I am trying to setup garuda as my new OS and when I run the live usb everything works great, games run better than windows mostly and everything is smooth. However once I install the OS its somewhat laggy, I’m getting one third of the frames in games and gpu/cpu utilization hovers around 30%. I also get screen flickering quite a bit.
In garuda settings manager → hardware config my gpu is listed as unknown device name as opposed to the correct name that shows when booted into the live usb.
If I run GreenWithEnvy it complains “NV CONTROL X extension not found” and then says to double check the propriertary drivers are installed and support my gpuu whereas in the live usb it works and I can change my gpu settings etc.
I did check my drivers and according to the nvidia website 535 is what I should be using.
My theory is its not using the proprietary drivers but not sure how to confirm that.
I have tried:
-updated my bios
-reinstallling garuda
-system update
-reinstalling nvidia-dkms
-paru nvidia-535xx-dkms nvidia-535xx-utils
-sudo pacman -S linux-zen-headers
-lts kernel and everything above following switching
-“sudo dkms autoinstall” this doesn’t appear to do anything, no output to konsole
The first time I did a clean install of garuda I had the same issue and “setup_dxvk install” fixed it until I turned my pc off for the night then it was back to bad performance.
Kernel: 6.7.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=adc85053-024e-4510-914a-e72db7112754 rw rootflags=subvol=@
v: 5.115.0 wm: kwin_wayland vt: 1 dm: SDDM Distro: Garuda base: Arch Linux
Mobo: ASUSTeK model: PRIME Z690-P WIFI D4 v: Rev 1.xx
UEFI: American Megatrends v: 3202 date: 02/20/2024
Info: model: 13th Gen Intel Core i9-13900K bits: 64 type: MST AMCP
microcode: 0x123
Topology: cpus: 1x cores: 24 mt: 8 tpc: 2 st: 16 threads: 32 smt: enabled
cache: L1: 2.1 MiB desc: d-16x32 KiB, 8x48 KiB; i-8x32 KiB, 16x64 KiB
L2: 32 MiB desc: 8x2 MiB, 4x4 MiB L3: 36 MiB desc: 1x36 MiB
Speed (MHz): avg: 865 high: 1100 min/max: 800/5500:5800:4300 scaling:
driver: intel_pstate governor: powersave cores: 1: 1100 2: 800 3: 1100
4: 800 5: 800 6: 800 7: 800 8: 800 9: 1100 10: 1100 11: 1100 12: 800
13: 1100 14: 800 15: 1100 16: 800 17: 800 18: 800 19: 800 20: 800 21: 800
22: 801 23: 800 24: 800 25: 800 26: 800 27: 800 28: 800 29: 800 30: 800
31: 800 32: 800 bogomips: 191692
Device-1: NVIDIA AD102 [GeForce RTX 4090] vendor: Micro-Star MSI
status: current (as of 2024-02) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: none off: DP-1,DP-2,DP-3 empty: HDMI-A-1 bus-ID: 01:00.0
chip-ID: 10de:2684 class-ID: 0300
alternate: fbdev,nouveau,nv,vesa gpu: nvidia d-rect: 6400x1440
display-ID: 0
Monitor-1: DP-1 pos: primary,left res: 2560x1440 size: N/A modes: N/A
Monitor-2: DP-2 pos: center res: 1920x1080 size: N/A modes: N/A
Monitor-3: DP-3 pos: right res: 1920x1080 size: N/A modes: N/A
API: EGL v: 1.5 hw: drv: nvidia platforms: gbm: drv: nvidia wayland:
drv: nvidia
API: OpenGL v: 4.6.0 vendor: nvidia v: 545.29.06 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce RTX 4090/PCIe/SSE2
memory: 23.43 GiB display-ID: :1.0
API: Vulkan v: 1.3.276 layers: 7 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 4090 driver: nvidia v: 545.29.06
device-ID: 10de:2684 surfaces: xcb,xlib,wayland
Device-1: Intel Alder Lake-S HD Audio vendor: ASUSTeK driver: snd_hda_intel
Device-2: NVIDIA AD102 High Definition Audio vendor: Micro-Star MSI
bus-ID: 01:00.1 chip-ID: 10de:22ba class-ID: 0403
Device-3: SteelSeries ApS Arctis 7
lanes: 1 mode: 1.1 bus-ID: 1-12:8 chip-ID: 1038:12ad class-ID: 0300
API: ALSA v: k6.7.5-zen1-1-zen status: kernel-api with: aoss
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 4000 bus-ID: 05:00.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:10 chip-ID: 8087:0026
Hardware-1: Intel Volume Management Device NVMe RAID Controller Intel
driver: vmd v: 0.6 port: N/A bus-ID: 00:0e.0 chip-ID: 8086:a77f rev:
class-ID: 0104
Local Storage: total: 7.69 TiB used: 19.04 GiB (0.2%)
fw-rev: 2B2QEXM7 temp: 44.9 C scheme: GPT
model: WD60EZAZ-00SF3B0 size: 5.46 TiB block-size: physical: 4096 B
fw-rev: 0A80 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 1TB
model: WD3200AAJS-56M0A0 size: 298.09 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s tech: N/A serial: <filter> fw-rev: 3E01
ID-5: /dev/sdd maj-min: 8:48 vendor: Samsung model: Flash Drive FIT
size: 119.51 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.1 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter>
fw-rev: 1100 scheme: MBR
ID-1: / raw-size: 219.73 GiB size: 219.73 GiB (100.00%)
used: 19.01 GiB (8.7%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
used: 26.8 MiB (27.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 219.73 GiB size: 219.73 GiB (100.00%)
ID-4: /var/log raw-size: 219.73 GiB size: 219.73 GiB (100.00%)
ID-5: /var/tmp raw-size: 219.73 GiB size: 219.73 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.08 GiB used: 6.2 MiB (0.0%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 32 dev: /dev/zram0
System Temperatures: cpu: 33.0 C mobo: N/A
Fan Speeds (rpm): cpu: 1069
Memory: total: 32 GiB note: est. available: 31.09 GiB used: 5.27 GiB (17.0%)
Processes: 544 Power: uptime: 7m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.39 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1792 libs: 529 tools: octopi,paru Compilers:
gcc: 13.2.1 Shell: garuda-inxi default: fish v: 3.7.0 running-in: konsole
inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2024-02-22
Last full system update: 2024-02-22 ↻
