Hi guys,
I’m new to Linux and Garuda. I’ve installed Garuda as my first Linux OS journey because I really like the look of it. I’m learning and enjoying it so far, but I’m having issues trying to get my Samsung Buds2Pro to work with Garuda.
I’ve tried the Galaxy Buds Manager for Linux, but it didn’t help. It kept saying my Buds aren’t connected, but the Bluetooth in the SystemTray says it it. I also tried to delete the Buds and then reconnect.
If anyone has any ideas on what software/drivers I need to install to make my Buds2Pro work, I’d appreciate the help. Thanks in advance.
SGS
24 April 2024 10:27
2
We need the garuda-inxi.
In KDE it is easy to set the settings, other DE’s not, so, post the garuda-inxi, please.
Read the template
What’s the problem with not posting garuda-inxi?
It contains additional, useful information about the status of your system.
Missing information requested in the template may result in not receiving assistance
Issue still unresolved? Then:
ONE issue per topic.
Describe your issue in detail. The more we know, the better we can help
Show us the results of your searches, and what you’ve tried
After rebooting, post the FULL output of garuda-inxi
in the body of the post (not linked externally, or collapsed with the “hide details” feature)
Format terminal output (including your garuda-inxi
) as a code block by clicking the preformatted text button (</> ) , or put three tildes (~) above and below the text
Without garuda-inxi this request will be moved to 412 Precondition Failed
If you don’t know how to use the Terminal they made a really awesome application. It’s called Garuda Assistant. There is a tab called “system spec”. Click it and at the bottom right is copy to forum
Click that and then paste it in the reply. If you figure out a solution please come back and let us know what it was so we can close the issue and share the knowledge.
Welcome to Garuda, the best distro I know of.
solid 40% chance audio is just being sent to the wrong place and 5 seconds in audio devices to change it would fix this.
Garuda-inxi:
╰─λ garuda-inxi
Kernel: 6.8.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=1b3c8c03-7285-4fb0-9206-7bc95933b85f rw rootflags=subvol=@
Type: Laptop System: Acer product: Swift SF314-55 v: V1.07
Mobo: WL model: MILLER_WL v: V1.07 serial: <superuser required>
part-nu: 0000000000000000 uuid: <superuser required>
UEFI: American Megatrends v: 1.07 date: 12/24/2018
ID-1: BAT0 charge: 44.8 Wh (99.3%) condition: 45.1/50.8 Wh (88.7%)
volts: 16.6 min: 15.3 model: AC14B7K type: Li-ion serial: N/A
Device-1: hidpp_battery_1 model: Logitech Wireless Mouse M510
serial: <filter> charge: 50% (should be ignored) rechargeable: yes
status: N/A
Info: model: Intel Core i5-8265U bits: 64 type: MT MCP arch: Whiskey Lake
model-id: 0x8E (142) stepping: 0xB (11) microcode: 0xF4
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 450 high: 800 min/max: 400/3900 scaling:
driver: intel_pstate governor: powersave cores: 1: 400 2: 400 3: 400 4: 800
5: 400 6: 400 7: 400 8: 400 bogomips: 28800
Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620]
vendor: Acer Incorporated ALI driver: i915 v: kernel arch: Gen-9.5
process: Intel 14nm built: 2016-20 ports: active: eDP-1
empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:3ea0 class-ID: 0300
Device-2: Chicony HD WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:5 chip-ID: 04f2:b5c5
Monitor-1: eDP-1 res: 1536x864 size: N/A modes: N/A
drv: iris inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.5-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 620 (WHL
GT2) device-ID: 8086:3ea0 memory: 7.43 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 3 device: 0 type: integrated-gpu name: Intel
UHD Graphics 620 (WHL GT2) driver: mesa intel v: 24.0.5-arch1.1
device-ID: 8086:3ea0 surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.0.5-arch1.1 (LLVM 17.0.6) device-ID: 10005:0000
Device-1: Intel Cannon Point-LP High Definition Audio
vendor: Acer Incorporated ALI driver: sof-audio-pci-intel-cnl
alternate: snd_hda_intel, snd_soc_skl, snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:9dc8 class-ID: 0401
API: ALSA v: k6.8.7-zen1-1-zen status: kernel-api tools: N/A
Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:9df0 class-ID: 0280
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:6
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 5.1
v: 3.0 port: 3060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 465.76 GiB used: 17.42 GiB (3.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 500GB
lanes: 4 tech: SSD serial: <filter> fw-rev: 3B4QFXO7 temp: 28.9 C
used: 17.42 GiB (3.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 7.61 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 38.0 C pch: 36.0 C mobo: N/A
Memory: total: 8 GiB available: 7.61 GiB used: 2.79 GiB (36.6%)
Processes: 285 Power: uptime: 3h 54m states: freeze,mem,disk
suspend: s2idle avail: deep wakeups: 3 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 3.03 GiB services: org_kde_powerdevil,
Packages: 1517 pm: pacman pkgs: 1511 libs: 431
tools: gnome-software,octopi,paru pm: flatpak pkgs: 6 Compilers: gcc: 13.2.1
Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole inxi: 3.3.34
System install date: 2024-04-20
Last full system update: 2024-04-23
Failed units: ```
I also tried going into the audio settings and see if it is a setting I can change but still can’t get the earbuds to work. It does the same thing with other bluetooth earbuds, too. I’m thinking it’s my bluetooth driver on my laptop?
Thank you for the suggestion, but I’m forcing myself to learn the Terminal to get used to Linux. haha.
So if you guys have any solutions that involve in using the Terminal, that would be even better. Looking forward to learning and hopefully pay-it-back and teach/guide someone else later on in life.
SGS
25 April 2024 05:09
8
Check
lsusb
in termial.
Search in arch wiki for the ID number xxxx:xxxx if there are problems.
Sample
Bus 003 Device 005: ID 8087:0026 Intel Corp. AX201 Bluetooth
Edit:
You can search also by
LinuxTerrorize:
Swift SF314-55
Hardware
PCI/USB ID
Working?
Bluetooth
8087:0026
Yes
8087:0033
Yes
According to the wiki page, my bluetooth should be working.
Bus 001 Device 006: ID 8087:0aaa Intel Corp. Bluetooth 9460/9560 Jefferson Peak (JfP)```
SGS
25 April 2024 05:31
10
Did you check also “Sound” in “System Settings” ?
Or you mean audio = sound?
Upps, wrong idea
Sadly I know nothing about plasma, I still use cinnimon desktop and it has blueberry. From what I read you might be using bluedevil as a GUI.
For the most part the bluetooth works, sometimes i have to delete the device, make sure the headphones are in pairing then re-connect. Sometimes I have to turn off and on my head phones. for it to connect and have sound.
but again I am using a different app and have no experience with bluedevil. I will say that I have the same device as you “Bluetooth 9460/9560”
I have no idea if the galaxy software for linux conflicts in anyway, but it might be good to uninstall it and reboot. Then try to pair again.
system
Closed
9 May 2024 05:34
12
