Screen lock does not unlock and gets stuck at lock screen after locking or doing screen lock
After updating garuda linux kernel to 6.11.5-zen1-1-zen. when i perform screen lock and then try to unlock the screen lock by entering the login password the screen lock does not unlock and gets stuck at lock screen. then i am forced to shut down the system by pressing power button. please provide a solution to this problem.
I tried this commad:
sudo sddm --config /etc/sddm.conf --reset
but nothing changed.
Here is the output of garuda-inxi:
Kernel: 6.11.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=199ac3e3-ffce-4fdb-8d7f-2ccd29ec7ee4 rw rootflags=subvol=@
quiet resume=UUID=2fc8d77f-163a-4865-989e-f3658df8808f loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.2.1 tk: Qt v: N/A info: frameworks v: 6.7.0
wm: kwin_x11 tools: avail: lxlock vt: 2 dm: SDDM Distro: Garuda
Type: Laptop System: Acer product: Aspire E5-576 v: V1.49
Mobo: KBL model: Ironman_SK v: V1.49 serial: <superuser required>
part-nu: 0000000000000000 uuid: <superuser required> UEFI: Insyde v: 1.49
date: 12/11/2018
ID-1: BAT1 charge: 22.5 Wh (70.1%) condition: 32.1/32.1 Wh (100.0%)
volts: 15.0 min: 14.6 model: PANASONIC AS16A5K type: Li-ion serial: <filter>
Info: model: Intel Core i3-7100U bits: 64 type: MT MCP arch: Amber/Kaby Lake
note: check gen: core 7 level: v3 note: check built: 2017
process: Intel 14nm family: 6 model-id: 0x8E (142) stepping: 9
microcode: 0xF6
desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 699 min/max: 400/2400 scaling: driver: intel_pstate
governor: powersave cores: 1: 699 2: 699 3: 699 4: 699 bogomips: 19200
Device-1: Intel HD Graphics 620 vendor: Acer Incorporated ALI driver: i915
active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:5916
Device-2: Quanta HD WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:4 chip-ID: 0408:a030
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.3
Monitor-1: eDP-1 model: ChiMei InnoLux 0x15f5 built: 2022 res: 1920x1080
ratio: 16:9 modes: 1920x1080
inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.2.5-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 620 (KBL GT2)
device-ID: 8086:5916 memory: 1.81 GiB unified: yes
API: Vulkan v: 1.3.295 layers: 3 device: 0 type: integrated-gpu name: Intel
HD Graphics 620 (KBL GT2) driver: mesa intel v: 24.2.5-arch1.1
device-ID: 8086:5916 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 18.1.8 256 bits) driver: mesa llvmpipe v: 24.2.5-arch1.1 (LLVM
Device-1: Intel Sunrise Point-LP HD Audio vendor: Acer Incorporated ALI
API: ALSA v: k6.11.5-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.2.5 status: active with: 1: pipewire-pulse
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.1 chip-ID: 10ec:8168
IF: enp3s0f1 state: down mac: <filter>
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:3 chip-ID: 8087:0aa7
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 4.2
Local Storage: total: 1.36 TiB used: 117.27 GiB (8.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT500P3SSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR30A temp: 36.9 C
model: WD10SPZX-21Z10T0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A02 scheme: GPT
ID-1: / raw-size: 34 GiB size: 34 GiB (100.00%) used: 22.12 GiB (65.1%)
ID-2: /boot/efi raw-size: 712 MiB size: 710.6 MiB (99.80%)
used: 51.3 MiB (7.2%) fs: vfat dev: /dev/sda7 maj-min: 8:7
ID-3: /home raw-size: 60.45 GiB size: 60.45 GiB (100.00%)
used: 21.34 GiB (35.3%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
ID-4: /var/log raw-size: 34 GiB size: 34 GiB (100.00%)
used: 22.12 GiB (65.1%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
ID-5: /var/tmp raw-size: 34 GiB size: 34 GiB (100.00%)
ID-1: swap-1 type: zram size: 3.7 GiB used: 1.58 GiB (42.7%) priority: 100
ID-2: swap-2 type: partition size: 3 GiB used: 8.6 MiB (0.3%) priority: -2
System Temperatures: cpu: 40.0 C pch: 39.0 C mobo: N/A
Memory: total: 4 GiB available: 3.7 GiB used: 2.58 GiB (69.7%)
Processes: 247 Power: uptime: 3h 14m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 1.47 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1474 libs: 386 tools: octopi,paru,yay
Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi default: fish
v: 3.7.1 running-in: yakuake inxi: 3.3.36
System install date:     2024-08-27
Last full system update: 2024-10-23
Have you attempted to roll back with your snapshots in Grub? not a perfect solution, but, at-least the system will be functioning like it did prior to the update. Otherwise, have you tried using TTY to try pulling up a console to login and start your KDE plasma session? I usually find TTY3 works for me, Ctrl + Alt + F3. From the TTY try seeing what the status of the SDDM is with systemctl status sddm , could restart SDDM with systemctl restart sddm and see if that fixes anything.
