my Asus tuf A15 is having Realtek wireless adapter but I am unable to get the WiFi driver for the same.
RTL8822 is the name of the wireless driver, there is no open source driver as well no proprietary drivers showing in the driver installation section!?
So if there is a way to get the WiFi driver kindly help!
Please
and post
inxi -Fxxxza
and
System: Kernel: 5.12.5-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=4101d0e8-23db-4583-9033-fe2a736a232a
Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: ASUSTeK product: ASUS TUF Gaming A15 FA506IV_FA506IV v: 1.0
Mobo: ASUSTeK model: FA506IV v: 1.0 serial: <filter> UEFI: American Megatrends v: FA506IV.316
date: 03/12/2021
Battery: ID-1: BAT1 charge: 40.3 Wh (98.5%) condition: 40.9/48.1 Wh (85.1%) volts: 12.0 min: 11.7
model: ASUS A32-K55 type: Li-ion serial: N/A status: Discharging
CPU: Info: 8-Core model: AMD Ryzen 9 4900H with Radeon Graphics bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 60 (96) stepping: 1 microcode: 8600104 cache: L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 105400
Speed: 1397 MHz min/max: 1400/3300 MHz boost: enabled Core speeds (MHz): 1: 1397 2: 1391
3: 1397 4: 1397 5: 1411 6: 1401 7: 1325 8: 1398 9: 1372 10: 2202 11: 1397 12: 1397 13: 1397
14: 1396 15: 1629 16: 1397
mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: ASUSTeK driver: nvidia v: 465.31
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1f15 class-ID: 0300
Device-2: AMD Renoir vendor: ASUSTeK driver: amdgpu v: kernel bus-ID: 05:00.0
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo bus-ID: 3-4:3
chip-ID: 13d3:56a2 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: modesetting
Monitor-1: eDP-1 res: 1920x1080 hz: 144 dpi: 142 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
OpenGL: renderer: AMD RENOIR (DRM 3.40.0 5.12.5-zen1-1-zen LLVM 11.1.0) v: 4.6 Mesa 21.1.0
direct render: Yes
Audio: Device-1: AMD vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 05:00.1
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
Sound Server-1: ALSA v: k5.12.5-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.28 running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: r8169
v: kernel port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter vendor: Lite-On driver: N/A
modules: rtw88_8822ce port: d000 bus-ID: 03:00.0 chip-ID: 10ec:c822 class-ID: 0280
IF-ID-1: enp5s0f4u2 state: unknown speed: N/A duplex: N/A mac: <filter>
Bluetooth: Device-1: Lite-On Bluetooth Radio type: USB driver: btusb v: 0.8 bus-ID: 5-1:2
chip-ID: 04ca:4005 class-ID: e001 serial: <filter>
Report: bt-adapter ID: hci0 rfk-id: 0 state: down bt-service: enabled,running rfk-block:
Device-2: Samsung Galaxy series misc. (tethering mode) type: USB driver: rndis_host v: kernel
bus-ID: 5-2:4 chip-ID: 04e8:6863 class-ID: 0a00 serial: <filter>
Drives: Local Storage: total: 1.38 TiB used: 26.73 GiB (1.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN530 SDBPNPZ-512G-1002
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
rotation: SSD serial: <filter> rev: 21106000 scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter>
rev: 0001 scheme: GPT
Partition: ID-1: / raw-size: 47.36 GiB size: 47.36 GiB (100.00%) used: 26.69 GiB (56.4%) fs: btrfs
dev: /dev/nvme0n1p8 maj-min: 259:8
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 32.4 MiB (12.7%) fs: vfat
ID-3: /home raw-size: 47.36 GiB size: 47.36 GiB (100.00%) used: 26.69 GiB (56.4%) fs: btrfs
ID-4: /var/log raw-size: 47.36 GiB size: 47.36 GiB (100.00%) used: 26.69 GiB (56.4%) fs: btrfs
ID-5: /var/tmp raw-size: 47.36 GiB size: 47.36 GiB (100.00%) used: 26.69 GiB (56.4%) fs: btrfs
ID-1: swap-1 type: zram size: 967.5 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-2: swap-2 type: zram size: 967.5 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-3: swap-3 type: zram size: 967.5 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-4: swap-4 type: zram size: 967.5 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram3
ID-5: swap-5 type: zram size: 967.5 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram4
ID-6: swap-6 type: zram size: 967.5 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram5
ID-7: swap-7 type: zram size: 967.5 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram6
ID-8: swap-8 type: zram size: 967.5 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram7
ID-9: swap-9 type: zram size: 967.5 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram8
ID-10: swap-10 type: zram size: 967.5 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram9
ID-11: swap-11 type: zram size: 967.5 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram10
ID-12: swap-12 type: zram size: 967.5 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram11
ID-13: swap-13 type: zram size: 967.5 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram12
ID-14: swap-14 type: zram size: 967.5 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram13
ID-15: swap-15 type: zram size: 967.5 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram14
ID-16: swap-16 type: zram size: 967.5 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram15
Sensors: System Temperatures: cpu: 39.9 C mobo: 0 C gpu: amdgpu temp: 37.0 C
Fan Speeds (RPM): cpu: 2200
Info: Processes: 347 Uptime: 4m wakeups: 1 Memory: 15.12 GiB used: 2.63 GiB (17.4%) Init: systemd
v: 248 tool: systemctl Compilers: gcc: 11.1.0 clang: 11.1.0 Packages: pacman: 1833 lib: 346
Shell: fish v: 3.2.2 running-in: konsole inxi: 3.3.04
why so complocated just give “RTL8822” to your add remove sofware maker and you will find what you want i know ^^
I wish it was that easy
But there is no driver to be specific RTL8822CE
Other drivers are not been shown in the hardware configuration driver section
sorry for that
sorry das ich das fragen muss aber hast du auch aur chaotic freigeschaltet also vielleicht kompilieren
sorry i have to ask this but did you also unlock aur chaotic so maybe compile it
sorry i 'm a white germain
i think i get it for you
always search for "rtl88x2ce-dkms" in software add/remove program
hope it helps
Try:
rtw88-dkms-git
It is in the Chaotic AUR.
Test other kernels if not working.
Thank you for that but I already have that driver ,the specific driver I am talking about is missing , my network device is
Realtek RTL882CE 802.11ac PCIe Wireless Network Adapter
Vendor: Lite-On
Driver: N/A (as mentioned)
Modules: rtw88_8822ce
Port: d000
bus-ID: 03:00.0
Who are you responding to, myself or @anon4516988.
Oh I am sorry I was responding to the above
Your message just came
Lemme try it your way
Thanks for the help
I hope you don't mind, but I edited your title to include your full wifi adapter model.
RTL8822 has multiple different adapters with different designations. Without your full terminal inxi output we wouldn't have known your proper adapter model. Some people seem to think we request this information too frequently, but without your full specs we are simply playing a guessing game.
Thank you for providing the proper textual terminal output when requested.
Edit:
Also, be sure to disable MAC address randomization, because this laptop may have problems connecting to your network after suspension. Randomization may be easily disabled through the Garuda Network Assistant.
Thank You So much
It worked!
You're very welcome, and I hope you enjoy Garuda.
