Hello,
I've got a strange issue. According to blender and the clinfo, I don't have an OpenCL plattform.
On the other hand DaVinci Resolve works very well. It needs the OpenCL and the AMDPro OpenCL libs/plattforms to even start.
My HW: AMD 5800X + AMD Radeon 6800XT
Blender only shows greyed nVidia options (Render-Settings) and just allows me to CPU-Render. Not even the depreached OpenCL is listed nor the HIP. Means no GPU rendering for me ![]()
*Side note: On Blender 3.1.2 from the community repository. No fancy downloads and self made buildpkg. And I know that HIP implementation might be coming in the future for Linux but OpenCL is missing complelte and the clinfo confirms it O.o
My attempts to resolve that issue:
- Re-installed the AMD drivers
- Manually added amd-opencl and amdpro-opencl (rebooted after every added package to be sure to get it initialized.)
- went through all the ArchLinux-Wikis who (mostly) show all the packages. Which I've tried and I kept an eye on conflict errors. I had none. Also my driver is up to date since I do a daily pacman -Syu. And have them installed properly as you can see in clinfo below
- reinstalled blender after adding opencl-drivers.
- always checking if DaVinci Resolve runs (critical to me) - Resolve even recognizes two 6800XT due to my driver bloat xD - I could sell one card hahaha how to make money LOL
Currently it is the "most bloated" (Number of plattforms 2
) state as I have several drivers in the row. And yet nothing works....
Why I'm creating that topic/thread
I haven't found anything familiar to my issue on this forum. Except some strange issue with a package regarding crypto mining... Furthermore the ArchLinux Wiki doesn't helped either. I assume a conceptional issue on my side ![]()
I'd be glad about any advice.
(Next in this post: prompt from clinfo and the ofc garuda-inxi:
clinfo:
Number of platforms 2
Platform Name Clover
Platform Vendor Mesa
Platform Version OpenCL 1.1 Mesa 22.0.1
Platform Profile FULL_PROFILE
Platform Extensions cl_khr_icd
Platform Extensions function suffix MESA
Platform Name AMD Accelerated Parallel Processing
Platform Vendor Advanced Micro Devices, Inc.
Platform Version OpenCL 2.2 AMD-APP (3406.0)
Platform Extensions cl_khr_icd cl_amd_event_callback
Platform Extensions function suffix AMD
Platform Host timer resolution 1ns
Number of devices 1
Device Name AMD Radeon RX 6800 XT (sienna_cichlid, LLVM 13.0.1, DRM 3.44, 5.17.1-zen1-1-zen)
Device Vendor AMD
Device Vendor ID 0x1002
Device Version OpenCL 1.1 Mesa 22.0.1
Device Numeric Version 0x401000 (1.1.0)
Driver Version 22.0.1
Device OpenCL C Version OpenCL C 1.1
Device Type GPU
Device Profile FULL_PROFILE
Device Available Yes
Compiler Available Yes
Max compute units 72
Max clock frequency 2575MHz
Max work item dimensions 3
Max work item sizes 256x256x256
Max work group size 256
=== CL_PROGRAM_BUILD_LOG ===
fatal error: cannot open file '/usr/share/clc/gfx1030-amdgcn-mesa-mesa3d.bc': No such file or directory
Preferred work group size multiple (kernel) <getWGsizes:1504: create kernel : error -46>
Preferred / native vector sizes
char 16 / 16
short 8 / 8
int 4 / 4
long 2 / 2
half 0 / 0 (n/a)
float 4 / 4
double 2 / 2 (cl_khr_fp64)
Half-precision Floating-point support (n/a)
Single-precision Floating-point support (core)
Denormals No
Infinity and NANs Yes
Round to nearest Yes
Round to zero No
Round to infinity No
IEEE754-2008 fused multiply-add No
Support is emulated in software No
Correctly-rounded divide and sqrt operations No
Double-precision Floating-point support (cl_khr_fp64)
Denormals Yes
Round to zero Yes
Round to infinity Yes
IEEE754-2008 fused multiply-add Yes
Address bits 64, Little-Endian
Global memory size 17179869184 (16GiB)
Error Correction support No
Max memory allocation 13743895347 (12.8GiB)
Unified memory for Host and Device No
Minimum alignment for any data type 128 bytes
Alignment of base address 32768 bits (4096 bytes)
Global Memory cache type None
Image support No
Local memory type Local
Local memory size 32768 (32KiB)
Max number of constant args 16
Max constant buffer size 67108864 (64MiB)
Max size of kernel argument 1024
Queue properties
Out-of-order execution No
Profiling Yes
Profiling timer resolution 0ns
Execution capabilities
Run OpenCL kernels Yes
Run native kernels No
ILs with version (n/a)
Built-in kernels with version (n/a)
Device Extensions cl_khr_byte_addressable_store cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_int64_base_atomics cl_khr_int64_extended_atomics cl_khr_fp64 cl_khr_extended_versioning
Device Extensions with Version cl_khr_byte_addressable_store 0x400000 (1.0.0)
cl_khr_global_int32_base_atomics 0x400000 (1.0.0)
cl_khr_global_int32_extended_atomics 0x400000 (1.0.0)
cl_khr_local_int32_base_atomics 0x400000 (1.0.0)
cl_khr_local_int32_extended_atomics 0x400000 (1.0.0)
cl_khr_int64_base_atomics 0x400000 (1.0.0)
cl_khr_int64_extended_atomics 0x400000 (1.0.0)
cl_khr_fp64 0x400000 (1.0.0)
cl_khr_extended_versioning 0x400000 (1.0.0)
Number of devices 1
Device Name gfx1030
Device Vendor Advanced Micro Devices, Inc.
