norbertom8:
I ran xrandr
Post xrandr output, please, unless it’s private.
You should realize that the problem is unique to your HW, either the HW model, or a malfunction.
We are just trying to do the impossible .
At this phase, there are two things I can comment.
The problem lies in the kernel, not Xorg (so xrandr can only provide some pointers, not the solution)
It is possible to relate to plymouth indirectly, since plymouth pops up in that phase and uses graphics.
As from the above, you may try some things.
Disable plymouth (it is complicated, so maybe someone else has the patience to give instructions, or you read Archwiki, or search the forum).
Remove gpu modules from mkinitcpio.conf MODULES array
Tip: grep "^MODULES" /etc/mkinitcpio.conf
Need to run mkinitcpio -P after edit.
Install other kernel(s) to test (at least linux-lts)
Prefer GRUB_GFXPAYLOAD_LINUX=text in grub settings, as I feel the moon is against you
Definitely post xrandr output.
Here it goes...
.%;888:8898898: b0n3x@b0n3x-1201101es
x;XxXB%89b8:b8%b88: ---------------------
.8Xxd 8X:. OS: Garuda Linux x86_64
.8Xx; 8x:. Kernel: 5.12.4-zen1-2-zen
.tt8x .d x88; Uptime: 0 mins
.@8x8; .db: xx@;
,tSXX° .bbbbbbbbbbbbbbbbbbbB8x@; Packages: 1203 (pacman)
.SXxx bBBBBBBBBBBBBBBBBBBBbSBX8; Shell: fish
,888S pd! Resolution: 1600x900
8X88/ q Terminal: konsole
GBB.
x%88 d888@8@X@X@X88X@@XX@@X@8@X. CPU: Intel Pentium(R) G630 (2) @ 2.7GHz
dxXd dB8b8b8B8B08bB88b998888b88x. Memory: 996MiB / 3839MiB (25%)
dxx8o .@@;.
dx88 .t@x.
d:SS@8ba89aa67a853Sxxad.
.d988999889889899dd.
╭─b0n3x@b0n3x in ~
╰─λ xrandr
Screen 0: minimum 8 x 8, current 1600 x 900, maximum 32767 x 32767
eDP1 connected primary 1600x900+0+0 (normal left inverted right x axis y axis) 440mm x 250mm
1600x900 58.03*+
1400x900 59.96 59.88
1368x768 59.88 58.00 59.85
1360x768 61.53
1280x800 59.81 59.91
1280x720 59.86 58.00 59.74
1024x768 60.00
1024x576 59.90 58.00 59.82
960x540 59.63 58.00 59.82
800x600 60.32 56.25
864x486 59.92 58.00 59.57
800x450 58.00
640x480 59.94
720x405 59.51 58.99 58.00
640x360 59.84 59.32 58.00
VGA1 disconnected (normal left inverted right x axis y axis)
VIRTUAL1 disconnected (normal left inverted right x axis y axis)
╭─b0n3x@b0n3x in ~ took 88ms
╰─λ
Best advice: Buy a different machine for your daughter. You can find much newer ones cheap.
norbertom8:
Here it goes…
Are you planning to answer one question a day?
True, thank you all for your help.
I will buy another machine as soon as I sell this one.
Take care. I¡m on lock down with my kids until 8th June duh... too bad, lol
Kind regards and thanks again.
Norbert
You take care, as well. Stay safe, mask up, get vaccinated as soon as you can. And don’t let the kids drive you crazy.
system
Closed
1 June 2021 10:15
47
