Screen sharing advice appreciated
I saw a closed post on this topic from 6/2023, but I did not see a resolution.
I noticed that screen sharing may not be working in the standard Discord app installed with Octopi. My version is up to date. Everything else about the app seems to be working fine. I do get some options of what to share (rectangular area, screen, etc). When I click on these, I can sometimes get a normal window that indicates shared screen (but my friend in Discord said nothing was visible) and if I then close the streaming when I try to restart streaming the even the choices disappear and a prolonged sort of “looking for streaming device” window is open with no options. I tried to see if I could just use Discord as a tab in Firefox and stream from there, but it appears support for screen sharing in Firefox is no longer present, at least there is no longer any option to click on in the bars next to the address box or in settings to enable. Finally, I git cloned the Webcord third-party client for Discord, as it was supposed to have support for Wayland screen streaming (according to what I read), but when I tried to stream on it, there is a black screen and no way to get out of it but to shut down the app. Does anyone have a way share do screen sharing that is not cumbersome? I saw many videos about more elaborate work-arounds.
Is this an option:? XDG Desktop Portal - ArchWiki.
Thanks.
Barry
╭─bmirtsching@DellT5810 in ~
╰─λ garuda-inxi
LANGUAGE = "",
LC_ALL = (unset),
LC_ADDRESS = "en_US.UTF-8",
LC_NAME = "en_US.UTF-8",
LC_MONETARY = "en_US.UTF-8",
LC_PAPER = "en_US.UTF-8",
LC_IDENTIFICATION = "en_US.UTF-8",
LC_TELEPHONE = "en_US.UTF-8",
LC_MEASUREMENT = "en_US.UTF-8",
LC_TIME = "en_US.UTF-8",
LC_NUMERIC = "en_US.UTF-8",
LANG = "en_US.UTF-8"
perl: warning: Falling back to the standard locale ("C").
Kernel: 6.10.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=73b3631e-3dec-4209-9c71-4928bd70fb46 rw rootflags=subvol=@
quiet rd.luks.uuid=a8e40cc9-41be-4434-8bf9-423936703f72
rd.luks.uuid=f79a930f-07d4-4043-878d-b926518407cc
resume=/dev/mapper/luks-f79a930f-07d4-4043-878d-b926518407cc loglevel=3
Desktop: KDE Plasma v: 6.1.3 tk: Qt v: N/A info: frameworks v: 6.4.0
Type: Desktop System: Dell product: Precision Tower 5810 v: N/A
serial: <superuser required> Chassis: type: 7 serial: <superuser required>
Mobo: Dell model: 0K240Y v: A01 serial: <superuser required> part-nu: 0617
uuid: <superuser required> UEFI-[Legacy]: Dell v: A34 date: 10/19/2020
Info: model: Intel Xeon E5-2687W v4 bits: 64 type: MT MCP arch: Broadwell
level: v3 note: check built: 2015-18 process: Intel 14nm family: 6
model-id: 0x4F (79) stepping: 1 microcode: 0xB000040
L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 3 MiB desc: 12x256 KiB
L3: 30 MiB desc: 1x30 MiB
Speed (MHz): avg: 2916 high: 3500 min/max: 1200/3500 scaling:
driver: intel_cpufreq governor: performance cores: 1: 3500 2: 2143 3: 2670
4: 3500 5: 3500 6: 3500 7: 3500 8: 2491 9: 2406 10: 3500 11: 1794 12: 3500
13: 3500 14: 1403 15: 2472 16: 3500 17: 3500 18: 1934 19: 3500 20: 2278
21: 3283 22: 2056 23: 3071 24: 3500 bogomips: 143656
vendor: Tul / PowerColor driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: HDMI-A-1 empty: DP-1, DP-2, DP-3, Writeback-1
bus-ID: 04:00.0 chip-ID: 1002:73df class-ID: 0300
Monitor-1: HDMI-A-1 res: 3440x1440 size: N/A modes: N/A
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.4-arch1.2
navi22 LLVM 18.1.8 DRM 3.57 6.10.1-zen1-1-zen) device-ID: 1002:73df
API: Vulkan v: 1.3.279 layers: 14 device: 0 type: discrete-gpu name: AMD
Radeon RX 6700 XT (RADV NAVI22) driver: mesa radv v: 24.1.4-arch1.2
device-ID: 1002:73df surfaces: xcb,xlib,wayland
Device-1: Intel C610/X99 series HD Audio vendor: Dell driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8d20 class-ID: 0403
Device-2: Creative Labs CA0132 Sound Core3D [Sound Blaster Recon3D /
Z-Series BlasterX AE-5 Plus] driver: snd_hda_intel v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 1102:0012 class-ID: 0403
Device-3: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 04:00.1 chip-ID: 1002:ab28
Device-4: SteelSeries ApS Arctis 1 Wireless
lanes: 1 mode: 1.1 bus-ID: 3-3:4 chip-ID: 1038:12b3 class-ID: 0300
API: ALSA v: k6.10.1-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.1 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I217-LM vendor: Dell driver: e1000e v: kernel
port: f020 bus-ID: 00:19.0 chip-ID: 8086:153a class-ID: 0200
IF: enp0s25 state: up speed: 1000 Mbps duplex: full mac: <filter>
speed: 5 GT/s lanes: 1 bus-ID: 0c:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp12s0 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-9:5 chip-ID: 8087:0029
Hardware-1: Intel SATA Controller [RAID Mode] driver: ahci v: 3.0 port: f000
bus-ID: 00:1f.2 chip-ID: 8086:2826 rev: N/A class-ID: 0104
Local Storage: total: 1.03 TiB used: 948.82 GiB (90.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: THNSNJ128GCSU
tech: SSD serial: <filter> fw-rev: 0101 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Hitachi model: HDS721010KLA330
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: N/A serial: <filter> fw-rev: A9CA scheme: GPT
ID-1: / raw-size: 84.84 GiB size: 84.84 GiB (100.00%)
used: 50.59 GiB (59.6%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-a8e40cc9-41be-4434-8bf9-423936703f72
ID-2: /home raw-size: 84.84 GiB size: 84.84 GiB (100.00%)
ID-3: /var/log raw-size: 84.84 GiB size: 84.84 GiB (100.00%)
ID-4: /var/tmp raw-size: 84.84 GiB size: 84.84 GiB (100.00%)
ID-1: swap-1 type: partition size: 34.4 GiB used: 0 KiB (0.0%)
mapped: luks-f79a930f-07d4-4043-878d-b926518407cc
ID-2: swap-2 type: zram size: 31.26 GiB used: 256 KiB (0.0%) priority: 100
System Temperatures: cpu: 49.0 C mobo: N/A sodimm: SODIMM C gpu: amdgpu
temp: 55.0 C mem: 54.0 C
Fan Speeds (rpm): cpu: 1009 gpu: amdgpu fan: 0
Memory: total: 32 GiB available: 31.26 GiB used: 7.49 GiB (24.0%)
Processes: 556 Power: uptime: 1h 49m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.46 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2199 libs: 609
tools: gnome-software,octopi,paru Compilers: clang: 18.1.8 gcc: 14.1.1
Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole inxi: 3.3.35
System install date:     2024-07-08
Last full system update: 2024-07-30 ↻
I was able to get Firefox browser screen sharing of Discord to work. The privacy setting of strict (vs normal) does not allow the site to request permissions for screen sharing to the browswer. Normal privacy mode does.
I was able to get Webcord to stream as well, but as expected, not the Discord app (as it does not apparently have support for streaming on Wayland). Not sure what enabled it to begin to work, as I did not change any privacy or permissions.
