honza
18 July 2024 18:01
1
I have a 4K laptop, so by default, a lot of apps are really small. I don’t really mind that, but when switching from app to app it’s pretty annoying. When I switched it on “Scaled by the system” in “Display & Monitor” Vivaldi was reeealy zoomed in and practically unusable. I had only few apps opened, so the issue is probably with more apps.
Can someone tell me how to choose this setting individually for each app? (not in-app settings but in system settings with some add-on or something).
Please can you provide you
as per the forum template this help people to help you
honza
18 July 2024 20:05
3
╭─honza@honza in ~
╰─λ garuda-inxi
Kernel: 6.9.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=6519954b-9606-4557-b953-512403841361 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.1.2 tk: Qt v: N/A info: frameworks v: 6.4.0
Type: Convertible System: LENOVO product: 82LU v: Yoga 9 14IAP7
serial: <superuser required> Chassis: type: 31 v: Yoga 9 14IAP7
Mobo: LENOVO model: LNVNB161216 v: SDK0T76530 WIN
serial: <superuser required> part-nu: LENOVO_MT_82LU_BU_idea_FM_Yoga 9
14IAP7 uuid: <superuser required> UEFI: LENOVO v: HNCN46WW
date: 09/08/2023
ID-1: BAT0 charge: 68.9 Wh (100.0%) condition: 68.9/75.0 Wh (91.9%)
volts: 17.6 min: 15.5 model: Celxpert L21C4PH0 type: Li-poly
serial: <filter> status: full cycles: 138
ID-2: hidpp_battery_0 charge: 100% condition: N/A volts: 4.2 min: N/A
Info: model: 12th Gen Intel Core i7-1260P bits: 64 type: MST AMCP
arch: Alder Lake level: v3 note: check built: 2021+
microcode: 0x433
Topology: cpus: 1x cores: 12 mt: 4 tpc: 2 st: 8 threads: 16 smt: enabled
cache: L1: 1.1 MiB desc: d-8x32 KiB, 4x48 KiB; i-4x32 KiB, 8x64 KiB
L2: 9 MiB desc: 4x1.2 MiB, 2x2 MiB L3: 18 MiB desc: 1x18 MiB
Speed (MHz): avg: 769 high: 2000 min/max: 400/4700:3400 scaling:
driver: intel_pstate governor: powersave cores: 1: 2000 2: 1835 3: 1082
4: 400 5: 736 6: 926 7: 459 8: 400 9: 400 10: 400 11: 1129 12: 400 13: 400
14: 937 15: 400 16: 400 bogomips: 79872
Please, post the full log from garuda-inxi.
Try X11 from login screen or use System settings to scale.
If the app aloud this, you must check if the app has it in their config file.
Here’s plenty of information on the topic
system
Closed
2 August 2024 01:50
6
