Hi everybody!
For like 1 month I have a problem with Garuda Linux. My screen is randomly blurring away.
Randomly my screen goes away, it will not be black, it will be blurry, but very - very blurred, I am just seeing the main colors of what would be on the screen.
I don't have a picture about it, but if It will happen next time, I am going to take a picture.
If this glitch happens, I can control the PC but I can't really see much, so I just hard reset my PC.
I just updated my system too!
What would be the solution for this? Or is there like a key bind for refreshing drivers, like Windows has? It would maybe a kind of half solution for my problem - it is really annoying.
My inxi -Faz
output:
System: Kernel: 5.15.7-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=e1fd8aa5-3909-4e25-beac-5e11b1b3a928
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Desktop Mobo: ASUSTeK model: STRIX B250G GAMING v: Rev X.0x serial: <superuser required>
UEFI: American Megatrends v: 0809 date: 07/07/2017
CPU: Info: Quad Core model: Intel Core i5-7500 bits: 64 type: MCP arch: Kaby Lake family: 6
model-id: 9E (158) stepping: 9 microcode: EA cache: L1: 256 KiB L2: 1024 KiB L3: 6 MiB
flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 27199
Speed: 3637 MHz min/max: 800/3800 MHz Core speeds (MHz): 1: 3637 2: 3708 3: 3734 4: 3692
mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: disabled, RSB filling
Graphics: Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: ASUSTeK driver: nvidia v: 495.46
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1c03 class-ID: 0300
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver: loaded: nvidia
unloaded: modesetting alternate: fbdev,nouveau,nv,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 5520x1163 s-dpi: 88 s-size: 1594x335mm (62.8x13.2") s-diag: 1629mm (64.1")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 82 size: 598x336mm (23.5x13.2") diag: 686mm (27")
Monitor-2: HDMI-1 res: 1920x1080 hz: 60 dpi: 82 size: 598x336mm (23.5x13.2") diag: 686mm (27")
Monitor-3: DP-1 res: 1680x1050 dpi: 91 size: 470x300mm (18.5x11.8") diag: 558mm (22")
Audio: Device-1: Intel 200 Series PCH HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 00:1f.3 chip-ID: 8086:a2f0 class-ID: 0403
Device-2: NVIDIA GP106 High Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 01:00.1 chip-ID: 10de:10f1 class-ID: 0403
Device-3: Kingston HyperX Cloud II Wireless type: USB driver: hid-generic,snd-usb-audio,usbhid
bus-ID: 1-7:3 chip-ID: 0951:1718 class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.15.7-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.41 running: yes
Network: Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel port: N/A
bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
Drives: Local Storage: total: 1.02 TiB used: 43.36 GiB (4.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SUV400S37120G size: 111.79 GiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 87RA
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD10EZRZ-00HTKB0 size: 931.51 GiB
serial: <filter> rev: 1A01 scheme: GPT
Partition: ID-1: / raw-size: 111.53 GiB size: 111.53 GiB (100.00%) used: 41.66 GiB (37.3%) fs: btrfs
dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.45%) used: 562 KiB (0.2%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 111.53 GiB size: 111.53 GiB (100.00%) used: 41.66 GiB (37.3%) fs: btrfs
ID-4: /var/log raw-size: 111.53 GiB size: 111.53 GiB (100.00%) used: 41.66 GiB (37.3%)
ID-5: /var/tmp raw-size: 111.53 GiB size: 111.53 GiB (100.00%) used: 41.66 GiB (37.3%)
ID-1: swap-1 type: zram size: 15.57 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 55 C
Info: Processes: 270 Uptime: 17m wakeups: 1 Memory: 15.57 GiB used: 4.36 GiB (28.0%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 Packages: 1456 pacman: 1449 lib: 334 snap: 7
Shell: fish v: 3.3.1 default: Bash v: 5.1.12 running-in: konsole inxi: 3.3.09
Thanks if your read it all! I hope, that someone can help me.
