salsa
1 August 2023 17:30
1
Hello,
Recently installed this build and really like it so far.
Having a persistent issue with the screen blanking (or going into hibernation, turning off my monitor) at about 15 minutes. I went to Power Management and turned off all of those so I am unsure where else this could be originating.
Kernel: 6.4.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=649300bf-7319-4910-9544-11aa06409d07 rw rootflags=subvol=@
resume=UUID=ff0962c3-da46-4358-a8d0-dd0f51283504 loglevel=3 ibt=off
Desktop: LXQt v: 1.3.0 tk: Qt v: 5.15.10 info: cairo-dock, lxqt-panel
wm: kwin_x11 vt: 2 dm: SDDM Distro: Garuda Linux base: Arch Linux
Type: Mini-pc System: LENOVO product: 11AMS0BX00 v: ThinkCentre M90n-1
serial: <superuser required> Chassis: type: 35 serial: <superuser required>
Mobo: LENOVO model: 314D v: NOK serial: <superuser required> UEFI: LENOVO
v: M2AKT2EA date: 09/17/2021
Info: model: Intel Celeron 4205U bits: 64 type: MCP arch: Comet/Whiskey Lake
note: check level: v2 built: 2018 process: Intel 14nm family: 6
model-id: 0x8E (142) stepping: 0xC (12) microcode: 0xF6
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 128 KiB
desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB desc: 2x256 KiB L3: 2 MiB
desc: 1x2 MiB
Speed (MHz): avg: 900 min/max: 400/1800 scaling: driver: intel_pstate
governor: powersave cores: 1: 900 2: 900 bogomips: 7200
Device-1: Intel Whiskey Lake-U GT1 [UHD Graphics 610] vendor: Lenovo
ports: active: DP-2 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:3ea1 class-ID: 0300
Device-2: USB C Video Adaptor driver: N/A type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:4 chip-ID: 25a4:9311
class-ID: 1100 serial: <filter>
Monitor-1: DP-2 model: Samsung serial: <filter> built: 2020 res: 1920x1080
hz: 60 dpi: 40 gamma: 1.2 size: 1210x680mm (47.64x26.77")
diag: 801mm (31.5") ratio: 16:9 modes: max: 1920x1080 min: 720x400
missing.
Device-1: Intel Cannon Point-LP High Definition Audio vendor: Lenovo
bus-ID: 00:1f.3 chip-ID: 8086:9dc8 class-ID: 0403
API: ALSA v: k6.4.7-zen1-1-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 0.3.76 status: active with: 1: pipewire-pulse
Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:9df0 class-ID: 0280
port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:5
Local Storage: total: 119.24 GiB used: 9.61 GiB (8.1%)
model: MZALQ128HCHQ-00BL1 size: 119.24 GiB block-size: physical: 512 B
fw-rev: 6L1QFXM7 temp: 21.9 C scheme: GPT
ID-1: / raw-size: 110.81 GiB size: 110.81 GiB (100.00%)
used: 9.61 GiB (8.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 110.81 GiB size: 110.81 GiB (100.00%)
ID-4: /var/log raw-size: 110.81 GiB size: 110.81 GiB (100.00%)
ID-5: /var/tmp raw-size: 110.81 GiB size: 110.81 GiB (100.00%)
ID-1: swap-1 type: zram size: 3.7 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 8.13 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 29.0 C pch: 28.0 C mobo: N/A
Processes: 201 Uptime: 1m wakeups: 0 Memory: total: 4 GiB available: 3.7 GiB
used: 2.04 GiB (55.2%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 Packages: pm: pacman pkgs: 1319
libs: 365 tools: octopi,paru Shell: Bash v: 5.1.16 running-in: qterminal
inxi: 3.3.28
System install date: 2023-07-31
Last full system update: 2023-07-31
I appreciate any assistance. Thank you.
SGS
1 August 2023 17:48
2
Welcome
Check with htop your memory use,
and temperature.
