[RTL8822CE] Wifi option is not showing in garuda linux Dr460nized
Hello! Everyone,
Today I installed garuda linux in my pc(hp 14s), but I am unable to connect to a wifi network cause its not showing at all.
This is my pc info :-
Kernel: 6.2.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=9a7d04fc-3ed6-4e9b-81b8-dafc2fb88bf9 rw [email protected]
resume=UUID=2aff6f50-56b4-4329-b259-442819cafc73 loglevel=3
Type: Laptop System: HP product: HP Laptop 14s-dy2xxx v: N/A
Mobo: HP model: 87FD v: 57.20 serial: <superuser required> UEFI: AMI
v: F.21 date: 03/21/2022
ID-1: BAT0 charge: 18.7 Wh (51.4%) condition: 36.4/41.0 Wh (88.8%)
volts: 11.1 min: 11.3 model: HP Primary type: Li-ion serial: <filter>
status: discharging cycles: 143
Info: model: 11th Gen Intel Core i3-1115G4 bits: 64 type: MT MCP
microcode: 0xA6
L1: 160 KiB desc: d-2x48 KiB; i-2x32 KiB L2: 2.5 MiB desc: 2x1.2 MiB
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 976 high: 1399 min/max: 400/4100 scaling:
driver: intel_pstate governor: powersave cores: 1: 1241 2: 1399 3: 559
4: 705 bogomips: 23961
Device-1: Intel Tiger Lake-LP GT2 [UHD Graphics G4] vendor: Hewlett-Packard
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1
bus-ID: 0000:00:02.0 chip-ID: 8086:9a78 class-ID: 0300
Device-2: Luxvisions Innotech HP TrueVision HD Camera type: USB
driver: uvcvideo bus-ID: 1-3:4 chip-ID: 30c9:0035 class-ID: fe01
Monitor-1: eDP-1 model: ChiMei InnoLux 0x1400 built: 2018 res: 1920x1080
hz: 60 dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 23.0.2 renderer: Mesa Intel UHD Graphics (TGL GT2)
direct-render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Hewlett-Packard
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
chip-ID: 8086:a0c8 class-ID: 0401
API: ALSA v: k6.2.10-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.68 status: active with: 1: pipewire-pulse
vendor: Hewlett-Packard driver: N/A modules: rtw88_8822ce port: 3000
bus-ID: 0000:01:00.0 chip-ID: 10ec:c822 class-ID: 0280
IF-ID-1: enp0s20f0u1 state: unknown speed: -1 duplex: half mac: <filter>
Device-1: MediaTek RMX3286 type: USB driver: rndis_host v: kernel
bus-ID: 1-1:2 chip-ID: 0e8d:2004 class-ID: 0a00 serial: <filter>
Device-2: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-10:5 chip-ID: 0bda:b00c class-ID: e001 serial: <filter>
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
Local Storage: total: 238.47 GiB used: 6.69 GiB (2.8%)
model: MZVLQ256HAJD-000H1 size: 238.47 GiB block-size: physical: 512 B
rev: HPS4NFXV temp: 48.9 C scheme: GPT
ID-1: / raw-size: 100 GiB size: 100 GiB (100.00%) used: 6.59 GiB (6.6%)
ID-2: /boot/efi raw-size: 513 MiB size: 512 MiB (99.80%)
used: 608 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 129.97 GiB size: 129.97 GiB (100.00%)
used: 99.7 MiB (0.1%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
ID-4: /var/log raw-size: 100 GiB size: 100 GiB (100.00%)
used: 6.59 GiB (6.6%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
ID-5: /var/tmp raw-size: 100 GiB size: 100 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.41 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
System Temperatures: cpu: 71.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0 fan-2: 0
Processes: 202 Uptime: 6m wakeups: 11436 Memory: 7.41 GiB
used: 2.19 GiB (29.6%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1156
libs: 313 tools: octopi,paru Shell: fish v: 3.6.1 default: Bash v: 5.1.16
System install date:     2023-04-13
Last full system update: 2023-04-13
Hi there, welcome to the forum!
Tip: If you use the forum search function, network issues can be easily spotted / narrowed down limiting the search to the Networking category, where Topics are Solved, and of course you could search for your wifi card.
I'd try this solution first:
If you don't have an Ethernet card, you will need of course to use your mobile phone in tethering mode.
I tried but this is showing while installing
ERROR: Missing 6.2.10-arch1-1 kernel modules tree for module rtw88/r218.37c8025.
Please help me
What to do now
I still waiting for your reply
please answer something
Please don't be pushy.
We are all unpaid volunteers here.
I, for example, check the forum only during some breaks, but I am at work now and will have to dedicate some time to family soon after back home...
Sorry, I will try again in a few hours.
Try installing the linux kernel:
sudo pacman -S linux linux-headers
and then again that package.
If not working again, try to build it yourself with an helper:
paru rtw88-dkms-git
I am so sorry sir, actually I was so nervous that time. I apologies :frowning:
Now I am trying your fix.
It shows this error
Error! The module/version combo: rtw88-r219.0f1890b is not located in the DKMS tree.
There might be something wrong with that package...
My last idea is to try with the LTS kernel:
Of course, every time you install a new kernel make sure you reboot and select the new kernel in the GRUB menu.
Shouldn’t this be moved to issues and not community?
I'm getting an error message "500 Internal Server Error" , since the very first moment I saw the topic.
Tried with PC, mobile, ...
It should be fine now, thanks to @dr460nf1r3 :smiley:
