Hello Everyone,
Kernel: 6.5.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=0d041406-fe13-41c0-b9f2-4c294e2a1d84 rw rootflags=subvol=@
intel_iommu=on iommu=pt quiet quiet rd.udev.log_priority=3
vt.global_cursor_default=0
resume=UUID=dff8cd6b-a08c-479d-bb33-80f49a2c20cb loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2
Type: Desktop System: Micro-Star product: MS-7C88 v: 1.0
Mobo: Micro-Star model: B460M-A PRO (MS-7C88) v: 1.0
serial: <superuser required> UEFI: American Megatrends v: 1.60
date: 11/30/2020
ID-1: hidpp_battery_0 charge: 29% condition: N/A volts: 3.7 min: N/A
Info: model: Intel Core i5-10400F bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 3 microcode: 0xF8
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 3998 high: 4001 min/max: 800/4300 scaling:
driver: intel_pstate governor: powersave cores: 1: 4000 2: 4000 3: 4000
4: 4000 5: 4000 6: 3994 7: 4000 8: 4001 9: 3992 10: 4000 11: 4000 12: 3998
bogomips: 69597
Device-1: NVIDIA TU106 [GeForce RTX 2060 Rev. A] driver: nvidia
v: 535.104.05 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-08) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1f08 class-ID: 0300
Screen-1: 0 s-res: 4480x1440 s-dpi: 108 s-size: 1054x342mm (41.50x13.46")
s-diag: 1108mm (43.63")
Monitor-1: DP-0 pos: primary,top-right res: 2560x1440 dpi: 109
size: 597x336mm (23.5x13.23") diag: 685mm (26.97") modes: N/A
Monitor-2: DP-2 pos: bottom-l res: 1920x1080 dpi: 81
size: 600x340mm (23.62x13.39") diag: 690mm (27.15") modes: N/A
Monitor-3: None-1-1 size-res: N/A modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 535.104.05 renderer: NVIDIA GeForce RTX
2060/PCIe/SSE2 direct-render: Yes
Device-1: Intel Comet Lake PCH-V cAVS vendor: Micro-Star MSI
bus-ID: 00:1f.3 chip-ID: 8086:a3f0 class-ID: 0403
Device-2: NVIDIA TU106 High Definition Audio driver: snd_hda_intel
chip-ID: 10de:10f9 class-ID: 0403
Device-3: C-Media Blue Snowball driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2.2:6
chip-ID: 0d8c:0005 class-ID: 0300 serial: <filter>
API: ALSA v: k6.5.3-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.80 status: active with: 1: pipewire-pulse
Local Storage: total: 982.99 GiB used: 328.37 GiB (33.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SanDisk
model: SSDPR-PX500-01T-80 size: 953.87 GiB block-size: physical: 512 B
fw-rev: V2.1.3 temp: 54.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 model: Mass Storage Device size: 29.12 GiB
block-size: physical: 512 B logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s
lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: 1.00 scheme: MBR
ID-1: / raw-size: 936.45 GiB size: 936.45 GiB (100.00%)
used: 328.37 GiB (35.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 936.45 GiB size: 936.45 GiB (100.00%)
ID-4: /var/log raw-size: 936.45 GiB size: 936.45 GiB (100.00%)
ID-5: /var/tmp raw-size: 936.45 GiB size: 936.45 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.56 GiB used: 2.67 GiB (17.2%)
ID-2: swap-2 type: partition size: 17.11 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 49.0 C mobo: N/A gpu: nvidia temp: 68 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 40%
Processes: 338 Uptime: 2h 51m wakeups: 12 Memory: total: 16 GiB
available: 15.56 GiB used: 9.15 GiB (58.8%) Init: systemd v: 254
Packages: 1939 pm: pacman pkgs: 1930 libs: 496 tools: octopi,pamac,paru
pm: flatpak pkgs: 9 Shell: fish v: 3.6.1 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.29
System install date: 2023-07-22
Last full system update: 2023-09-22
Failed units: xhost_cups.service
I am being bothered with a very annoying issue.
When i try to record my screen with obs or share it with discord i experience a lot of lag in a game I’m playing. This occurs with every title i have tried(Apex legends, minecraft, Shadow of the Tomb Rider, Lol)
I dont know if this has anything to do with it but when i try to use pipewire to capture screen in obs it does not work(it does not allow me to select a screen to capture:)
XSHM works but it causes the lags, discord capture too. (My fps drops from ~120 to ~65) and the game feels really choppy.
