I am getting "Could not connect to host for smb://.local/" when trying to connect to other machines via "shared folders (SMB)" option under network in dolphin file manager
From other machine i am able to browse the same. Both machine have similar smb.conf file.
By other machine I meant is that i am able to connect to connect to Garuda Install from other Arch DE
Is there anything i am missing? Any help or pointers, much appreciated
Do you use Windoze on other computers in your network? If not, I would suggest installing the native Linux NFS (Network File System).
@librewish has done a great job of configuring Samba OOTB, yet the fact remains it is a reverse engineered M$ creation intended for Win based systems.
I haven't used Samba in quite some time. I consider it just not worth the effort to configure and maintain on Linux. Samba is just too prone to breakages IMO, NFS is rock solid in comparisson. NFS would always be my first choice, but that's just me.
Then I think NFS is totally the method for you. My own personal opinion is even if you get Samba configured and working it won't be too long before some Samba update breaks your configuration.
Once you have NFS configured, (and that is simpler than Samba) you're good for the long haul. The Arch wiki has lots of info on NFS.
i have couple of Windows machine..that i would to share with and hence trying to see if i could make Samba working...will try few things over the weekend...to see if i am missing anything trivial in configuration or settings.
Thanks, this fixed my problem today! Just installed Garuda this week.
added all my drives to fstab and nfs shares to exports, but forgot to start nfs service. facepalm
Ya used to use samba, because I was still logging on windows, for gaming.
Then when I made the full switch I figured, why not get something is optimized for linux and not to work with windows.
Sounds better and more optimized.
