hello
running into this error when I try to use paru
git reset --hard -q HEAD:
fatal: ambiguous argument ‘HEAD’: unknown revision or path not in the working tree.
Use ‘–’ to separate paths from revisions, like this:
‘git […] – […]’
seems to be a new issue since I reinstalled my system. another quirk since reinstallation, when the computer falls asleep and I wake it up and log in it takes me to a black screen which I can escape with the ctl alt f2 but it won’t let me into the system and makes me reboot.
thanks in advance!
╭─cc@cc in ~ on master [?] took 9s
[🔴] × garuda-inxi
Kernel: 6.13.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=aed9da9f-5ce9-4e9e-8dbb-f066d90ce36e rw rootflags=subvol=@
quiet resume=UUID=fd3dc478-5aa0-4469-883a-bdbfde213bad loglevel=3 ibt=off
Type: Desktop System: ASRock product: Z690M-ITX/ax v: N/A
Mobo: ASRock model: Z690M-ITX/ax serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: 13.02
date: 04/13/2023
Device-1: hid-CC260260KKSG61CAR-battery model: Apple Inc. Magic Trackpad 2
serial: N/A charge: N/A status: discharging
Info: model: 12th Gen Intel Core i5-12600KF bits: 64 type: MST AMCP
microcode: 0x38
Topology: cpus: 1x dies: 1 clusters: 7 cores: 10 threads: 16 mt: 6 tpc: 2
st: 4 smt: enabled cache: L1: 864 KiB desc: d-4x32 KiB, 6x48 KiB; i-6x32
KiB, 4x64 KiB L2: 9.5 MiB desc: 6x1.2 MiB, 1x2 MiB L3: 20 MiB
desc: 1x20 MiB
Speed (MHz): avg: 800 min/max: 800/4900:3600 scaling: driver: intel_pstate
bogomips: 117964
Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX
470/480/570/570X/580/580X/590] vendor: XFX Pine driver: amdgpu v: kernel
arch: GCN-4 code: Arctic Islands process: GF 14nm built: 2016-20 ports:
active: DP-3,HDMI-A-1 empty: DP-1,DP-2,DVI-D-1 bus-ID: 0000:01:00.0
Device-2: Logitech BRIO Ultra HD Webcam driver: snd-usb-audio,uvcvideo
type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:4
chip-ID: 046d:085e class-ID: 0102 serial: <filter>
Device-3: Realtek NexiGo N660P FHD Webcam driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:5
chip-ID: 0bda:0567 class-ID: 0102 serial: <filter>
s-diag: 1055mm (41.54")
Monitor-1: DP-3 mapped: DisplayPort-2 pos: primary,left
model: Samsung C27F390 serial: <filter> built: 2021 res: mode: 1920x1080
hz: 60 scale: 100% (1) dpi: 82 gamma: 1.2 size: 598x336mm (23.54x13.23")
diag: 686mm (27") ratio: 16:9 modes: max: 1920x1080 min: 720x400
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: right model: Acer EB321HQ A
serial: <filter> built: 2021 res: mode: 1920x1080 hz: 60 scale: 100% (1)
dpi: 70 gamma: 1.2 size: 698x393mm (27.48x15.47") diag: 801mm (31.5")
device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.0.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 580 Series (radeonsi
polaris10 ACO DRM 3.61 6.13.7-zen1-1-zen) device-ID: 1002:67df
memory: 7.81 GiB unified: no
API: Vulkan v: 1.4.304 layers: 9 device: 0 type: discrete-gpu name: AMD
Radeon RX 580 Series (RADV POLARIS10) driver: N/A device-ID: 1002:67df
Device-1: Intel Alder Lake-S HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
Device-2: Advanced Micro Devices [AMD/ATI] Ellesmere HDMI Audio [Radeon
RX 470/480 / 570/580/590] vendor: XFX Pine driver: snd_hda_intel v: kernel
bus-ID: 0000:01:00.1 chip-ID: 1002:aaf0 class-ID: 0403
Device-3: Logitech BRIO Ultra HD Webcam driver: snd-usb-audio,uvcvideo
Device-4: Realtek NexiGo N660P FHD Webcam driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.13.7-zen1-1-zen status: kernel-api with: aoss
bus-ID: 0000:00:14.3 chip-ID: 8086:7af0 class-ID: 0280
Device-2: Intel Ethernet I219-V vendor: ASRock driver: e1000e v: kernel
port: N/A bus-ID: 0000:00:1f.6 chip-ID: 8086:1a1d class-ID: 0200
Device-3: Realtek RTL8125 2.5GbE vendor: ASRock driver: r8169 v: kernel
port: 3000 bus-ID: 0000:02:00.0 chip-ID: 10ec:8125 class-ID: 0200
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:8 chip-ID: 8087:0033
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 2.73 TiB used: 481.77 GiB (17.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 3B2QGXA7 temp: 47.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 1TB
ID-1: / raw-size: 1.79 TiB size: 1.79 TiB (100.00%) used: 481.77 GiB (26.3%)
used: 481.77 GiB (26.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 31.17 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 34.29 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 45.2 C mobo: N/A gpu: amdgpu temp: 32.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 687
Memory: total: 32 GiB available: 31.17 GiB used: 3.77 GiB (12.1%)
Processes: 435 Power: uptime: 2m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.46 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1912 libs: 550 tools: octopi,paru Compilers:
clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi default: fish v: 4.0.1
System install date: 2025-03-07
Last full system update: 2025-03-15
