Dumb question: what is the best way to set-up screen blanking and sleep on idle?
(garuda-hyprland)
Please post the output of garuda-inxi
for all Issues & Assistance topics as requested in the template.
Try the solution suggested in this thread:
Another solution would be to add this to your Hyprland config:
exec-once = swayidle idlehint 1
That will send an idlehint after you log in, and from there you can configure your desired settings in /etc/systemd/logind.conf
(or, even better, a drop-in file in /etc/systemd/logind.conf.d/
Was this format we have got in hyprland recently ?
Because , to execute at once during startup is done like this :
As far as I remember , that format is for sway config
Tell me if I am wrong
You are not wrong, I just grabbed that right out of my Sway config.
Thanks for the correction, I edited the post above .
