Hi everyone.
I did a fresh reinstall of Garuda XFCE this morning, every now and then when I play videos or games I get this screeching/scratching sound that repeat two or three times during playback. At first I thought it was the videos that i'm playing since they are live-recorded over skype and later edited. I have no idea what could possibly cause this, but I did notice on the garuda-inxi below that I have an Intel audio driver installed for my on-board audio which is actually Realtek. I tried changing the configuration profile on PulseAudio from Analog Stereo Duplex or Analog Stereo Output and Pro Audio, that doesn't help. I'm using an old amplifier but I doubt it's the amplifier cause the screeching/scratching sounds digital, noise goes away when I stop playback.
Any thoughts appreciated. Thanks.
Kernel: 6.1.37-1-lts arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=60b8f66e-c676-4631-ba03-30ef04375769 rw rootflags=subvol=@
resume=UUID=d6944b17-9fec-4b14-a018-9f4dded19c56 loglevel=3 ibt=off
Type: Desktop Mobo: Micro-Star model: B450 TOMAHAWK (MS-7C02) v: 1.0
serial: <superuser required> UEFI: American Megatrends LLC. v: 1.J1
date: 05/06/2023
Info: model: AMD Ryzen 3 2200G with Radeon Vega Graphics bits: 64 type: MCP
arch: Zen level: v3 note: check built: 2017-19 process: GF 14nm
family: 0x17 (23) model-id: 0x11 (17) stepping: 0 microcode: 0x8101016
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 384 KiB
desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 3678 high: 3690 min/max: 1600/3500 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3667 2: 3672
3: 3686 4: 3690 bogomips: 27956
vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands
process: GF 14nm built: 2016-20 pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: lanes: 16 ports: active: DVI-D-1 empty: DP-1,DVI-D-2,HDMI-A-1
bus-ID: 10:00.0 chip-ID: 1002:67df class-ID: 0300 temp: 50.0 C
Display: x11 server: X.Org v: 21.1.8 compositor: xfwm v: 4.18.0 driver: X:
loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.65x9.37")
s-diag: 485mm (19.11")
Monitor-1: DVI-D-1 mapped: DVI-D-0 model: Samsung SyncMaster
serial: <filter> built: 2009 res: 1600x900 hz: 60 dpi: 92 gamma: 1.2
size: 443x250mm (17.44x9.84") diag: 509mm (20") ratio: 16:9 modes:
max: 1600x900 min: 720x400
API: OpenGL v: 4.6 Mesa 23.1.3 renderer: AMD Radeon RX 570 Series
(polaris10 LLVM 15.0.7 DRM 3.49 6.1.37-1-lts) direct-render: Yes
lanes: 8 link-max: lanes: 16 bus-ID: 10:00.1 chip-ID: 1002:aaf0
Device-2: AMD Family 17h/19h HD Audio vendor: Micro-Star MSI
bus-ID: 30:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.1.37-1-lts status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.72 status: active with: 1: pipewire-pulse
Message: No PCI device data found.
IF-ID-1: enp48s0f4u1 state: unknown speed: -1 duplex: half mac: <filter>
Device-1: vivo 2015 driver: rndis_host v: kernel type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1:4 chip-ID: 2d95:600a
Report: bt-service: enabled,stopped note: tool can't run
Local Storage: total: 5.69 TiB used: 4.73 TiB (83.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Mushkin model: MKNSSDHL250GB-D8
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: S1111A0L temp: 45.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ01ABD100
size: 931.51 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: HDD rpm: 5400
serial: <filter> scheme: MBR
model: WD50NDZW-11BCSS0 size: 4.55 TiB block-size: physical: 4096 B
logical: 512 B type: USB rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
tech: HDD rpm: 4800 serial: <filter> fw-rev: 1034 scheme: GPT
ID-1: / raw-size: 223.79 GiB size: 223.79 GiB (100.00%)
used: 104.37 GiB (46.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 223.79 GiB size: 223.79 GiB (100.00%)
ID-4: /var/log raw-size: 223.79 GiB size: 223.79 GiB (100.00%)
ID-5: /var/tmp raw-size: 223.79 GiB size: 223.79 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.68 GiB used: 4.52 GiB (58.8%)
System Temperatures: cpu: 51.6 C mobo: N/A gpu: amdgpu temp: 50.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1238
Processes: 308 Uptime: 3h 49m wakeups: 0 Memory: available: 7.68 GiB
used: 6.24 GiB (81.3%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 Packages: pm: pacman pkgs: 1530
libs: 500 tools: gnome-software,octopi,paru Shell: Bash v: 5.1.16
running-in: xfce4-terminal inxi: 3.3.27
System install date: 2023-07-02
Last full system update: 2023-07-02 ↻