Device Version OpenCL 2.0
Driver Version 3406.0 (HSA1.1,LC)
Device OpenCL C Version OpenCL C 2.0
Device Type GPU
Device Board Name (AMD) AMD Radeon RX 6800 XT
Device PCI-e ID (AMD) 0x73bf
Device Topology (AMD) PCI-E, 0000:2f:00.0
Linker Available Yes
Max compute units 36
SIMD per compute unit (AMD) 4
SIMD width (AMD) 32
SIMD instruction width (AMD) 1
Graphics IP (AMD) 10.3
Device Partition (core)
Max number of sub-devices 36
Supported partition types None
Supported affinity domains (n/a)
Max work item sizes 1024x1024x1024
Preferred work group size (AMD) 256
Max work group size (AMD) 1024
Preferred work group size multiple (kernel) 32
Wavefront width (AMD) 32
char 4 / 4
short 2 / 2
int 1 / 1
long 1 / 1
half 1 / 1 (cl_khr_fp16)
float 1 / 1
double 1 / 1 (cl_khr_fp64)
Half-precision Floating-point support (cl_khr_fp16)
Denormals No
Infinity and NANs No
Round to nearest No
Round to zero No
Denormals Yes
Round to zero Yes
Correctly-rounded divide and sqrt operations Yes
Denormals Yes
Round to zero Yes
Global memory size 17163091968 (15.98GiB)
Global free memory (AMD) 16760832 (15.98GiB) 16760832 (15.98GiB)
Global memory channels (AMD) 8
Global memory banks per channel (AMD) 4
Global memory bank width (AMD) 256 bytes
Max memory allocation 14588628168 (13.59GiB)
Shared Virtual Memory (SVM) capabilities (core)
Coarse-grained buffer sharing Yes
Fine-grained buffer sharing Yes
Fine-grained system sharing No
Atomics No
Alignment of base address 1024 bits (128 bytes)
Preferred alignment for atomics
SVM 0 bytes
Global 0 bytes
Local 0 bytes
Max size for global variable 14588628168 (13.59GiB)
Preferred total size of global vars 17163091968 (15.98GiB)
Global Memory cache type Read/Write
Global Memory cache size 16384 (16KiB)
Global Memory cache line size 64 bytes
Image support Yes
Max number of samplers per kernel 29631
Max size for 1D images from buffer 134217728 pixels
Max 1D or 2D image array size 8192 images
Base address alignment for 2D image buffers 256 bytes
Pitch alignment for 2D image buffers 256 pixels
Max 2D image size 16384x16384 pixels
Max 3D image size 16384x16384x8192 pixels
Max number of read image args 128
Max number of write image args 8
Max number of read/write image args 64
Max number of pipe args 16
Max active pipe reservations 16
Max pipe packet size 1703726280 (1.587GiB)
Local memory size 65536 (64KiB)
Local memory size per CU (AMD) 65536 (64KiB)
Local memory banks (AMD) 32
Max number of constant args 8
Max constant buffer size 14588628168 (13.59GiB)
Preferred constant buffer size (AMD) 16384 (16KiB)
Queue properties (on host)
Profiling Yes
Queue properties (on device)
Out-of-order execution Yes
Profiling Yes
Preferred size 262144 (256KiB)
Max size 8388608 (8MiB)
Max queues on device 1
Max events on device 1024
Prefer user sync for interop Yes
Number of P2P devices (AMD) 0
Profiling timer resolution 1ns
Profiling timer offset since Epoch (AMD) 0ns (Thu Jan 1 01:00:00 1970)
Thread trace supported (AMD) No
Number of async queues (AMD) 8
Max real-time compute queues (AMD) 8
Max real-time compute units (AMD) 36
printf() buffer size 4194304 (4MiB)
Built-in kernels (n/a)
Device Extensions cl_khr_fp64 cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_int64_base_atomics cl_khr_int64_extended_atomics cl_khr_3d_image_writes cl_khr_byte_addressable_store cl_khr_fp16 cl_khr_gl_sharing cl_amd_device_attribute_query cl_amd_media_ops cl_amd_media_ops2 cl_khr_image2d_from_buffer cl_khr_subgroups cl_khr_depth_images cl_amd_copy_buffer_p2p cl_amd_assembly_program
NULL platform behavior
clGetPlatformInfo(NULL, CL_PLATFORM_NAME, ...) No platform
clGetDeviceIDs(NULL, CL_DEVICE_TYPE_ALL, ...) No platform
clCreateContext(NULL, ...) [default] No platform
clCreateContext(NULL, ...) [other] Success [MESA]
clCreateContextFromType(NULL, CL_DEVICE_TYPE_DEFAULT) Success (1)
clCreateContextFromType(NULL, CL_DEVICE_TYPE_CPU) No devices found in platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_GPU) Success (1)
clCreateContextFromType(NULL, CL_DEVICE_TYPE_ACCELERATOR) No devices found in platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_CUSTOM) No devices found in platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_ALL) Success (1)
My inxi:
root=UUID=de43fccd-7f1e-439e-9eca-59d05e719941 rw rootflags=subvol=@
Type: Desktop Mobo: Micro-Star model: MPG X570 GAMING PLUS (MS-7C37) v: 2.0
serial: <superuser required> UEFI: American Megatrends LLC. v: A.F0
date: 12/16/2021
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3719 high: 4341 min/max: 2200/4850 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3624 2: 3626
3: 3637 4: 4341 5: 3648 6: 3835 7: 3626 8: 3717 9: 3859 10: 3660 11: 3640
12: 3720 13: 3653 14: 3632 15: 3673 16: 3624 bogomips: 121610
STIBP: always-on, RSB filling
Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] vendor: ASUSTeK
driver: amdgpu v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
active: DP-2,HDMI-A-1 empty: DP-1,DP-3 bus-ID: 2f:00.0 chip-ID: 1002:73bf
loaded: amdgpu unloaded: modesetting,radeon alternate: fbdev,vesa
s-diag: 1055mm (41.54")
Monitor-1: DP-2 mapped: DisplayPort-1 pos: primary,left model: Asus VS248
serial: <filter> built: 2012 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: primary,right model: Asus VS248
OpenGL: renderer: AMD Radeon RX 6800 XT (sienna_cichlid LLVM 13.0.1 DRM
3.44 5.17.1-zen1-1-zen)
v: 4.6 Mesa 22.0.1 direct render: Yes
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 2f:00.1 chip-ID: 1002:ab28
bus-ID: 31:00.4 chip-ID: 1022:1487 class-ID: 0403
vendor: Micro-Star MSI X570-A PRO driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 27:00.0 chip-ID: 10ec:8168
IF: enp39s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 946.03 GiB used: 242.97 GiB (25.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P5SSD8
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: P4CR311
temp: 36.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Generic model: Flash Disk
size: 14.51 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> rev: 8.07 scheme: MBR
used: 242.97 GiB (26.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 62.78 GiB used: 2.2 MiB (0.0%)
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 35.0 C
mem: 32.0 C
Processes: 360 Uptime: 40m wakeups: 0 Memory: 62.78 GiB used: 4 GiB (6.4%)
Init: systemd v: 250 tool: systemctl Compilers: gcc: 11.2.0 clang: 13.0.1
Packages: pacman: 2012 lib: 578 Shell: fish v: 3.4.1 running-in: konsole
inxi: 3.3.14
Garuda (2.6.1-1):
System install date: 2022-04-05
Last full system update: 2022-04-07
I wasn't sure if this is ok to put this in 'unsupported' but I assume it to be since Garuda devs ain't developing gpu drivers nor are they developing on blender. Therefore I think it is about usnupported software.
Thanks for your time!
Bruce
P.S.: For anyone who might not know, Schrödinger is a noble price winner from Austria
- and Schrödingers Cat is his most famous analogy
