Hi All,
This is such a great distro, makes arch usable! - I love it.
I'm having an issue getting the GFX in my laptop to work using NVIDIA drivers. I have downloaded from NVIDIA (however, I don't think that I'm supposed to do that from doing some reading) but that won't install as nouveau is running, and I can't seem to blacklist it.
I've seen someone with an older GTX card get them working by running a pacman command (sudo pacman -Syu nvidia-470xx-dkms) - but I have no idea what nvidia package (if one exists) I need to install via pacman.
Cany anyone help me get proper hardware accelerated GFX working on my Garuda installation, I love it so much and would very much like to keep using it
You’re correct, so rather than trying to get something to work that you know is the wrong approach, why not try the correct approach and install the NVIDIA drivers using the Garuda tools?
Hi there, welcome.
Please always include the output of your garuda-inxi, as instructed in the template.
As regards your issue, I'm not a Nvidia user nor expert but I've seen many troubles starting installing wrong drivers at first.
Anyway, in general, you can install the proprietary drivers from the setup assistant or with the HW assistant (Garuda Welcome - > Garuda Settings Manager - > Hardware Configuration).
"You're correct, so rather than trying to get something to work that you know is the wrong approach, why not try the correct approach and install the NVIDIA drivers using the Garuda tools?"
I have tried that - but then the display scale is HUGE, even when in display settings the scale is set to 100%. Makes it look like I'm using a super low res.
I'll post the output from garuda-inxi ASAP.
As mentioned above, I did try the installation using the built-in tool in the Setup Assistant, and also via Hardware Manager - but the display res looked like 800x600 even though in Display Settings it was showing 1920x1080 and scaled to 100%.
Odd.
In which case this is the problem you need to fix - installing the same driver via a different route isn’t going to help.
Can you switch your laptop to discrete graphics mode in the UEFI? If so, that’s going to be the most reliable way of getting the dGPU to work correctly.
I seem to remember that there was a certain range of cards that were “unknown” within the NVIDIA PCIID list - I wonder if this was one of them, and it’s installing the wrong driver package.
Which driver does the Hardware Manager pick to install?
I found that out last night! There was no xorg.conf
I have now solved the issue. I used the auto installed driver. Turns out I had to use Nvidia server settings tool to create an X11 conf file, and add in an option to “Monitor” specifying a custom DPI setting.
Ideally you wouldn't have a xorg.conf file at all. Just having the DPI settings on its own in xorg.conf.d should be enough and is the preferred solution to having a full xorg.conf.
