Hello everyone!
Zoom on Linux is quite resource intensive - I could find multiple links where people have reported high CPU usage when Zoom runs on their systems; but I could not really find any reliable solution to it, apart from tweaking the Zoom settings as mentioned here, and a script to limit the CPU and memory. I have tweaked my settings, but not went ahead with the linked script, as my system anyways has 4 logical CPUs and couldn't find systemd
under $HOME/.config/
Therefore, I am wondering if there are ways to optimize Zoom's CPU usage (thus, lower down the high fan noise) on my Macbook Pro 2015 model running Garuda dragonized? Please let me know if any suggestions!
P.S. I recently freshly applied thermal paste and have cleaned by system internally. garuda-inxi
output below:
Kernel: 6.0.10-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=3b9186f6-a3ee-4548-95dc-048a2804b985 rw [email protected]
resume=UUID=1dc61dfb-3521-41db-b272-be8214602c50 loglevel=3
Desktop: KDE Plasma v: 5.26.3 tk: Qt v: 5.15.7 info: latte-dock
Type: Laptop System: Apple product: MacBookPro12,1 v: 1.0
serial: <superuser required> Chassis: type: 9 v: Mac-E43C1C25D4880AD6
Mobo: Apple model: Mac-E43C1C25D4880AD6 v: MacBookPro12,1
serial: <superuser required> UEFI: Apple v: 430.140.3.0.0 date: 04/18/2022
ID-1: BAT0 charge: 69.8 Wh (100.0%) condition: 69.8/72.3 Wh (96.5%)
volts: 12.5 min: 11.3 model: ifixit bq20z451 type: Li-ion serial: N/A
status: full cycles: 39
Info: model: Intel Core i5-5257U bits: 64 type: MT MCP arch: Broadwell
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2730 high: 2769 min/max: 500/3100 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 2769 2: 2702 3: 2700
4: 2750 bogomips: 21598
vulnerable
Device-1: Intel Iris Graphics 6100 vendor: Apple driver: i915 v: kernel
arch: Gen-8 process: Intel 14nm built: 2014-15 ports: active: eDP-1
empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:162b
Screen-1: 0 s-res: 2560x1600 s-dpi: 168 s-size: 387x241mm (15.24x9.49")
s-diag: 456mm (17.95")
Monitor-1: eDP-1 model: Apple Color LCD built: 2013 res: 2560x1600 hz: 60
dpi: 227 gamma: 1.2 size: 286x179mm (11.26x7.05") diag: 337mm (13.3")
ratio: 16:10 modes: 2560x1600
API: OpenGL v: 4.6 Mesa 22.2.3 renderer: Mesa Intel Iris Graphics 6100
(BDW GT3) direct render: Yes
Device-1: Intel Broadwell-U Audio vendor: Apple driver: snd_hda_intel
Device-3: Broadcom 720p FaceTime HD Camera driver: N/A pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 14e4:1570 class-ID: 0480
Sound API: ALSA v: k6.0.10-zen2-1-zen running: yes
Sound Server-2: PipeWire v: 0.3.60 running: yes
Device-1: Broadcom BCM43602 802.11ac Wireless LAN SoC vendor: Apple
driver: brcmfmac v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 03:00.0 chip-ID: 14e4:43ba class-ID: 0280
Device-1: Apple Bluetooth Host Controller type: USB
driver: btusb,hid-generic,usbhid bus-ID: 1-3:2 chip-ID: 05ac:8290
class-ID: fe01
Local Storage: total: 233.76 GiB used: 34.59 GiB (14.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Apple model: SSD SM0256G
size: 233.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: SA0Q scheme: GPT
ID-1: / raw-size: 224.66 GiB size: 224.66 GiB (100.00%)
used: 34.59 GiB (15.4%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
used: 652 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 224.66 GiB size: 224.66 GiB (100.00%)
ID-4: /var/log raw-size: 224.66 GiB size: 224.66 GiB (100.00%)
ID-5: /var/tmp raw-size: 224.66 GiB size: 224.66 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.67 GiB used: 241.2 MiB (3.1%)
dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 70.0 C pch: 65.5 C mobo: N/A
Processes: 240 Uptime: 1h 24m wakeups: 2 Memory: 7.67 GiB
used: 5.54 GiB (72.3%) Init: systemd v: 252 default: graphical
pkgs: 1275 libs: 314 tools: octopi,paru,yaourt Shell: fish v: 3.5.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.23