Also check log files like
journalctl -b -1 | grep -i hibernation
All in all, I’m glad it runs on such a machine at all.
salsa
1 August 2023 18:02
3
It runs pretty well aside from this although I don't do much heavier than DOSBox emulation.
Here is the output from the log, I also checked if other Hibernation/Sleeps were running. htop showed 1.2gb ram consumption.
Jul 31 21:41:02 lu-11ams0bx00 kernel: PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
Jul 31 21:41:02 lu-11ams0bx00 kernel: PM: hibernation: Registered nosave memory: [mem 0x0009f000-0x000fffff]
Jul 31 21:41:02 lu-11ams0bx00 kernel: PM: hibernation: Registered nosave memory: [mem 0x7bc1e000-0x7bc1efff]
Jul 31 21:41:02 lu-11ams0bx00 kernel: PM: hibernation: Registered nosave memory: [mem 0x7bc2c000-0x7bc2cfff]
Jul 31 21:41:02 lu-11ams0bx00 kernel: PM: hibernation: Registered nosave memory: [mem 0x84a54000-0x84a9cfff]
Jul 31 21:41:02 lu-11ams0bx00 kernel: PM: hibernation: Registered nosave memory: [mem 0x86dcb000-0x86dcbfff]
Jul 31 21:41:02 lu-11ams0bx00 kernel: PM: hibernation: Registered nosave memory: [mem 0x8935b000-0x8b33dfff]
Jul 31 21:41:02 lu-11ams0bx00 kernel: PM: hibernation: Registered nosave memory: [mem 0x8b33e000-0x8b3f6fff]
Jul 31 21:41:02 lu-11ams0bx00 kernel: PM: hibernation: Registered nosave memory: [mem 0x8b3f7000-0x8b491fff]
Jul 31 21:41:02 lu-11ams0bx00 kernel: PM: hibernation: Registered nosave memory: [mem 0x8b492000-0x8bd0efff]
Jul 31 21:41:02 lu-11ams0bx00 kernel: PM: hibernation: Registered nosave memory: [mem 0x8bd10000-0x8f7fffff]
Jul 31 21:41:02 lu-11ams0bx00 kernel: PM: hibernation: Registered nosave memory: [mem 0x8f800000-0xfdffffff]
Jul 31 21:41:02 lu-11ams0bx00 kernel: PM: hibernation: Registered nosave memory: [mem 0xfe000000-0xfe010fff]
Jul 31 21:41:02 lu-11ams0bx00 kernel: PM: hibernation: Registered nosave memory: [mem 0xfe011000-0xfebfffff]
Jul 31 21:41:02 lu-11ams0bx00 kernel: PM: hibernation: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
Jul 31 21:41:02 lu-11ams0bx00 kernel: PM: hibernation: Registered nosave memory: [mem 0xfec01000-0xfecfffff]
Jul 31 21:41:02 lu-11ams0bx00 kernel: PM: hibernation: Registered nosave memory: [mem 0xfed00000-0xfed03fff]
Jul 31 21:41:02 lu-11ams0bx00 kernel: PM: hibernation: Registered nosave memory: [mem 0xfed04000-0xfedfffff]
Jul 31 21:41:02 lu-11ams0bx00 kernel: PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
Jul 31 21:41:02 lu-11ams0bx00 kernel: PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xffffffff]
> ╭─lu@lu in ~ took 17s
╰─λ sudo systemctl status sleep.target suspend.target hibernate.target hybrid-sleep.target
○ sleep.target - Sleep
Loaded: loaded (/usr/lib/systemd/system/sleep.target; static)
Active: inactive (dead)
Docs: man:systemd.special(7)
○ suspend.target - Suspend
Loaded: loaded (/usr/lib/systemd/system/suspend.target; static)
○ hibernate.target - System Hibernation
Loaded: loaded (/usr/lib/systemd/system/hibernate.target; static)
○ hybrid-sleep.target - Hybrid Suspend+Hibernate
Loaded: loaded (/usr/lib/systemd/system/hybrid-sleep.target; static)
salsa
1 August 2023 20:47
4
Here's the output as it happens if that offers any insight:
Aug 01 16:28:56 lu-11ams0bx00 dbus-daemon[481]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Aug 01 16:28:56 lu-11ams0bx00 sudo[4643]: lu : TTY=pts/0 ; PWD=/home/lu ; USER=root ; COMMAND=/usr/bin/true
