Hello.
I'm having issue with my screen going full black and keyboard lighs shutting down after exactly 30 seconds of inactivity. I have checked my GNOME settings for power and "Dim Screen When Inactive" is disabled, "Blank Screen" is set to 10 minutes.
Also nothing is happening in dmseg or journalctl when the screen goes black.
This does not happen when I'm watching a video for some reason.
My install dates from a couple of days so I don't have much comparison with past versions of Garuda.
Does anyone have any idea?
Kind regards,
Post your terminal/konsole in- and output as text (no pictures ) from:
% uname -a
Linux Ma1X-Os-X-Mion 5.14.14-zen1-1-zen #1 ZEN SMP PREEMPT Wed, 20 Oct 2021 21:35:17 +0000 x86_64 GNU/Linux
% lsb_release -a
LSB Version: 1.4
Distributor ID: Garuda
Description: Garuda Linux
Release: Soaring
Codename: Harpy-Eagle
% gsettings get org.gnome.settings-daemon.plugins.power sleep-inactive-ac-timeout
1200
% gsettings get org.gnome.settings-daemon.plugins.power sleep-inactive-battery-timeout
1200
% gsettings get org.gnome.desktop.screensaver idle-activation-enabled
false
Can we have your inxi -Faz please
My bad, here it is:
System: Kernel: 5.14.14-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=92e8dfb4-1622-4b2d-b26b-0d724eab6260 rw
rootflags=subvol=@ quiet
cryptdevice=UUID=3708c014-0e76-4689-bdae-9eecc021ed53:luks-3708c014-0e76-4689-bdae-9eecc021ed53
root=/dev/mapper/luks-3708c014-0e76-4689-bdae-9eecc021ed53 splash rd.udev.log_priority=3 vt.global_cursor_default=0
systemd.unified_cgroup_hierarchy=1 resume=/dev/mapper/luks-582ec2db-05f4-4110-81dd-8ea4c008f299 loglevel=3
Desktop: GNOME 40.5 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1 Distro: Garuda Linux base: Arch Linux
Machine: Type: Laptop System: Dell product: XPS 13 9370 v: N/A serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: Dell model: 0F6P3V v: A00 serial: <filter> UEFI: Dell v: 1.3.3 date: 05/17/2018
Battery: ID-1: BAT0 charge: 51.2 Wh (100.0%) condition: 51.2/52.0 Wh (98.5%) volts: 8.6 min: 7.6
model: LGC-LGC6.73 DELL H754V05 type: Li-ion serial: <filter> status: Full
CPU: Info: Quad Core model: Intel Core i7-8550U bits: 64 type: MT MCP arch: Kaby Lake note: check family: 6
model-id: 8E (142) stepping: A (10) microcode: EA cache: L2: 8 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 31999
Speed: 3852 MHz min/max: 400/4000 MHz Core speeds (MHz): 1: 3852 2: 3722 3: 3942 4: 3740 5: 3712 6: 3933 7: 3916
8: 3728
Graphics: Device-1: Intel UHD Graphics 620 vendor: Dell driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:5917
Device-2: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo bus-ID: 1-5:2 chip-ID: 0bda:58f4 class-ID: 0e02
Display: x11 server: X.Org 1.20.13 compositor: gnome-shell driver: loaded: intel unloaded: modesetting
alternate: fbdev,vesa display-ID: :1 screens: 1
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 168 size: 290x160mm (11.4x6.3") diag: 331mm (13")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.2.4 direct render: Yes
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel v: kernel alternate: snd_soc_skl
Sound Server-1: ALSA v: k5.14.14-zen1-1-zen running: yes
Network: Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter vendor: Rivet Networks Killer 1435 Wireless-AC
driver: ath10k_pci v: kernel bus-ID: 02:00.0 chip-ID: 168c:003e class-ID: 0280
