The plan is to avoid runing xmodmap ~/.Xmodmap
in the terminal every time I reboot. I have seriously tried it all: creating a new service with systemd, running through all sorts of different options including full paths to xmodmap; creating a new .desktop entry in ~/.config/autostart/; dropping the command into my .bashrc; editing crontab, using the @reboot; using the Garuda Boot Options (which does not open for some reason); and so on. Honestly, that's about half of the different strategies that I've tried, where each strategy has included lots of modifications based on what I've found recommended on forums. I feel like it should be easy to have a script run on startup, or at least to run the xmodmap command indicated above on startup since, at least currently, this is all that I need. Any help would be much appreciated. Here is my inxi -Faz
Kernel: 5.16.1-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=b81a6f3e-b667-450e-9f4d-9ad16bae681d rw rootflags=subvol=@
Desktop: GNOME 41.3 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.3
Type: Laptop System: System76 product: Lemur Pro v: lemp9
Mobo: System76 model: Lemur Pro v: lemp9 serial: <superuser required>
UEFI: coreboot v: 2020-05-15_e2baafa date: 05/15/2020
ID-1: BAT0 charge: 51.0 Wh (93.4%) condition: 54.6/73.9 Wh (73.9%)
volts: 8.8 min: 7.7 model: Notebook BAT type: Li-ion serial: <filter>
status: Charging
Info: model: Intel Core i7-10510U bits: 64 type: MT MCP
arch: Comet/Whiskey Lake note: check family: 6 model-id: 0x8E (142)
stepping: 0xC (12) microcode: 0xEA
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1176 high: 2056 min/max: 400/4900 scaling:
driver: intel_pstate governor: powersave cores: 1: 900 2: 1306 3: 2056
4: 1389 5: 1057 6: 900 7: 900 8: 900 bogomips: 36799
Device-1: Intel CometLake-U GT2 [UHD Graphics] driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:9b41 class-ID: 0300
Device-2: Chicony Chicony USB2.0 Camera type: USB driver: uvcvideo
bus-ID: 1-7:2 chip-ID: 04f2:b685 class-ID: 0e02
Display: x11 server: X.Org 1.21.1.3 compositor: gnome-shell driver:
loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :1
s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 157
size: 310x170mm (12.2x6.7") diag: 354mm (13.9")
Device-1: Intel Comet Lake PCH-LP cAVS driver: snd_hda_intel v: kernel
chip-ID: 8086:02c8 class-ID: 0403
Sound Server-1: ALSA v: k5.16.1-zen1-1-zen running: yes
Sound Server-2: JACK v: 1.9.20 running: no
Sound Server-4: PipeWire v: 0.3.43 running: yes
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 02:00.0
chip-ID: 8086:2723 class-ID: 0280
bus-ID: 1-10:3 chip-ID: 8087:0029 class-ID: e001
address: <filter>
Local Storage: total: 465.76 GiB used: 125.68 GiB (27.0%)
rev: 2B2QEXM7 temp: 55.9 C scheme: GPT
ID-1: / raw-size: 465.51 GiB size: 465.51 GiB (100.00%)
used: 125.68 GiB (27.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 256 MiB size: 252 MiB (98.46%)
used: 546 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 465.51 GiB size: 465.51 GiB (100.00%)
ID-4: /var/log raw-size: 465.51 GiB size: 465.51 GiB (100.00%)
ID-5: /var/tmp raw-size: 465.51 GiB size: 465.51 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.5 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 55.0 C pch: 53.0 C mobo: N/A
Processes: 348 Uptime: 4m wakeups: 1 Memory: 15.5 GiB
used: 4.03 GiB (26.0%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1578 lib: 377 Shell: fish
v: 3.3.1 running-in: tmux: inxi: 3.3.12