Aug 01 16:28:56 lu-11ams0bx00 sudo[4643]: pam_unix(sudo:session): session opened for user root(uid=0) by lu(uid=1000)
Aug 01 16:28:56 lu-11ams0bx00 sudo[4643]: pam_unix(sudo:session): session closed for user root
Aug 01 16:29:26 lu-11ams0bx00 dbus-daemon[481]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.105' (uid=0 pid=4690 comm="sudo journalctl -f")
Aug 01 16:29:26 lu-11ams0bx00 dbus-daemon[481]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Aug 01 16:29:26 lu-11ams0bx00 sudo[4690]: lu : TTY=pts/0 ; PWD=/home/lu ; USER=root ; COMMAND=/usr/bin/journalctl -f
Aug 01 16:29:26 lu-11ams0bx00 sudo[4690]: pam_unix(sudo:session): session opened for user root(uid=0) by lu(uid=1000)
Aug 01 16:41:06 lu-11ams0bx00 systemd[1]: Starting Update locate database...
Aug 01 16:41:06 lu-11ams0bx00 systemd[1]: updatedb.service: Deactivated successfully.
Aug 01 16:41:06 lu-11ams0bx00 systemd[1]: Finished Update locate database.
Please post always your terminal in- and output as text like
Kernel: 5.18.15-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
parameters:
I have edited your post.
It appears LXQt is currently allowing DPMS to override the user-specified settings in LXQt Power Management, the reason given being "lxqt-powermanagement should not silently touch other components settings". See the discussion here:
opened 03:28AM - 19 Jul 23 UTC
Default DPMS timeouts are in conflict with `lxqt-powermanagement`.
Users migh… t have found various ways of avoiding this problem (like I did), and once the issue was avoided, it might have been forgotten. But, IMHO, it's a serious issue under X11.
Its fix may be as simple as this (inside `IdlenessWatcher::setup()`):
```c++
// override DPMS settings
if (QGuiApplication::platformName() == QStringLiteral("xcb")) {
xcb_dpms_set_timeouts(QX11Info::connection(), 0, 0, 0);
This solution worked here. Now `xset q` shows
DPMS (Display Power Management Signaling):
Standby: 0 Suspend: 0 Off: 0
DPMS is Enabled
Monitor is On
However, not being an expert in cmake, I had a hard time to find XCB's DPMS module with it. In the end, I edited what I found in screengrab.
@luis-pereira, @palinek, @yan12125
Am I missing something when I think that this issue is serious? And do you know of a simpler way of finding DPMS? I mean simpler than what's done in screengrab?
It looks like they are fixing this behavior so DPMS will be overridden when the "idleness watcher" is enabled, which seems reasonable to me. The issue is still open at the moment however, so in the meanwhile you may wish to employ the workaround mentioned in the issue (disable DPMS in a startup script).
A simple way to do this would be to make an .xprofile file, which SDDM will source when starting X11.
micro ~/.xprofile
Add to the file:
xset s off -dpms
Save and exit.
I hope that helps, welcome to the community @salsa .
salsa
2 August 2023 04:14
8
Yep, looks like that got it. Thank you!
Gavin
2 August 2023 09:31
9
if by any chance it all starts blanking again after a reboot, what i did was just add caffeiine-ng and add a couple of apps to preferences. No more blanking. Its in aur, so can be downloaded and installed locally if need be.
Just a brief correction: ~/.xprofile does not need to be executable, I took that part out of the post above. I'm not sure why I added that; it was late and must have been typing on auto-pilot.
system
Closed
4 August 2023 10:44
11
