Screen Edge Window Tiling Vertical Monitor
I recently moved to using Garuda and I can’t figure out how to get window tiling on my vertical monitor to work the way I would like. On my main horizontal monitor, it is no problem getting apps to work with the standard screen edge (dragging windows to the left and right edge to have them take up half the screen), but with my vertical monitor this makes it tile vertically, rather then being able to drag it to the top/bottom edge to tile horizontally.
Kernel: 6.18.2-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=61871416-3b06-49a9-9fd4-4bc07c91da68 rw rootflags=subvol=@
quiet loglevel=3
Desktop: KDE Plasma v: 6.5.4 tk: Qt v: N/A info: frameworks v: 6.21.0
Type: Desktop Mobo: ASRock model: X570 Taichi serial: <superuser required>
uuid: <superuser required> Firmware: UEFI vendor: American Megatrends
v: P5.60 date: 01/18/2024
Info: model: AMD Ryzen 7 5700X3D bits: 64 type: MT MCP arch: Zen 3+ gen: 3
model-id: 0x21 (33) stepping: 2 microcode: 0xA201211
desc: 8x512 KiB L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 575 min/max: 575/3001 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 575 2: 575 3: 575
4: 575 5: 575 6: 575 7: 575 8: 575 9: 575 10: 575 11: 575 12: 575 13: 575
14: 575 15: 575 16: 575 bogomips: 96004
ssse3 svm
Device-1: Advanced Micro Devices [AMD/ATI] Navi 22 [Radeon RX 6700/6700
XT/6750 XT / 6800M/6850M XT] vendor: ASRock driver: amdgpu v: kernel
gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-1,DP-2
empty: DP-3,HDMI-A-1,Writeback-1 bus-ID: 10:00.0 chip-ID: 1002:73df
Device-2: Polycom Poly Studio P5 webcam
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-5.1:8 chip-ID: 095d:9296
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu d-rect: 5120x2880
display-ID: 0
Monitor-1: DP-1 pos: bottom-r model: Gigabyte G32QC A serial: <filter>
built: 2023 res: mode: 2560x1440 hz: 165 scale: 100% (1) dpi: 93 gamma: 1.2
max: 2560x1440 min: 640x480
Monitor-2: DP-2 pos: primary,top-left model: Gigabyte G27Q
serial: <filter> built: 2023 res: mode: 2560x1440 hz: 144 scale: 178% (1.78)
to: 1440x2560 dpi: 108 gamma: 1.2 size: 598x336mm (23.54x13.23")
diag: 685mm (27") ratio: 16:9 modes: max: 2560x1440 min: 720x400
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.3.2-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6750 XT (radeonsi
navi22 LLVM 21.1.6 DRM 3.64 6.18.2-zen2-1-zen) device-ID: 1002:73df
API: Vulkan v: 1.4.335 layers: 14 device: 0 type: discrete-gpu name: AMD
Radeon RX 6750 XT (RADV NAVI22) driver: mesa radv v: 25.3.2-arch1.1
device-ID: 1002:73df surfaces: N/A device: 1 type: cpu name: llvmpipe
(LLVM 21.1.6 256 bits) driver: mesa llvmpipe v: 25.3.2-arch1.1 (LLVM
bus-ID: 10:00.1 chip-ID: 1002:ab28 class-ID: 0403
vendor: ASRock driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 12:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: IK Multimedia AXE IO SOLO
lanes: 1 mode: 2.0 bus-ID: 1-6:5 chip-ID: 1963:006e class-ID: 0103
Device-4: KORG nanoKONTROL2 MIDI Controller driver: snd-usb-audio
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:5
chip-ID: 0944:0117 class-ID: 0103
Device-5: Polycom Poly Studio P5 webcam
Device-6: AKAI Professional M.I. MPK mini 3
lanes: 1 mode: 1.1 bus-ID: 5-2:2 chip-ID: 09e8:0049 class-ID: 0103
API: ALSA v: k6.18.2-zen2-1-zen status: kernel-api with: aoss
Device-1: Intel Wi-Fi 6 AX200 vendor: Rivet Networks Killer driver: iwlwifi
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 06:00.0
chip-ID: 8086:2723 class-ID: 0280
IF: wlp6s0 state: up mac: <filter>
Device-2: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 08:00.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-2:3 chip-ID: 8087:0029
Local Storage: total: 6.37 TiB used: 685.66 GiB (10.5%)
fw-rev: 4B2QEXM7 temp: 25.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Crucial model: CT1000P5PSSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P7CR403 temp: 38.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DX002-2DV164
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC41 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT2000BX500SSD1
tech: SSD serial: <filter> fw-rev: 061 scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 680.76 GiB (36.5%)
used: 664 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
used: 680.76 GiB (36.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
System Temperatures: cpu: 31.8 C mobo: N/A gpu: amdgpu temp: 36.0 C
mem: 32.0 C
Memory: total: 16 GiB available: 15.54 GiB used: 2.74 GiB (17.6%)
Processes: 481 Power: uptime: 1m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.2 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1809 libs: 505 tools: octopi,paru Compilers:
gcc: 15.2.1 Shell: Bash v: 5.3.9 default: fish v: 4.3.2 running-in: konsole
inxi: 3.3.40
Garuda (2.11.1-1):
System install date:     2025-12-29
Last full system update: 2025-12-30
25/26 checks run in 0.86 seconds ⌛
Powered by garuda-health 🦅
