Hi guys,
I have the following problem: I freshly installed garuda hyprland and tried to set it up. Everything works fine, but I have big problems to get my native monitor resolution (7680x2160 240hz).
On windows, before i installed garuda, everything works fine. On my mac working notebook I get a much higher resolution as well, even I cannot get the full res due apples restrictions. So I assume my monitor and cables are not the problem here.
I already tried to add it manually with gtf and cvt, but it didnt work either. I get the error “BadValue (integer parameter out of index …)”. I tried this with 7680x2160 144hz and 7680x2160 240hz.
I also updated my drivers and rebooted multiple times.
It may seems to be a arch specific problem, since there are multiple threads about the same problem, but a fix regarding this problem should be already implemented for approx. 1 year now.
Does anyone may know what the problem could be and how to solve it?
I really hope to get this fixed.
Thanks in advance and have a great start in the week,
Eric
$ sudo get-edid | parse-edid - Output
This is read-edid version 3.0.2. Prepare for some fun.
Attempting to use i2c interface
Looks like no busses have an EDID. Sorry!
Attempting to use the classical VBE interface
Performing real mode VBE call
Interrupt 0x10 ax=0x4f00 bx=0x0 cx=0x0
Function unsupported
Call failed
VBE version 0
VBE string at 0x0 "O"
VBE/DDC service about to be called
Report DDC capabilities
Interrupt 0x10 ax=0x4f15 bx=0x0 cx=0x0
Call failed
Reading next EDID block
Read EDID
Interrupt 0x10 ax=0x4f15 bx=0x1 cx=0x0
Call failed
The EDID data should not be trusted as the VBE call failed
Error: output block unchanged
I'm sorry nothing was successful. Maybe try some other arguments
if you played with them, or send an email to Matthew Kern <pyrophobicman@gmail.com>.
Partial Read... Try again
garuda-inxi - Output
Kernel: 6.9.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=03a949ad-790e-4786-a2ca-0b8b42065ae2 rw rootflags=subvol=@
quiet resume=UUID=7cabe734-feb3-486b-94a0-6407ab83ba9d loglevel=3 ibt=off
Desktop: Hyprland v: 0.41.1 with: waybar tools: avail: swayidle,swaylock
vt: 1 dm: SDDM Distro: Garuda base: Arch Linux
Mobo: ASUSTeK model: TUF GAMING B650-PLUS v: Rev 1.xx
UEFI: American Megatrends v: 0823 date: 11/21/2022
Info: model: AMD Ryzen 9 7950X bits: 64 type: MT MCP arch: Zen 4 gen: 5
Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 16 MiB desc: 16x1024 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 719 high: 5530 min/max: 400/5881 scaling:
driver: amd-pstate-epp governor: performance cores: 1: 400 2: 400 3: 400
4: 400 5: 5530 6: 400 7: 5489 8: 400 9: 400 10: 400 11: 400 12: 400
13: 400 14: 400 15: 400 16: 400 17: 400 18: 400 19: 400 20: 400 21: 400
22: 400 23: 400 24: 400 25: 400 26: 400 27: 400 28: 400 29: 400 30: 400
31: 400 32: 400 bogomips: 287444
Device-1: AMD Navi 31 [Radeon RX 7900 XT/7900 XTX/7900M] vendor: ASUSTeK
driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm)
built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: HDMI-A-1
empty: DP-1, DP-2, DP-3, Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:744c
Device-2: AMD Raphael vendor: ASUSTeK driver: amdgpu v: kernel
gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
empty: DP-4,HDMI-A-2,Writeback-2 bus-ID: 0f:00.0 chip-ID: 1002:164e
class-ID: 0300 temp: 46.0 C
Device-3: Logitech Logitech Webcam C920-C driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-2.3:6
chip-ID: 046d:0841 class-ID: 0102 serial: <filter>
compositor: Hyprland v: 0.41.1 driver: X: loaded: amdgpu
gpu: amdgpu display-ID: 1
Monitor-1: HDMI-A-1 model: Samsung Odyssey G95NC serial: <filter>
built: 2023 res: 3840x1080 hz: 60 dpi: 70 gamma: 1.2 scale: 1
size: 1400x400mm (55.12x15.75") diag: 1456mm (57.3") modes: max: 3840x1080
min: 640x480
API: Vulkan v: 1.3.279 layers: 4 device: 0 type: discrete-gpu name: AMD
Radeon RX 7900 XT (RADV NAVI31) driver: mesa radv v: 24.1.1-arch1.1
device-ID: 1002:744c surfaces: xcb,xlib,wayland device: 1
type: integrated-gpu name: AMD Radeon Graphics (RADV RAPHAEL_MENDOCINO)
driver: mesa radv v: 24.1.1-arch1.1 device-ID: 1002:164e
17.0.6 256 bits) driver: mesa llvmpipe v: 24.1.1-arch1.1 (LLVM 17.0.6)
Device-2: AMD Rembrandt Radeon High Definition Audio vendor: ASUSTeK
bus-ID: 0f:00.1 chip-ID: 1002:1640 class-ID: 0403
bus-ID: 0f:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: BEHRINGER GmbH UMC204HD 192k driver: snd-usb-audio type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3 chip-ID: 1397:0508
class-ID: fe01
Device-5: Logitech Logitech Webcam C920-C driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.9.5-zen1-1-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 1.0.7 status: active with: 1: pipewire-pulse
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 0a:00.0
Device-1: ASUSTek Broadcom BCM20702A0 Bluetooth driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2:2
chip-ID: 0b05:17cb class-ID: fe01 serial: <filter>
Local Storage: total: 2.27 TiB used: 9.43 GiB (0.4%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Gigabyte
model: GP-ASM2NE6200TTTD size: 1.82 TiB block-size: physical: 512 B
fw-rev: EGFM11.3 temp: 44.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Seagate model: FireCuda 520 SSD
ZP500GM30002 size: 465.76 GiB block-size: physical: 512 B logical: 512 B
speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: STNSC014
temp: 32.9 C scheme: GPT
ID-1: / raw-size: 1.79 TiB size: 1.79 TiB (100.00%) used: 9.43 GiB (0.5%)
fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:5
used: 584 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:4
used: 9.43 GiB (0.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:5
ID-1: swap-1 type: zram size: 30.5 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 32 dev: /dev/zram0
ID-2: swap-2 type: partition size: 33.55 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:6
System Temperatures: cpu: 54.1 C mobo: N/A
GPU: device: amdgpu temp: 47.0 C device: amdgpu temp: 40.0 C mem: 54.0 C
fan: 0 watts: 11.00
Memory: total: 32 GiB note: est. available: 30.5 GiB used: 2.4 GiB (7.9%)
Processes: 514 Power: uptime: 2m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.19 GiB Init: systemd v: 255
Packages: pm: pacman pkgs: 1290 libs: 379 tools: pacseek,paru Compilers:
gcc: 14.1.1 Shell: garuda-inxi default: Bash v: 5.2.26
running-in: xfce4-terminal inxi: 3.3.34
System install date: 2024-06-17
Last full system update: 2024-06-17
Edit 1:
Added DRI_PRIME=1 to bashrc, so its forced to use my dedicated gpu, didnt work either.
