Hello)
im using garuda dragonized gaming with ryzen 5 2600 and rtx 3060. in installed nvidia 470.63 drivers. dxvk works perfect. trying witcher 3 from steam with amd fsr get 4k 70 fps). Dbt in lutris valhalla dont work( Proglem with vkd3d. game says gpu not dx12 compatible. maybe i need to install some additional packages?
Please help.
You saw the posting rules. No help unless you first post the output of inxi -Fzza
System: Host: amdGaruda Kernel: 5.13.12-zen1-1-zen x86_64 bits: 64 Desktop: KDE Plasma 5.22.4
Distro: Garuda Linux
Machine: Type: Desktop Mobo: Gigabyte model: B450 AORUS ELITE v: x.x serial: <superuser required>
UEFI: American Megatrends LLC. v: F62 date: 07/13/2021
CPU: Info: 6-Core model: AMD Ryzen 5 2600 bits: 64 type: MT MCP cache: L2: 3 MiB
Speed: 3115 MHz min/max: 1550/3400 MHz Core speeds (MHz): 1: 3115 2: 2262 3: 3893 4: 2230
5: 3374 6: 2231 7: 3888 8: 3138 9: 2559 10: 3452 11: 3416 12: 2231
Graphics: Device-1: NVIDIA GA106 [GeForce RTX 3060] driver: nvidia v: 470.63.01
Display: x11 server: X.Org 1.20.13 driver: loaded: nvidia resolution: 1920x1080~60Hz
OpenGL: renderer: NVIDIA GeForce RTX 3060/PCIe/SSE2 v: 4.6.0 NVIDIA 470.63.01
Audio: Device-1: NVIDIA driver: snd_hda_intel
Device-2: Sennheiser EPOS GSX 300 type: USB driver: hid-generic,snd-usb-audio,usbhid
Sound Server-1: ALSA v: k5.13.12-zen1-1-zen running: yes
Sound Server-2: PulseAudio v: 15.0 running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169
IF: eno1 state: up speed: 1000 Mbps duplex: full mac: 18:c0:4d:49:5f:35
IF-ID-1: anbox0 state: down mac: 4a:8d:63:f5:78:a3
Drives: Local Storage: total: 931.52 GiB used: 27.6 GiB (3.0%)
ID-1: /dev/sda vendor: Western Digital model: WDS100T2G0A-00JH30 size: 931.52 GiB
Partition: ID-1: / size: 931.26 GiB used: 27.6 GiB (3.0%) fs: btrfs dev: /dev/sda2
ID-2: /boot/efi size: 256 MiB used: 562 KiB (0.2%) fs: vfat dev: /dev/sda1
ID-3: /home size: 931.26 GiB used: 27.6 GiB (3.0%) fs: btrfs dev: /dev/sda2
ID-4: /var/log size: 931.26 GiB used: 27.6 GiB (3.0%) fs: btrfs dev: /dev/sda2
ID-5: /var/tmp size: 931.26 GiB used: 27.6 GiB (3.0%) fs: btrfs dev: /dev/sda2
Swap: ID-1: swap-1 type: zram size: 15.57 GiB used: 0 KiB (0.0%) dev: /dev/zram0
Sensors: System Temperatures: cpu: 42.2 C mobo: N/A gpu: nvidia temp: 45 C
Info: Processes: 305 Uptime: 21m Memory: 15.57 GiB used: 2.26 GiB (14.5%) Shell: fish inxi: 3.3.06
here it is my inxi info
I suspect it will be useful to include some more information about what this is and what you're trying to do.
If Steam games work then the system itself is set up correctly.
i have played witcher 3 dx 11 in steam it work great. in lutris i have tried to run valhalla with amd fsr and vkd3d. it says my gpu dont support dx 12. i will try later run horizon zero down with dx 12 in steam to see would vkd3d in steam work. if it is then it is lutris problem.
i will write result later if it works
