर्मित वॉलपेपर
Very nice!
Unfortunately, I can’t read the text except for the OM at the end. Is that a mantra?
The text is basically “garuda linux operating system” typed in hindi. As for om yes it’s considered sound of universe.
Om Suasti Astu
Thanks for the explanation.
Om Canti Canti Canti Om
So you are writing in Hinglish, but you don’t know hindi …:stuck_out_tongue:
Edit : Hinglish is not any actual language but a Hybrid of English and Hindi so…sometimes it makes you crazy :crazy_face:
Summary
13
Not Hinglish, this is Balinese!
Back to my older wallpaper collections :slightly_smiling_face:
Finally made the gruvbox theme i wanted :slight_smile:
Seems there is no FireDragon/Floorp Web Browser icon we can use. :smiley:
Gee, I wonder if anybody knows some artist adept at icon creation?
Unfortunately, this is a font. :smiley:
But maybe @Ankur will find something suitable.
Ahh… I don’t have any good suggestions :
:dragon_face: :dragon: :fire:
well, I think it’s okay whatever is already there :slightly_smiling_face:
:fire: :dragon:
is a solution :smiley:
I think if you all keep talking :fire: and :dragon: 's I’m gonna call the fire department, then the nuthouse, in that order.
You people are dangerous! :smiley:
