I start on Garuda which I find excellent!!
my question I have a brother printer in network DCPL 2530DW
The printer works well, however the integrated scanner is not recognized
can you help me and tell me as a beginner how to do it
Sincerely yours
Hello, If you have an issue and require assistance, please use the proper category here: https://forum.garudalinux.org/c/issues-assistance/15
Make a new topic and follow the template.
(Edit: Your thread has since been moved, but we could use your garuda-inxi output still)
Yes, that was me, sorry
But since you have TL3, feel free to do it yourself. Click on the pen and enter the category in the search box or scroll there.
You know, with this power also a great responsibility passes to you
well i am very beginner
my printer is the brother dcp -l 253dw
it includes a scanner
could you give me very simple command line
the one provided does not work
Thank you for your help
very cordially to read you the address printer
ip=192.168.1.16
(sorry if I am getting a bit off topic)
I usually do move threads like these (and do a lot of re-organizing moving things to proper sub-sections), just that I don't think the template would be seen if I just simply move it from a category like "Garuda Community". Maybe I could copy a new thread template from the "Issues & Assistance" section to my post after I move it? Would that be acceptable?
thank you for your help I'm a beginner...windows is easier
then I have copied in the terminal the command line that you made that returns:
-a name=DCP-L2530DW model=DCP-L2530DW ip=192.168.1.16
find-the-command: "brsaneconfig4" is not found locally, searching in repositories...
find-the-command: command not found: "brsaneconfig4"
the sane software launches but it finds nothing...
on the other hand the printer only works but not the scanner alas!!
thank you very much for your patience
