Hello everybody,
I installed cron for some task scheduling and used the cronjobs as a user.
For this I installed cron and activated the service with systemctl start cronie
I tested some bash scripts and the worked.
I wanted to create a script that would update all the packages, delete cache and so on.
For this I have to be root.
I wanted to create a cronjob as root after opening the terminal as root with the known command:
crontab -e
and got this error message:
no crontab for root - using an empty one
Executing Kate with kdesu is not possible due to unfixable security vulnerabilities. It is also not necessary;simply use Kate normally, and you will be prompted for elevated privileges when saving documents if needed.
crontab: "kate" exited with status 1
I updated all packages, reinstalled them as well. But no result.
What information should I provide / is missing?
Thanks in advance.
