Hello.
I'm experiencing random crashes/freezes on Garuda i3. It doesn't happen specific times or when i open specific applications. But it happened several times while I was on Mailspring mail client.
Also it can happen 2-3 times a day and then it can happen again after a week... It's random completely.
inxi -Faz
System: Kernel: 5.15.6-zen2-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=ce118470-4f53-49b9-b500-9ddd71f75162 rw
Desktop: i3 4.20.1 info: i3bar vt: 7 dm: LightDM 1.30.0 Distro: Garuda Linux base: Arch Linux
Machine: Type: Desktop Mobo: Micro-Star model: B450-A PRO (MS-7B86) v: 2.0 serial: <superuser required>
UEFI: American Megatrends v: A.21 date: 09/20/2018
CPU: Info: 6-Core model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+ family: 17 (23) model-id: 8 stepping: 2
microcode: 800820D cache: L1: 576 KiB L2: 3 MiB L3: 16 MiB
flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 81590
Speed: 3243 MHz min/max: 1550/3400 MHz boost: enabled Core speeds (MHz): 1: 3243 2: 3278 3: 3790 4: 3778 5: 3801
6: 3798 7: 3457 8: 3495 9: 3724 10: 3770 11: 3772 12: 3776
Graphics: Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: Micro-Star MSI driver: nvidia v: 495.44
alternate: nouveau,nvidia_drm bus-ID: 1c:00.0 chip-ID: 10de:1c82 class-ID: 0300
Display: x11 server: X.Org 1.21.1.1 driver: loaded: nvidia unloaded: modesetting alternate: fbdev,nouveau,nv,vesa
Screen-1: 0 s-res: 1920x1080 s-dpi: 101 s-size: 483x272mm (19.0x10.7") s-diag: 554mm (21.8")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 82 size: 598x336mm (23.5x13.2") diag: 686mm (27")
Audio: Device-1: NVIDIA GP107GL High Definition Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
bus-ID: 1c:00.1 chip-ID: 10de:0fb9 class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
bus-ID: 1e:00.3 chip-ID: 1022:1457 class-ID: 0403
Sound Server-1: ALSA v: k5.15.6-zen2-1-zen running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI driver: r8169 v: kernel
port: f000 bus-ID: 18:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp24s0 state: up speed: 100 Mbps duplex: full mac: <filter>
IF-ID-1: br-c38dd7569bf8 state: down mac: <filter>
IF-ID-2: br-c473b5e2278b state: down mac: <filter>
IF-ID-3: br-c573e5d4dcb3 state: down mac: <filter>
IF-ID-4: docker0 state: down mac: <filter>
Drives: Local Storage: total: 1.59 TiB used: 103.1 GiB (6.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SA2000M8500G size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: S5Z42105 temp: 32.9 C scheme: MBR
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 250GB size: 232.89 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 1B6Q scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD10EZEX-08WN4A0 size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: 1A02 scheme: GPT
Partition: ID-1: / raw-size: 195.31 GiB size: 195.31 GiB (100.00%) used: 28.62 GiB (14.7%) fs: btrfs dev: /dev/nvme0n1p3
maj-min: 259:3
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 596 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 254.16 GiB size: 254.16 GiB (100.00%) used: 21.29 GiB (8.4%) fs: btrfs dev: /dev/nvme0n1p4
maj-min: 259:4
ID-4: /var/log raw-size: 195.31 GiB size: 195.31 GiB (100.00%) used: 28.62 GiB (14.7%) fs: btrfs
ID-5: /var/tmp raw-size: 195.31 GiB size: 195.31 GiB (100.00%) used: 28.62 GiB (14.7%) fs: btrfs
ID-1: swap-1 type: zram size: 31.36 GiB used: 2.2 MiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: Message: No sensor data found. Is lm-sensors configured?
Info: Processes: 384 Uptime: 51m wakeups: 0 Memory: 31.36 GiB used: 8.65 GiB (27.6%) Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 Packages: pacman: 1460 lib: 335 Shell: Zsh v: 5.8 running-in: electron inxi: 3.3.09
Also I have experienced frame rate drops or general lag when sometimes I open private Firefox browser and play YouTube music. I don't know if this has something to do.