Bluetooth: Device-1: Foxconn / Hon Hai type: USB driver: btusb v: 0.8 bus-ID: 1-7:3 chip-ID: 0489:e0a2 class-ID: e001
Drives: Local Storage: total: 476.94 GiB used: 24.23 GiB (5.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: PC401 NVMe 512GB size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 80003E00 temp: 43.9 C
Partition: ID-1: / raw-size: 459.79 GiB size: 459.79 GiB (100.00%) used: 24.23 GiB (5.3%) fs: btrfs dev: /dev/dm-0
maj-min: 254:0 mapped: luks-3708c014-0e76-4689-bdae-9eecc021ed53
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 706 KiB (0.3%) fs: vfat dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 459.79 GiB size: 459.79 GiB (100.00%) used: 24.23 GiB (5.3%) fs: btrfs dev: /dev/dm-0
ID-4: /var/log raw-size: 459.79 GiB size: 459.79 GiB (100.00%) used: 24.23 GiB (5.3%) fs: btrfs dev: /dev/dm-0
ID-5: /var/tmp raw-size: 459.79 GiB size: 459.79 GiB (100.00%) used: 24.23 GiB (5.3%) fs: btrfs dev: /dev/dm-0
ID-1: swap-1 type: zram size: 15.35 GiB used: 2.83 GiB (18.5%) priority: 100 dev: /dev/zram0
ID-2: swap-2 type: partition size: 16.88 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/dm-1 maj-min: 254:1
mapped: luks-582ec2db-05f4-4110-81dd-8ea4c008f299
Sensors: System Temperatures: cpu: 63.0 C mobo: 38.0 C sodimm: SODIMM C
Fan Speeds (RPM): cpu: 0
Info: Processes: 390 Uptime: 1d 21h 10m wakeups: 21044 Memory: 15.35 GiB used: 10.72 GiB (69.8%) Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1286 lib: 344 Shell: Zsh v: 5.8
running-in: tmux: inxi: 3.3.08
filo
29 October 2021 16:00
4
I’d consider an update here.
I think (just a quick search) the current version should be 1.16.0 released on 24 sep 2021.
I usually consider it just my “obsession”, but in this case, since all drivers, packages, etc. are up to date / rolling, I would start from here…
I performed the upgrade.
At first, I though it did the trick but the problem came back.
It seems to be ok after a reboot "for some time" until it comes back.
Mobo: Dell model: 0F6P3V v: A00 serial: <filter> UEFI: Dell v: 1.16.0 date: 07/09/2021
Battery: ID-1: BAT0 charge: 47.2 Wh (92.2%) condition: 51.2/52.0 Wh (98.5%) volts: 8.5 min: 7.6
model: LGC-LGC6.73 DELL H754V05 type: Li-ion serial: <filter> status: Charging
Speed: 3814 MHz min/max: 400/4000 MHz Core speeds (MHz): 1: 3814 2: 3923 3: 3958 4: 3991 5: 3779 6: 3977 7: 3968
8: 3927
Drives: Local Storage: total: 476.94 GiB used: 24.78 GiB (5.2%)
Partition: ID-1: / raw-size: 459.79 GiB size: 459.79 GiB (100.00%) used: 24.75 GiB (5.4%) fs: btrfs dev: /dev/dm-0
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 32.9 MiB (12.8%) fs: vfat dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 459.79 GiB size: 459.79 GiB (100.00%) used: 24.75 GiB (5.4%) fs: btrfs dev: /dev/dm-0
ID-4: /var/log raw-size: 459.79 GiB size: 459.79 GiB (100.00%) used: 24.75 GiB (5.4%) fs: btrfs dev: /dev/dm-0
ID-5: /var/tmp raw-size: 459.79 GiB size: 459.79 GiB (100.00%) used: 24.75 GiB (5.4%) fs: btrfs dev: /dev/dm-0
ID-1: swap-1 type: zram size: 15.35 GiB used: 1024 KiB (0.0%) priority: 100 dev: /dev/zram0
Info: Processes: 313 Uptime: 14h 19m wakeups: 22397 Memory: 15.35 GiB used: 9.51 GiB (62.0%) Init: systemd v: 249
SGS
31 October 2021 08:04
6
filo
31 October 2021 08:23
7
Maybe you could try
xset -dpms
according to this suggestion here
Maybe first check what this is all about, at least how to revert It, since I never trust reddit posts with blind eyes...
system
Closed
3 November 2021 19:40
8
