Hi there, I ran into an issue where I had kdfontop funtion error on boot and tried to fix it with this dev suggestion (SOLVED) KDFONTOP function not implemented
I put mkinitcpio -p into the terminal and after a reboot my system is all goofed up. All my installed apps/games disappeared and icons are just white now. My ssd lost over 200gb out of 500gb. Tried to use snapshots but they boot to the same thing. Any idea what I can do here? Even my terminal history is wiped and I can see the default garuda flavour text on printf. I use the default snapshot tool that comes with garuda. I can't see what else I put in the terminal that might have caused this issue since it got cleared.
Is there a way I can roll everything back before I attempted this? I have access to a live USB if needed.
I am quite new when it comes to this stuff.
Thanks
Kernel: 6.3.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=bec9422a-d102-4b77-900d-522e97b1d1f8 rw rootflags=subvol=@
loglevel=3 ibt=off
Type: Desktop System: ASUS product: All Series v: N/A
Mobo: ASUSTeK model: Z97-P v: Rev X.0x serial: <superuser required>
UEFI: American Megatrends v: 2907 date: 03/11/2016
Info: model: Intel Core i5-4690K bits: 64 type: MCP arch: Haswell
desc: 1x6 MiB
Speed (MHz): avg: 3799 high: 3900 min/max: 800/3900 scaling:
driver: intel_cpufreq governor: performance cores: 1: 3900 2: 3498 3: 3900
4: 3900 bogomips: 27983
Device-1: NVIDIA GM206 [GeForce GTX 950] vendor: Micro-Star MSI
status: current (as of 2023-05) arch: Maxwell code: GMxxx
process: TSMC 28nm built: 2014-19 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1402 class-ID: 0300
Screen-1: 0 s-res: 1920x1080 s-dpi: 30 s-size: 1626x914mm (64.02x35.98")
s-diag: 1865mm (73.44")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 30
size: 1600x900mm (62.99x35.43") diag: 1836mm (72.27") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 530.41.03 renderer: NVIDIA GeForce GTX
950/PCIe/SSE2 direct-render: Yes
Device-1: Intel 9 Series Family HD Audio vendor: ASUSTeK 9
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8ca0
Device-2: NVIDIA GM206 High Definition Audio vendor: Micro-Star MSI
bus-ID: 01:00.1 chip-ID: 10de:0fba class-ID: 0403
Device-3: PreSonus Audio AudioBox USB 96 driver: snd-usb-audio type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:3 chip-ID: 194f:0303
API: ALSA v: k6.3.4-zen1-1-zen status: kernel-api with: aoss
vendor: ASUSTeK AM1I-A driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
IF-ID-2: ztyouusv64 state: unknown speed: 10000 Mbps duplex: full
mac: <filter>
Local Storage: total: 2.27 TiB used: 181.47 GiB (7.8%)
model: WD2003FZEX-00Z4SA0 size: 1.82 TiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s tech: N/A serial: <filter> fw-rev: 1E.8
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 500GB
used: 181.47 GiB (39.0%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 592 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-1: swap-1 type: zram size: 15.56 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 32.0 C mobo: N/A gpu: nvidia temp: 24 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 42%
Processes: 231 Uptime: 1m wakeups: 0 Memory: available: 15.56 GiB
used: 2.2 GiB (14.1%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: N/A Packages: pm: pacman
pkgs: 2141 libs: 573 tools: octopi,pamac,paru pm: flatpak pkgs: 0
inxi: 3.3.27
System install date: 2022-12-01
Last full system update: 2023-05-26
Failed units: wg-quick@wg0.service
McFly: Upgrading McFly DB to version 3, please wait...thread 'main' panicked at 'McFly error: Unable to add cmd_tpl to commands (duplicate column name: cmd_tpl)', src/history/schema.rs:49:17
note: run with RUST_BACKTRACE=1
environment variable to display a backtrace
